				 Posted: Mon Mar 22, 2010 11:23 am    Post subject: No Title |
				At 01:00 PM 5/22/2010, you wrote:
 Hi all,
 I would like to ask your comments regarding a reoccurring problem that I am
 having in my RV7. I have wired it according to Z11 with the additional
 projection for internally regulated ND alternator as suggested by the
 connection. I have had now three alternator failures in short order, each
 time I have taken out the alternator and had it checked out at the shop,
 twice they found a faulty diode and the third time the alternator checked
 out ok, no fault found. I have exchanged the alternator contactor and have
 checked all wires and fuses, they all check out ok.
 I am wondering how I could check the system to see if I can find any
 problems with it. Any suggestions are appreciated
      Start by by-passing the OV protection system. Just
      move the alternator b-lead wire to the other side
      of the disconnect contactor so that the b-lead
      is always hooked to the system.
      If you're still in possession of the third, no-fault
      found device, run it in that configuration for the
      time being and see if things settle down.
      How did you first become aware of the failure?
      How did the failure manifest? Low voltage, over voltage?
      Did you turn the alternator OFF while the engine
      was running and the alternator was under load?
