		Z601c(at)anemicaardvark.c Guest
				 Posted: Tue Mar 23, 2010 2:41 pm    Post subject: CHris Heintz' book |
				I received a review copy of Chris Heintz new book, which is entitled something
 like "Flying Your Own WIngs." I'll post a review here as soon as I get a
 chance to read it.
                                        Jim B. Belcher
                                        BS,MS Physics
                                             A&P/IA
                       General Radio Telephone Certificate
                                Instrument Rated Pilot
                      Retired Aerospace Technical Manager
                          Semi-proficient Househusband
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Wed Mar 24, 2010 7:49 am    Post subject: CHris Heintz' book |
				I said I'd publish a review of this book as soon as I read it. I spent quite a
 bit of time with it last night. I've posted a review on Mr. Heintz website
 (www.flyingonyourownwings.com), and on Barnes and Noble, per their request.
 I don't believe humans write perfect books, and I've tried my best to give
 this book an honest review. I like it, and I recommend it, but as you will
 see, I think it could be made better.
 Chris Heintz' book, Flying on You Own Wings, is subtitled: “A Complete Guide
 to Understanding Light Airplane Design.” The subtitle is a very accurate
 description of the book's contents. I'm going to first tell you my basis for
 review, and what I believe is good about the book. I'll then tell you what I
 believe could be improved.
 I won't hide my conclusion from you, or make you wait until the end of the
 review. Your wife has been hiding money in the sugar bowl so she can buy a
 second dress. Wait until she is fast asleep, sneak out $39.95, and buy the
 book. Who needs a second dress? You need this book.
 His first chapter, Mathematics, is a review of freshman and perhaps sophomore
 level college math, and physical symbology. Those already possessing this
 information could easily skip over this chapter and the following chapter.
 However, I feel it and the second chapter on units would help introduce many
 to these subjects, and provide a generally good basic grounding. In fact, I
 intend to buy a copy of this book, and provide it to our son, who is a first
 year engineering student, trying to come to grips with where all this math
 came from, and what it really means.
 Mr. Heintz hits his stride in the third chapter on aerodynamics and air loads,
 followed by chapters on structural stress analysis, and human factors.
 Although his approach provides reasonably rigorous mathematical backup, it is
 common sense, and has real world examples.
 He concludes with chapters on a sample design, and flight testing.
 I can't absorb all this book at a single reading period. It's going to take
 days or weeks to think some of this through. I am confident that this book will
 provide me with background missing in many areas. It's certain I will have a
 much better understanding of aircraft design when I finish.
 You should be aware that the reviewer holds degrees in physics, with minors in
 math and computer science. What I consider common knowledge may not be common
 to everyone, and you should adjust the opinions I express accordingly.
 Conversely, some of you may have much more knowledge than I, and find the book
 too basic.
 Now for the down side of things. First, it's clear the author's primary
 language is not English. This results in occasional odd turns of phrase which
 may hinder the readability of the book. Engineers are not known for being the
 best communicators, and don't always break things up into short, manageable
 segments. This book is no exception: it appears to badly need a technical
 editor. It's far, far, too pedantic. But so are a lot of technical books.
 The lot of the author of a  book on a technical subject is a challenging one.
 If the book is too technical, it becomes turgid, and difficult to read, even for
 those knowledgable in the field. If the author writes on too broad a level,
 some of the technical content is lost.
 It's even worse when math is involved. Mathematicians are less concerned about
 the real world value of their work than its theoretical value. Those of us in
 the real world must pick our way very carefully through a mine field, selecting
 those areas of math which have physical meaning, and those which do not.
 Unfortunately, it's too easy to dismiss something of value in another
 discipline, which is meaningless in our own. That's an error Mr. Heintz has
 made.
 An example of this is on page 32, where imaginary numbers are dismissed.
 Students of engineering and science need to be aware that these numbers have
 real physical meaning in some fields. There really are things that work this
 way.  Where there is one error of this type, there are likely to be others.
 Study this book carefully, and focus on the aircraft design portions.
 I agree with his premise that the metric system is easier to use in most
 engineering calculations. But I wonder why, in a book whose largest audience
 is likely to be in the United States, this system was used. Maybe I
 underestimate the ability of aircraft builders, but those I know don't use the
 metric system, and most rather frown on its usage. Perhaps one purpose of the
 book is to educate on the use of the metric system, or to promote it.
 I think it might have been more accurate to introduce the subject by saying
 that calculations are more readily done in the metric system. For this reason,
 the book is written around that system, to make the calculations easier to
 understand. I do most of my own calculations in the metric system, but convert
 the results to a more familiar form, because most materials available to me
 only come in feet, pounds, and inches.
 Some of the philosophy strikes the mark very well. For example, an aircraft
 should not only perform well, it should be handsome in appearance. But some of
 the philosophy is very cryptic, and I have no idea what its intent may have
 been.
 Unfortunately, some of the philosophy borders on metaphysics, and would put
 Shirley McClaine to shame. On page 51, there is speculation that the number of
 calendar years in a sidereal year are the approximately the same as the number
 of breaths a human takes in in one day. This is hardly a causual relationship,
 and included in a book on light aircraft design, throws the technical
 credibility into question. If I breathe more slowly, does the universe slow
 down?
 More of this appears on page 53, where Mr. Heintz observes “Note: Although the
 gravitational pull of planets does not affect aircraft design, its action on
 the life forces (plants, animals, humans) and soul forces (animals and humans)
 is not much recognized in our western culture. Some cultures are more attuned
 to this....”
 First, if it has nothing to do with aircraft design, why is it here? Second,
 it's possible to find a lot of cultures with some pretty strange ideas, but
 that doesn't make them correct. The book needs to be more focused.
 Do not take this criticism as damming the book with faint praise. It's a good
 book, and, if you want to understand aircraft design, well worth studying. In
 fairness, the answer to many of these issues is that children should not read
 books written for adults. When you read Mr. Heintz' book, you should simply be
 mature enough to recognize his rather unique outlook. Absorb the parts about
 aircraft design, and filter out some of the rest.
 This is a good book, and worth studying (reading is too light a word).  My
 regret is that what is now a good book could have been an excellent book with
 the services of a good technical editor.
                                        Jim B. Belcher
                                        BS,MS Physics
                                             A&P/IA
		n801bh(at)netzero.com Guest
				 Posted: Wed Mar 24, 2010 8:59 am    Post subject: CHris Heintz' book |
				I am living proof that Chris designs a strong airframe... <<GG>>
 But this statement flys in the face of reality...
 been.
 After all , he did design the 801 and its 'less then handsome' looks. <G>
 Thanks for the write up though, I will one day get the book and read it.
 Ben Haas
 N801BH
 www.haaspowerair.com
		psm(at)att.net Guest
				 Posted: Wed Mar 24, 2010 9:27 am    Post subject: CHris Heintz' book |
				Hi Jim,
 Thank you for the great review of Chris' book.  My immediate reaction was to order a copy from Amazon.com.
 The biggest reason I did that was one small comment you made about Chris nixing imaginary numbers.  I did the same thing in my career as an electrical engineer.  You see -- My education is in mathematics.  All of mathematics is based on 4 axioms.  To get imaginary numbers to work you need to add a 5th axiom (that i-squared is equal to -1).  This is totally unacceptable from a philosophical point of view.  In my opinion it invalidates all the math used after making this outrageous change to the rules.  (There is a reason they are called imaginary.)
 I am still very angry over my experience with the Zodiac XL and the business conducted by ZAC/Zenair.  Still, my original reason for selecting this design was Chris' reputation for design of this type of aircraft.  I really look forward to reading his thoughts on airplane design.
 Paul
 XL - installing upgrade kit
		kmccune
  Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
				 Posted: Wed Mar 24, 2010 2:36 pm    Post subject: Re: CHris Heintz' book |
				Ben,
 I for one, hold to the beauty of function over form! And the 701/750 and 801 are beautiful technical designs!
 Sorry couldn't resist.
 Kevin
  	  | n801bh(at)netzero.com wrote: | 	 		  I am living proof that Chris designs a strong airframe... <<GG>>
 been.
 Ben Haas
 N801BH
  _________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy  McCune |
