Lynn Matteson
Posted: Thu Mar 11, 2010 1:58 pm Post subject: Northstar problems |
I don't think so....the one I have in my hands (actually I laid it
down to type) has the feel and weight of glass, and the ends of the
glass tube look like they have been "flame smoothed" and I don't
think poly-carb will stand still for that, but I could be wrong. This
particular one is marketed by Mr. Gasket, and is not up to the
quality of the Purolator filters, in my opinion. The instructions say
"The glass housing will weaken if scratched or chipped. If the glass
housing is damaged or dropped, DO NOT USE IT-you must replace the
housing." I don't know if these warnings would apply if the housing
were poly-carb. But aside from the instructions, which may use
"glass" as a generic term, my experience tells me that this is glass,
and so are the 3 on my plane, and the other 2 or 3 hanging on a peg
in the hangar.
Lynn Matteson
Jabiru 2200, #2062, 876.7 hrs (since 3-27-2006)
Countdown to 1000 hrs~124 to go(135 days to go)
Sensenich 62"x46" Wood (summer)
Sensenich 55.5" x 46" Wood (winter)
Rotec TBI-40 injection
Status: flying (and learning)
On Mar 11, 2010, at 4:27 PM, vetdrem wrote:
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Float Flyr
Posted: Thu Mar 11, 2010 2:08 pm Post subject: Northstar problems |
Lynn:
When you say "Glass filters" do you mean the cases are glass and the filter
material is something else or is the filter medium some kind of glass wool?
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Thu Mar 11, 2010 2:19 pm Post subject: Northstar problems |
Mike:
Even though I'm in favour of the gascolator, I do have to note that the
chances of stirring up debris is much higher in the gascolator than in a
filtered header tank of a gallon or more. The only thing I would like to
see would be to have the bottom of the header tank cup or funnel shaped so
any water would definitely flow to the bottom drain and not stay around in
the bottom of the header tank.
I used to service gascolators on bush planes that used a felt cloth to
filter all the fuel that went into the planes. Felt like chamois won't pass
water.... Remember the cowboy movies where the hero always gave his horse a
drink from his felt hat... The one problem with felt is that it is mostly
made of beaver fur ( Canada) and occasionally you will find a hair or two
that gets through the system as far as... you got it, the screen in the
gascolator.
Noel
Kitfox III-A
Lynn Matteson
Posted: Thu Mar 11, 2010 2:20 pm Post subject: Northstar problems |
I think that's what Jim was pointing out, Noel. If you look at the
picture again, you'll see a fitting....looks like a quick-
drain....underneath the header tank. I think Jim just hasn't got
around to cutting the fabric at that point...or am I full of it
again, Jim? : )
Aren't the present tanks equipped with the bottom drain? Mine is, and
I think it was from a model 5 if not mistaken....Deke?
Lynn Matteson
On Mar 11, 2010, at 3:40 PM, Noel Loveys wrote:
| Quote: | You need an access port on the bottom of the fuse to take samples
from your header. A nice addition on future header tanks would be
for the tank to have a small sump on the bottom to trap water.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-
list-server(at)matronics.com] On Behalf Of Zimmermans
Sent: March 10, 2010 1:15 AM
Subject: Re: Northstar problems
Here you can see the outlet on the front and the drain in the bottom.
Jim Series 5 0-200
21D MN
============================================================ _-
contribution_-
N369LM |
akflyer
Posted: Thu Mar 11, 2010 2:22 pm Post subject: Re: Northstar problems |
Lyn something to think about.. Pipers originally came out with a glass gascolator. There are an ungodly amount of cub drivers up here that crashed, survived the impact but were trapped or pinned in the wreckage. The gascolator would break and the ensuing fires would kill the otherwise pretty much unharmed pilot. I know one of my flying buddies that watched a guy he had just checked out in a cub do an accelerated stall and go in. By the time my buddy was able to land and get over to the wreckage all he could hear was his friend screaming as he was burning up... He would have survived that wreck had the glass not been in place in the fuel system.
I don't think you can find a cub or piper around here anymore that has glass in the fuel system.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Lynn Matteson
Posted: Thu Mar 11, 2010 2:56 pm Post subject: Northstar problems |
Noel-
The housing is glass, and the filter medium is some kind of nylon/
plastic/? material. I don't have the Purolator package here at home,
and don't recall what their marketing term was, but the Mr. Gasket
brand calls it a "Clear View Fuel Filter" Incidentally, the Mr.
Gasket brand is a poorly-made version of the same thing Purolator
used to sell. NAPA is another take-off of the same thing. The Mr.
Gasket one uses plastic (of some sort) screw-in barbed fittings,
whereas the original Purolator (as far as I know Purolator came
before the imitators) had one-piece end caps that had "gentle" barbs,
meaning that you could take the fuel hose off without pulling shards
of rubber/neoprene out with it.
From what I've seen, the NAPA brand is better than the Mr. Gasket,
but by the time you read this, they both may have gone downhill in
quality. Aircraft Spruce (2009-2010 catalog, p.164, lower left
corner) still shows the "Glass #804" filter, and the "Glass #806"
filter, the 04 and 06 referring to the size of the end cap barbs in
1/16" increments. Purolator used to sell a #805, which was for a
5/16" fuel line, but Spruce doesn't seem to show that one. And like
everything else, if you order, you may not get the genuine article,
Purolator, but one of the cheaper substitutes, which aren't ALL that
bad, it's just when you've seen and used the original, the others
seem to lack the quality.
Lynn Matteson
On Mar 11, 2010, at 5:06 PM, Noel Loveys wrote:
Lynn:
the filter
glass wool?
Noel
N369LM |
Lynn Matteson
Posted: Thu Mar 11, 2010 3:07 pm Post subject: Northstar problems |
That is good info, Lenny....sad, but good to keep in mind. Two of my
glass filters are situated in the cabin, sort of protected by the two
angled down-tubes behind my head, and preceded by shut-off valves.
The other one is under the console, surrounded by metal on three
sides. I'm not saying that I'm isolated from the incidents that you
describe, but if something gets to those filters and breaks that
glass, well, I don't think I'm gonna be in any condition to scream.
Like Art Arfons replied to me (I had asked how he liked driving the
Green Monster Ranger-engined dragster with the drive shaft rotating
between his legs, TOO close to his crotch): "I'm still lookin' for
the guy who wants to live forever."
Lynn Matteson
On Mar 11, 2010, at 5:22 PM, akflyer wrote:
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
582 (100 hrs and counting on the rebuild)
IVO IFA
Full Lotus 1450
http://forums.matronics.com/viewtopic.php?p=290052#290052
N369LM |
Float Flyr
Posted: Thu Mar 11, 2010 7:39 pm Post subject: Northstar problems |
The only reason I asked the question is because years ago my mother used to
use Angel hair in (spun Glass) in the filters of her aquarium. As I was
reading the post it came to me that angel hair could make a great filter and
easily recharged.
Wouldn't gasoline dissolve polycarbonate?
Noel
Kitfox III-A
Float Flyr
Posted: Thu Mar 11, 2010 7:43 pm Post subject: Northstar problems |
Thanks Lynn
Noel
Kitfox III-A
Float Flyr
Posted: Thu Mar 11, 2010 7:46 pm Post subject: Northstar problems |
Those glass bowls were pretty hefty and hard as nails... I expect it was
not the glass that broke but the body (top ) of the gascolator. Like any
other fitting on the fuel system if it breaks that is not good. Don't
forget the location of that glass bowl is the lowest part of the whole fuel
system. As to whether or not Lynn's filters are susceptible to fracture I'm
sure the manufacturers have done studies on it.
Noel
Kitfox III-A
Jimz
Posted: Thu Mar 11, 2010 8:29 pm Post subject: Northstar problems |
Correct. It now has a rubber hose around the drain, like a piece of radiator
hose, and a hole in the fuselage to drain the fuel. There is an aluminum
piece that goes in the end of the hose and you fabric over it. It all came
with my kit. My Champ had a glass bowl like the Cubs and it cracked. I
replaced it with an all metal one.
Fox5flyer Guest
Posted: Fri Mar 12, 2010 5:20 am Post subject: Northstar problems |
Yup, correcto, Lynn. I replaced it with a 2-gallon aluminum tank with an
even bigger sump and bottom drain.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 438+ TT
Previously Model 2 582 400 Hrs
"If you put the federal government in charge of the Sahara
Desert, in five years there'd be a shortage of sand."
-- Nobel prize-winning economist Milton Friedman (1912-2006)
| Quote: | I think that's what Jim was pointing out, Noel. If you look at the
drain....underneath the header tank. I think Jim just hasn't got around
to cutting the fabric at that point...or am I full of it again, Jim? : )
Aren't the present tanks equipped with the bottom drain? Mine is, and I
Lynn Matteson
> You need an access port on the bottom of the fuse to take samples from
> your header. A nice addition on future header tanks would be for the
> Noel
> To: kitfox-list(at)matronics.com
> Jim Series 5 0-200
> 21D MN
> contribution_-
akflyer
Posted: Fri Mar 12, 2010 4:21 pm Post subject: Re: Northstar problems |
| Float Flyr wrote: | Those glass bowls were pretty hefty and hard as nails... I expect it was
Noel
no, it was the glass. I have not seen any glass that would not break and the aluminum housing would. Last time I checked, the metal was alot tougher than the glass.
When I stuffed the pacer (short wing piper death trap for some of you out there ) in, the glass shattered on it, but I was fortunate enough that it did not ignite.
easy test, go smack one with a hammer and tell me if the glass shatters or the metal housing fails.
Lynn is probably right in thinking that if his break, he probably wont be in any shape to scream, or worry about the ensuing flames.
FWIW, I have plastic see through filters on mine with the rounded barbs and they have not given me any trouble. one started to plug off, but I knew it right away as my fuel flow was running lower than it should have been on my flow meter. I kicked on the electric back up pump and set it down in short order and swapped it (I carry 2 spares).
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
