dpark748(at)hotmail.co.uk Guest
Posted: Fri Mar 26, 2010 1:44 pm Post subject: Antenna tuning |
I have just borrowed an SWR meter and am trying to tune my Comm antenna. The manual says to tune by shortening until minimum reading at 127.50 I am getting Minimum reading at 133.00. My last two cuts of 3mm have not moved the minimum reading 1.5 at 133.00 above and below this frequency the readings are at 1.9 -1.9.
Do I keep shortening the antenna????
Any ideas? Regards Dave Park G-LDVO
jimpuglise(at)comcast.net Guest
Posted: Fri Mar 26, 2010 1:59 pm Post subject: Antenna tuning |
David-
I assume you are talking about the copper strip antenna that comes with the kit. My own approach is to start at the bottom of the band and record the SWR every 50 khz. After you have done this, put the figures in Excel and graph it. Each line in your Excel spreadsheet shoud have one frequency in column A and the SWR at that frequency in column B. In this way, you can see what the antenna is doing through the entire band. You need to be concerned that the SWR is not extremely high at one end and extremely low at the other. I usually shoot for 1.0-1.2 / 1 at the center and 1.9 or so at each band edge. If you are at 1.5 in the middle of the band, that should be just fine. The reason you are not seeing change with small adjustments is that it is probably relatively flat a few MHZ each side of resonance. Also, I don't know if you are using the coax that comes with the kit, but I took one look at it and threw it away. Invest in some good RG-58 for the comm antenna and some RG-400 for the transponder. When you look at the graph, it will be very obvious what you need to do.
Jim Puglise A-283
Posted: Fri Mar 26, 2010 2:13 pm Post subject: Antenna tuning |
Jim,
Thanks for that, yes I did use the coax that came with the kit - major job to change that now - unless it is worth making a connection in the tail area to the kit coax with RG58??
I am just a bit concerned that if I keep cutting to achieve 1,5 at 127.5, presently 133.0 I might bxxxxx it up compleyely!
Dave
Date: Fri, 26 Mar 2010 21:59:15 +0000
Subject: Re: Antenna tuning
.ExternalClass p {;} David-
Jim Puglise A-283
gregoryf.flyboy(at)comcas Guest
Posted: Fri Mar 26, 2010 7:10 pm Post subject: Antenna tuning |
Dave,
Unless I am suffering from temporary dyslexia, I think you would need to lengthen your antenna at this point, to get the SWR reading to come down in frequency from a low reading at 133Mhz, since 133Mhz has a smaller wavelength than 127.5 Mhz
regards,
Greg Fuchs XS Tri
Posted: Fri Mar 26, 2010 8:01 pm Post subject: Antenna tuning |
Dave-
Shortening the antenna raises the resonant frequency, lengtlhening it decreases it. No, if it is a hassle, it would not be worth changing the cable. If you do the graph, you will get a better picture of just where you are.
Jim
Bill & Sue
Joined: 10 Jan 2006 Posts: 48 Location: Malvern, Worcs. UK (Defford, Croft Farm)
Posted: Sun Mar 28, 2010 2:21 am Post subject: Re: Antenna tuning |
Dave,
If you are anywhere near me (Aylesbury, so must be closer than Ferg!)) I'm happy to turn out and provide some hands-on help if you think that would be useful. I suffer from the delusion that I know a little about antennas (antennae?) and I have a couple of suitable SWR meters and some practical experience messing about with this sort of antenna. Please give me a call on 01296 689165 if you think that would be any use or you just want some telephone advice.
Bill
Posted: Sun Mar 28, 2010 3:34 am Post subject: Antenna tuning |
Bill,
Thanks for the offer but I am in South Manchester, nr airport!. But I may ring you when I am next in the garage. Originally with the length at 490mm as per drawing the best SWR was at 133.00. I shrortened it down to 480mm but could not get best SWR mid frequency range. I have temporarly extended the antenna to try again.
Regards Dave
[quote] Subject: Re: Antenna tuning
Date: Sun, 28 Mar 2010 03:21:15 -0700
--> Europa-List message posted by: "Bill & Sue" <Billandsue(at)billbell.co.uk>
David,
Bill
http://forums.matronics.com/viewtopic.php?p=292045#292045
Posted: Sun Mar 28, 2010 5:22 am Post subject: Antenna tuning |
David-
I think you have been trimming your copper tape in millimeters. I did a couple of calculations this morning and you change resonant frequency is about .38 inches (around 10 mm) per mhz. So--if you have been trimming your foil at 2 mm per check, you would need to trim it 5 times to move it 1 mhz. If you do your graph, you should be able to calculate very closely how you need to trim it and do it with a single cut.
Jim Puglise A-283
Posted: Sun Mar 28, 2010 3:42 pm Post subject: Antenna tuning |
Bill, Jim,
Out of interest what kind of length did you both end up with??
Dave
Date: Sun, 28 Mar 2010 13:18:44 +0000
Subject: Re: Re: Antenna tuning
David-
Jim Puglise A-283
Posted: Sun Mar 28, 2010 5:10 pm Post subject: Antenna tuning |
Dave-
Sorry, I can't tell you. It calculates to 43 inches, but I canabalized the included antenna and cut it for the amateur 2 meter band. It is installed just aft of the "D" panel and cut for 146 MHZ. I used a commercial (AAE) antenna for my comm. It gets a touch technical, but the AAE antenna is what is called a folded dipole, so it is about twice the bandwidth of a conventional dipole. If you attempt to trim it, it will destroy it, so you just put it in and away you go. I am at 1/1 in the center of the band and about 1.3 / 1 at the edges with it. If you want to spend the money, the AAE antenna is a great choice. I also used one of theirs for my transponder. It is a flat tape, about 1.5 inches wide and glues to the stern post beautifully. It has a built in balun, so all you do is attach your coaxial cable and glue it in. No tuning or trimming.
Jim
Bill & Sue
Posted: Mon Mar 29, 2010 4:24 am Post subject: Re: Antenna tuning |
Dave,
I'm afraid I can't help much with the length either as I haven't put the antenna in our our Europa yet ( I should be filling right now!) and anyway I ignored the Europa design (not that there is anything wrong with it) and made an aerial of my own design for fun -it came out well, but won't help in sizing your antenna.
I agree with Jim, the length quoted sounds a bit short- I would have expected about 55cm per leg, less a bit for the dielectric effects of mounting it on fibreglass. So maybe the final length in the book is about right, but I would be inclined to start a bit longer and cut to size.
The suggestion of drawing a graph is a good one to allow you to visualise where you are starting from.
One piece of reassurance- you can mess with the length all you like and it is very hard indeed to damage anything (a bit like fibreglass you can stick another bit on and have second crack at cutting it to size!) and, although it is nice to get it just so, small errors in the end result are likely to be unnoticeable in practice.
PS Hi Jim, we met in NZ but I didn't realise you were a Ham too- small world!
Fergus Kyle
Joined: 03 Jun 2007 Posts: 291 Location: Burlington ON Canada
Posted: Mon Mar 29, 2010 12:01 pm Post subject: Antenna Tuning |
Cheers,
I might mention something while tuning an antenna which might make some difference. Normally an antenna up and clear will reflect the qualities desired. But at our freqs, it’s important to ensure that nothing resembling a nearby freq exists within about a ˝ to 5/8 wavelength ( a bit less) – say 300/127 m or something less than 1.5m. All this depends on orientation etc, so if a UHF or higher ferq is off the end of your tailplane dipole, not much loss of a spherical power plot. BUT if you insert a Ľ-wave vertical in the plane of the diploe within a meter or so, expect the pattern of the latter’s power plot to be skewed and it won’t radiate spherically – that is pieces of the pattern will be missing power (maybe straight ahead and you have to turn the a/c 30 degrees to get the tower ahead to pay attention). High is assumed but clear is also needed.
Nuff sed.
ferg [quote][b]
Posted: Mon Mar 29, 2010 1:45 pm Post subject: Antenna tuning |
On 03/26/2010 10:43 PM, david park wrote:
| Quote: | I have just borrowed an SWR meter and am trying to tune my Comm
127.50
Well, somewhat contrary to what others tell you, I wouldn't make a big
deal out of it. You just need to verify that the SWR is no higher than
2.5 anywhere in the frequency spectrum you intent to use. No need to
make a graph in my opinion, just dial through the band, transmit on
every 100kHz to verify that the SWR is acceptable.
HAM's usually strive to perfection, but you aren't going to moon-bounce,
DX, trying to reach the other end of the world with 1 milliwatt, or
working with satellites.
You have 10 Watts or so to spoil, have a very short cable in comparison
to HAM-stations, are transmitting from a height HAM's usually can only
dream upon, and without obstacles in your transmission path.
You won't notice any SWR improvement from 1:2.5 to 1:1, even with a
lossy cable. Just relax.
BTW, I'm a HAM myself.
The real challenge in airplanes is to keep the interference between
avionics and your signal as minimal as possible, so spend your time on
that, rather than chasing the perfect SWR.
Just my 2 cents.
Frans
Fergus Kyle
Posted: Tue Mar 30, 2010 4:55 pm Post subject: Antenna Tuning |
Sorry, the formula didn’t erase – please ignore 300/127m
Tnx
Ferg [quote][b]
graeme bird
Posted: Sun Mar 06, 2011 2:01 pm Post subject: Re: Antenna tuning - toriods |
Interesting and relevant stuff to me - but, the ferrite's in the manual from Phillips are now obsolete, does anyone know what can be used instead. Are they critical for matching the dipole to the 50ohm cable transceiver as a balun or is it just ballast/supression at the cable end?
Thanks Graeme
_________________ Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk |
Posted: Sun Mar 06, 2011 2:36 pm Post subject: Antenna tuning |
Ferg Kyle might know?
Graham
Sent: Sunday, 6 March, 2011 22:01:09
--> Europa-List message posted by: "graeme bird" <graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk)>
Thanks Graeme
Graeme Bird
G-UMPY
Mono Classic/XS FWFD 912ULS/Warp drive FP
Build nearing completion
http://forums.matronics.com/viewtopic.php?p=332935#332935
Navigator?Europa-List" target="_blank">http://www.matronics.com/Navigatorsp; - MATRONICS WEB FORUMS -
jrgowing(at)bigpond.net.a Guest
Posted: Sun Mar 06, 2011 3:15 pm Post subject: Antenna tuning |
Graham
I hope the ferrites are not obsolete!
I build mine in about 7 years ago and haven’t used the antenna yet!
Maybe they just have something smaller or easier to use?
JR (Bob) Gowing UK Kit 327 in Oz
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of GRAHAM SINGLETON
Sent: Monday, 7 March 2011 9:30 AM
Graham
Thanks Graeme
Graeme Bird
G-UMPY
012345678
Checked by AVG - www.avg.com
Version: 10.0.1204 / 03/06/11
g-iani(at)ntlworld.com Guest
Posted: Mon Mar 07, 2011 5:39 am Post subject: Antenna tuning |
Graeme
I am not a radio expert but from what I have been told the ferrite rings are
needed for impedance matching (ie they are the balum).
Ian Rickard G-IANI XS Trigear, 300hours
Europa Club Mods Specialist
e-mail g-iani(at)ntlworld.com
Posted: Tue Mar 08, 2011 12:42 am Post subject: Antenna tuning |
On 03/07/2011 02:34 PM, G-IANI wrote:
| Quote: | I am not a radio expert but from what I have been told the ferrite rings are
The ferrite rings are not for impedance matching but to convert the
asymmetric signal (one center wire against an outer sleeve) in a
symmetrical one (the two legs of the dipole antenna).
Without such a conversion, the electrons can not really see the
difference between the sleeve of the coax cable and the leg of the
dipole antenna. They get confused, turn the wrong way, and radiate off
the cable instead of radiating from the dipole leg.
In this situation, it is more difficult to obtain a good and stable SWR.
Furthermore, as the sleeve of the coax cable starts radiating, you
induce more interferences in the avionics while transmitting, and
receive more noise from within the ship while receiving.
Ferrite rings are a way to "filter" the electrons. Slow moving electrons
can pass, but electrons in the mood for radiating can not, and can only
stay within the antenna. Be warned though that ferrite rings come in all
kind of flavours, if you pick a random ring from a catalog you will most
likely get one that is not efficient on the VHF frequencies we are using.
There are other ways to obtain the same result. You can coil up the coax
immediately behind the antenna connection, or create a so called
"balun". (Google on "balun" and "dipole" to find the formula how to
create such a contraption).
I have ferrite rings near the antenna connection, AND a coil in the tail
of the ship. I believe that this double measures are needed because it
is impossible to route the coax cable sufficiently far away in a 90
degree angle from the antenna, so it picks up some of the radiation from
the antenna again on the other end of the ferrite rings. The coil
further upstream takes care of this, making sure the cable is completely
"dead" between the radio and the tail of the ship.
As a result, I never have had any interference problems between the
transceiver and the rest of the avionics. Even the three strobes, fed
from a central power supply, have no influence at all at reception.
Frans
graeme bird
Posted: Tue Mar 08, 2011 10:00 am Post subject: Re: Antenna tuning |
Thanks for that, I guessed that was the case, I selected toroids that are effective in the 130Mhz range.
kit4 (Wagstaff) TBD
