				 Posted: Tue Mar 16, 2010 11:09 am    Post subject: Squeeze Bulb Safety & Positive Pressure Prime |
				FireFlyer's,
 Put up a couple of pages that might be of interest.  The first shows a
 method of how to safety a fuel squeeze bulb while saving some weight and at
 the same time simplifying the fuel system.
 It can be seen at:
 http://jackbhart.com/firefly/firefly157.html
 The second shows a method for getting rid of the squeeze bulb all together
 providing additional weight savings and system simplification.  Herb gave me
 the idea.
 It can be seen at:
 http://jackbhart.com/firefly/firefly157a.html
 These methods were investigated while trying to figure out how to get fuel
 to the Tillotson carburetor on the MZ 34. Turns out that neither of them
 will work, but they will with the Bing.  And each will save a little
 weight.
 Clouds and rain have moved in.  Snow is gone.  Wings are back on the FireFly.
 Jack B. Hart FF004
 Winchester, IN
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		lcottrell
				 Posted: Tue Mar 16, 2010 2:00 pm    Post subject: Squeeze Bulb Safety & Positive Pressure Prime |
				Very interesting Jack, However I have a much more  effective way to reduce the weight of my airplane, so far I have cut 20 pounds  off my Firestar's flying weight, and if my resolve holds out I may loose another  10 pounds off it. Saves on food money too.
  Larry C
  Note: If you forward this email, please delete the forwarding history,  which includes my email address.
  [quote]   ---
				 Posted: Tue Mar 16, 2010 3:43 pm    Post subject: Squeeze Bulb Safety & Positive Pressure Prime |
				FireFlyer's,             #2
 It can be seen at:
 the idea.
 It can be seen at:
 weight.
 Jack B. Hart FF004
 Winchester, IN
		Dana
				 Posted: Tue Mar 16, 2010 5:12 pm    Post subject: Squeeze Bulb Safety & Positive Pressure Prime |
				At 11:08 AM 3/16/2010, Jack B. Hart wrote:
   	  | Quote: | 	 		  --> Kolb-List message posted by: "Jack B. Hart" <jbhart(at)onlyinternet.net>
  It can be seen at:
  http://jackbhart.com/firefly/firefly157.html |
  Problem is, it doesn't prevent a leaky bulb or stuck check valve... the latter nearly cost me my plane on my first flight in it.
  In the end I ditched the bulb and installed a plunger primer.
  -Dana
   If God took acid, would He see people?    [quote][b]
		Eugene Zimmerman
				 Posted: Wed Mar 17, 2010 1:56 am    Post subject: Squeeze Bulb Safety & Positive Pressure Prime |
				I've tried numerous plunger type primers with mixed results but ultimately they all eventually leaked or stuck.I finally settled on the button type primer which simply works with no leaks and weighs almost nothing and lasts longer for me than any plunger type that I have tried.
 Here is a link for the button type I use.
 http://www.jackofmosttrades.com/Rotax_Parts/Primer_Plunger_Button/primer_plunger_button.html
 Gene Z
 On Mar 16, 2010, at 7:59 PM, Dana Hague wrote:
 [quote]At 11:08 AM 3/16/2010, Jack B. Hart wrote:
   	  | Quote: | 	 		  --> Kolb-List message posted by: "Jack B. Hart" <jbhart(at)onlyinternet.net (jbhart(at)onlyinternet.net)>
  It can be seen at:
  -Dana
   If God took acid, would He see people?  	  | Quote: |
  | 	  [b]
		rickofudall
				 Posted: Wed Mar 17, 2010 2:51 am    Post subject: Squeeze Bulb Safety & Positive Pressure Prime |
				Jack, all, I probably missed this as your work is always very thorough, but how do you pressurize a vented tank?
 Rick Girard
 On Tue, Mar 16, 2010 at 9:10 PM, Eugene Zimmerman <etzimm(at)gmail.com (etzimm(at)gmail.com)> wrote:
  [quote]I've tried numerous plunger type primers with mixed results but ultimately they all eventually leaked or stuck. I finally settled on the button type primer which simply works with no leaks and weighs almost nothing and lasts longer for me than any plunger type that I have tried.
 Gene Z
  It can be seen at:
  -Dana
 tp://forums.matronics.com
		Dana
				 Posted: Wed Mar 17, 2010 3:57 am    Post subject: Squeeze Bulb Safety & Positive Pressure Prime |
				That's the one I was talking about.  Works great, and if you tee it off the fuel line near the carburetor, it will draw fuel up from the tank and fill an empty fuel line.
  -Dana
  At 10:10 PM 3/16/2010, Eugene Zimmerman wrote:
   1.  Programmers are expensive.
  2.  Press releases are cheap.
  3.  Therefore, it's cheaper to explain the bug than to fix it.    [quote][b]
				 Posted: Wed Mar 17, 2010 4:18 am    Post subject: Squeeze Bulb Safety & Positive Pressure Prime |
				Date: Wed, 17 Mar 2010 05:28:55 -0500
 Rick,
 Once the bicycle pump is removed, the tire valve stem installed in the tank
 acts as the vent.  Any previous vent must be plugged.
 Jack B. Hart FF004
 Winchester, IN
		herbgh(at)nctc.com Guest
				 Posted: Wed Mar 17, 2010 6:12 am    Post subject: Squeeze Bulb Safety & Positive Pressure Prime |
				My Version has a squeeze bulb plumbed into the top tank using a
 schrader valve with the internals taken out....to fill the float
 bowl, I just place my finger over the vent hole and squeeze the
 bulb... Easy to do on a full tank but a bit tedious on a partially
 full tank... Simple enough...
    Jack has me thinking about taking along  a tool kit, bicycle pump
 , tie downs etc..for those times when I venture off the beaten path...Herb
 At 07:13 AM 3/17/2010, you wrote:
 Rick,
 Jack B. Hart FF004
 Winchester, IN
		Vic Peters
  Joined: 30 Oct 2009 Posts: 54 Location: Millinocket, Maine
				 Posted: Wed Mar 17, 2010 6:38 am    Post subject: Squeeze Bulb Safety & Positive Pressure Prime |
				My plunger primer ($20) worked great for a  while then leaked after just a few hrs.
  I deconstructed it and was amazed at what a piece  of crap it was.
  Imo your just playing with fire, pun  intended.
  Use of a used certified one would be much  safer.
  I'm going back to a fuel pump.
  Vic
  Xtra 912ul
  _________________ Vic
912ul Xtra
Maine
Too old to cut the mustard but not the cheese. |
				 Posted: Wed Mar 17, 2010 7:23 am    Post subject: Squeeze Bulb Safety & Positive Pressure Prime |
 Date: Tue, 16 Mar 2010 13:51:16 -0600
 Larry,
 I applaud your efforts to keep the G-loading of your aircraft to the
 minimum, and to keep the pilot trim and fit.
 Jack B. Hart FF004
 Winchester, IN
