rashvac(at)earthlink.net Guest
Posted: Sun Mar 21, 2010 12:18 pm Post subject: Holes left open |
My QB did not have these holes dimpled or countersunk does this cause a problem when finishing?
Can I machine countersink the skins with the longerons riveted?
Russell Shavitz
Shavitz Heating & Air Conditioning
4849 Main Street, Skokie, IL 60077
office: 847-678-1000
cell: 847-417-6622
www.shavitz.com
rv10rob(at)gmail.com Guest
Posted: Sun Mar 21, 2010 8:53 pm Post subject: Holes left open |
You definitely want to call Van's (if for nothing else, to notify them of the error). I don't see how you have much of a choice but to countersink them now.
-Rob
On Sun, Mar 21, 2010 at 1:15 PM, Russell Shavitz <rashvac(at)earthlink.net (rashvac(at)earthlink.net)> wrote:
| Quote: | --> RV10-List message posted by: Russell Shavitz <rashvac(at)earthlink.net (rashvac(at)earthlink.net)>
Russell Shavitz
cell: 847-417-6622
www.sh==================
Browse, Chat, FAQ,
="http://www.matronics.com/Navigator?RV10-List" target="_blank">http://====
http://forums.mle, List Admin.
Rob Kochman
RV-10 "Finishing" Kit
Woodinville, WA (near Seattle)
http://kochman.net/N819K
effectus(at)rogers.com Guest
Posted: Mon Mar 22, 2010 2:19 am Post subject: Holes left open |
There is a set of dimple dies that you can get that go in your rivet tool. They work like a pulled rivet.
A pin is put through the center of the back side die and then put through the hole. The front die is put over the pin and then you put the hand rivet pulling tool over the pin.
You then carefully squeeze the two dies together.
This gives you a pretty good dimple that might require s clean up with the counter sink.
Dave Hertner
Sent from my BlackBerry device on the Rogers Wireless Network
Kelly McMullen
Posted: Mon Mar 22, 2010 5:18 am Post subject: Holes left open |
While the pop-rivet dimple die set works well in hard to reach areas,
it is not likely to do much where the layer underneath is a longeron
angle. Had to use the pop-rivet dies on the bottom skin of QB fuse for
the six holes or so on each stiffener at the rear before joining
tailcone.
On Mon, Mar 22, 2010 at 4:10 AM, <effectus(at)rogers.com> wrote:
| Quote: | There is a set of dimple dies that you can get that go in your rivet tool.
counter sink.
Dave Hertner
Date: Sun, 21 Mar 2010 21:27:39 -0700
Subject: Re: Holes left open
You definitely want to call Van's (if for nothing else, to notify = them of
the error).=A0 I don't see how you have much of a choice but to= countersink
them now.
=A0
-Rob
On Sun, Mar 21, 2010 at 1:15 PM, Russell Shavitz= <rashvac(at)ear= thlink.net>
wrote:
--> RV10-List message posted = by: Russell Shavitz <rashvac(at)ea= rthlink.net>
My QB did not have these holes dimpled or countersunk does this cause a=
Can I machine countersink the skins with the lo= ngerons riveted?
Russell Shavitz
Shavitz Heating & Air Condit= ioning
office: =A0847-678-1000
cell: =A08= 47-417-6622
www.sh= =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
Browse, Chat, FAQ,
=3D"http://www.matronics.com/Navigator?RV10-List" target=3D"_blank">http://=
=3D=3D=3D=3D
http://forums.m= le, List Admin.
=3D=3D=3D=3D=3D
Rob Kochman
RV-10 "Finishing" Kit=
= http://kochman.net/N819K
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Mon Mar 22, 2010 8:27 am Post subject: Holes left open |
Sorry about that! I didn't look closely enough at the location of the problem.
Dave
