Tdawson(at)avidyne.com Guest
Posted: Tue Apr 18, 2006 6:27 am Post subject: Cowl fasteners |
Where are people coming down on the decision of sticking with Van's cowl
"hinge" design, or going with Cam-lok type cowl fasteners?
Of the flying folks, anyone like to comment on the ease of use of the
hinge fastener design?
TDT
40025
flysrv10(at)gmail.com Guest
Posted: Tue Apr 18, 2006 6:55 am Post subject: Cowl fasteners |
I have had the hinges on my RV6 for 12 years, I would not trade them
with Cam-loks. The installation and operation of the hinges for RV10
is even easier due to the larger diameter cowl.
Do not archive.
On 4/18/06, Tim Dawson-Townsend <Tdawson(at)avidyne.com> wrote:
TDT
40025
Tim(at)MyRV10.com Guest
Posted: Tue Apr 18, 2006 7:23 am Post subject: Cowl fasteners |
I was originally a big proponent of the concept of switching
to Camloc's. I didn't, because that would have slowed down
my build while trying to figure out exactly how I wanted to
do it, using the skybolt set, or smaller ones, and how many
and for how much cost. They aren't cheap, but they are
convenient.
Now that I've had my cowl on and off a few times, I can comment
better on the hinges though.
I'm very surprised at how easy it is to deal with the hinges.
The top ones you just loosen the holding bracket and pull
the pins, very quick. The horizontal ones are a simple
straight-in and out, very easy. The bottom cowl side pins
are also pretty simple. I did NOT go with lower pins,
but used nutplates and screws due to a large number of comments
on other RV's about how the eyelits wear on the hinges.
I'm glad I went the route I did for future issues.
So the cowl is very easy to remove and re-install, in regards
to the hinge pins. I do get a little black streaking coming
out my cowl seam from the aluminum of the hinges. I don't
know that it will get better, or worse, over time, but I'm
sure there will eventually be more play in the hinges. Long-term
I can see the hinges possibly being an issue for wear, and
replacing them might not be fun, and would maybe require a
cowl repaint. But I think it would be a long time to get
to that point of wear.
As far as the cowl going on and off, the lower cowl is
a real pain. There isn't much clearance to get it up and down,
with the spinner installed, and the FAB/inlet stuff isn't fun to
align and keeps the cowl from going on smoothly. It's a hard
job to do the lower cowl alone without banging things up....I
just did it yesterday. The top one is simple. I did
just change oil again too, with the lower cowl on. You have
to protect your hands from the hot crankcase and exhaust, but
it's definitely do-able with a quick-disconnect. I got a set
from ACS that had the valve and a matching latch-on hose
that works really well, and was pretty cheap I think.
For those deciding on props, you may have noticed the post
today regarding the 3 blade aerocomposite prop and it being
hard to remove and replace the lower cowl. I personally
haven't done a 3-blade, but I can definitely see the
issue. Even with my 2-blade, I have to make sure my
blades are horizontal or it can be a bear getting the cowl
off and on again. I can't even imagine how it would
be with 3 blades, although I'm sure it's something
that 3-blade owners will manage fine. I'm betting that
if 3-blade owners gave an honest statement, they'd
say that cowl removal sucks, but they love the prop. I'd
be suspicious if someone just says "no problem, easy"...
just call a spade a spade....doesn't mean the prop, or
the choice in props was bad. Just means there's a little
more story to go along with it.
So all in all, I'm more happy with the hinges than I
thought I'd be, although I recognize that some day
I might have to repaint the cowl after a hinge repair.
The cowl definitely looks the best with hinges, but
camlocs aren't awful looking either...just don't
try to paint them.
Tim Dawson-Townsend wrote:
TDT
40025
Jack.Phillips(at)cardinal Guest
Posted: Tue Apr 18, 2006 7:42 am Post subject: Cowl fasteners |
I haven't yet started on my RV-10, but I can add to what Tim said about
the hinges. My RV-4 has the same type of cowling design, with piano
hinges. It has been flying since 1989 and the hinges have not shown any
appreciable wear. I concur with Tim that the bottom cowl is a real pain
to install by yourself, but with help it is not too bad. Unfortunately,
with the cheek cowls of the RV-4, it is not an option to leave the lower
cowl in place for oil changes - just not enough room to work.
Jack Phillips
Raleigh, NC
jesse(at)itecusa.org Guest
Posted: Tue Apr 18, 2006 7:48 am Post subject: Cowl fasteners |
I second almost all of this. We put in nutplates and screw on the top cowl.
While it is simple and anybody can figure out how to do it easily, it is a
pain in the neck to take off all those screws. I think it looks kind of
cool with all of the SS screws and counter sunk washers, but it would look
cool with nothing too. We use the pins on the lower cowl and wouldn't
change that. On this one we are going pins just like the plans say, the
whole way. The bottom cowl is a bear and a half to get off, especially with
the front gear leg fairing installed. We should have left more of a gap
between the baffles and the cowl and possibly between the airbox and the
cowl. We change the oil with the bottom cowl on, with a quick drain from
Van's, but it would be nice if the bottom cowl came off easier. I also
couldn't imagine trying to do it with a 3-blade, but the plane looks better
with 3 blades and flies smoother. There are pros and cons to just about
everything.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
10flyer(at)verizon.net Guest
Posted: Tue Apr 18, 2006 9:15 am Post subject: Cowl fasteners |
Hey Tim, I have the Camloc system on my 10. The big advantage is that I can
easily put on/ take off top and bottom cowl by myself. I can also do it in a
matter of minutes. Disadvantages are obviously the cost, not as clean
looking, and almost impossible not to eventually get a little scalloping
between the camlocs around the firewall. I never have used pins before, but
I can tell you the other guy on the field with a 10 has them and needs help
putting the cowl on due to its size. He definately has a cleaner look!!
Posted: Tue Apr 18, 2006 9:53 am Post subject: Cowl fasteners |
I don't follow one thing though.... You said you have an easy
time doing the top AND bottom cowl by yourself. I can't
see what would make it significant in regards to the pins
though.....it seems like the actual pinning or camloc
twisting is the easy part...the hard part is just getting that
bottom cowl up in place between the prop and engine, under
that rear cowl bracket, next to the gear leg, and have
it all line up.
Or did you do something unique and have a lower cowl mod
that makes it easier to get on an off? I'm just not sure
what I'm missing.
Mark Chamberlain wrote:
can easily put on/ take off top and bottom cowl by myself. I can also do
it in a matter of minutes. Disadvantages are obviously the cost, not as
clean looking, and almost impossible not to eventually get a little
scalloping between the camlocs around the firewall. I never have used
pins before, but I can tell you the other guy on the field with a 10 has
them and needs help putting the cowl on due to its size. He definately
Rick S.
Posted: Tue Apr 18, 2006 2:04 pm Post subject: Cowl fasteners |
Take a peek at Randy Lervold's site, he is using the SKybolt C-loks. I am leaning this way although not flying yet. He specs out the correct PN's of the recepticles, studs etc. I think they are a better but albeit a tad more expensive than the hinge route.
Heres a link:
http://www.romeolima.com/RV3works/Airframe/airframe.htm
I really like the way they look and should outlast the hinges without any problem.
Rick S.
40185
Fuse/Finish
371.11 KB |
321 Time(s) |
_________________ Rick S.
RV-10
40185 |
Posted: Tue Apr 18, 2006 4:12 pm Post subject: Cowl fasteners |
Maybe this is specific to how my cowl worked out, but once I've posisitioned
the bottom half ( It sorta hangs on the baffle material around the air box)
I can easily fasten the top camloc on each side of the bottom cowl. It then
hangs by itself. Now it is a simple task to position the top and then go
through a sequence of fastening each camloc with a quarter turn. Of course I
still have the screws on either side of the spinner and under the cowl near
the fuselage. Mark
Randy(at)abros.com Guest
Posted: Fri Apr 21, 2006 8:37 am Post subject: Cowl fasteners |
I would not change from that factory setup. It has been flawless, easy
to install and remove. Randy
