		edgraydallas
				 Posted: Mon Mar 29, 2010 8:00 am    Post subject: Wing repair |
				My 2 cents worth on the wing repair.  Building new Model 4 wings is a good
 idea if financially feasible.  I would want to uncover the damaged wing to
 inspect for other damage.  If replacing the spar, how about sawing of the
 front half of the old spar, leaving the ribs in place, then attaching a new
 spar with rivets and cement.  It would only add the thickness of the spar
 material (.035 inches ?) to the chord of the wing, and would save lots of
 time and add only a pound or two.
 Before covering my model 4 wings, I have decided to make the "quick tip"
 mod, making the outer bay of the wing removable for conversion to
 "Speedster" wing.  Who has done this and who has any comments/advice.
 Please post here or email me - don't be shy.
 Ed Gray Dallas KF2 582 and Model 4 building and looking for 100 hp engine
 and fwf
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		leach(at)infogen.net.nz Guest
				 Posted: Mon Mar 29, 2010 12:10 pm    Post subject: Wing repair |
				My 2 cents worth also.  I have built an Avid but have never tried to repair
 a wing.  I would try what Ed Gray suggested and cut the spar in half
 lengthwise with an angle grinder and cutting disc. Aluminium cuts very
 easily with these discs.  But don't try and fit the new spar inside what is
 left of the old one.  This would be very messy and they wont fit neatly
 together anyway.  Use a grinding disc and grind the aluminium away from the
 inside of the spar at each rib.  The heat generated will help release the
 glue and the whole operation would be completely stress free on the delicate
 wing structure.  It would be a lot of work, but a lot less than building
 another wing.  As I said, I have never tried doing this but it might work.
 Brian.
		marwynne(at)windstream.ne Guest
				 Posted: Mon Mar 29, 2010 2:19 pm    Post subject: Wing repair |
				Splitting the spar will cause the spar to spring open wider .  I bet you will damage the ribs doing that
		dave
				 Posted: Mon Mar 29, 2010 2:58 pm    Post subject: Re: Wing repair |
				Guys , Get a grip here.
 You want to take a bent un- airworthy spar and  dissect it and epoxy and rivet another tube to it  ?
 Fix it properly or  the plane will  become a lawn ornament.
 Hard to believe that anyone would try to re-engineer a damaged part instead of doing a proper repair.
  _________________ Realtime Kitfox movies to separate  the internet  chatter from the truth
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
		Pat Reilly
				 Posted: Mon Mar 29, 2010 3:34 pm    Post subject: Wing repair |
				Sounds to me like it would be safer to just ignore the dent than attempt to fix it with the patch work methods I've seen here.
  Pat Reilly
  Mod 3 582 Rebuild
  Rockford, IL
  On Mon, Mar 29, 2010 at 4:06 PM, Brian Leach <leach(at)infogen.net.nz (leach(at)infogen.net.nz)> wrote:
   	  | Quote: | 	 		  --> Kitfox-List message posted by: "Brian Leach" <leach(at)infogen.net.nz (leach(at)infogen.net.nz)>
  another wing.  As I said, I have never tried doing this but it might workist Features Navigator to browse
  s.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
  ronics.com/" target="_blank">http://forums.matronics.com
  Matt Dralle, List Admin.
 Pat Reilly
 Mod 3 582 Rebuild
 Rockford,IL
				 Posted: Mon Mar 29, 2010 4:49 pm    Post subject: Wing repair |
				Pat Reilly and Dave.   I think you have  both misunderstood my post.  I was suggesting a way of completely removing  the old spar without stressing the rest of the wing structure, so that the new  spar could be glued in.  If the old spar could be successfully removed  without damaging the ribs the end result would be the same as a new wing.
  Brian.
  [quote]   From:    Patrick    Reilly (patreilly43(at)gmail.com)
    To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
    Sent: Tuesday, March 30, 2010 11:33    AM
    Subject: Re: Wing    repair
    Pat Reilly
    Mod 3 582 Rebuild
    Rockford, IL
 Pat Reilly
 Mod 3 582 Rebuild
 Rockford,IL
 href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
  | 	  [b]
		dave
				 Posted: Mon Mar 29, 2010 4:59 pm    Post subject: Re: Wing repair |
				Brian,  Yes replace the entire front spar.  But who knows what lurks inside.   It is a huge job regardless.  I just hope that the fellow that was looking at buying this plane knows  that the plane is not  structurally as sound as it should be.
 Plenty of Kitfox for sale< why fix a bent one when you can buy one that is airworthy now unless is it cost effective. ?
		dave
				 Posted: Mon Mar 29, 2010 5:01 pm    Post subject: Re: Wing repair |
				Pat - what are you saying here?   Ignore the damage?
 >>Sounds to me like it would be safer to just ignore the dent than attempt to�fix it with the patch work�methods I've seen�here.
 Pat Reilly <
				 Posted: Mon Mar 29, 2010 8:28 pm    Post subject: Wing repair |
				Dave
 I think it goes without saying that with any damage like this the fabric
 must be torn off, the entire wing inspected and the spar replaced.  The
 point that I was making is that if you can carefully cut the old spar out
 without damaging the ribs, and carefully support everything so you don't
 change the washout, then you should be able to make a perfect repair that
 would be a lot less time and money than building a complete new wing.  This
 is assuming there is no other damage except for the dented spar.  But as
 somebody else said, if you haven't already built one of these wings, don't
 even think about doing it.  Anybody thinking about buying this aeroplane
 would certainly want to see inside the wing before making a decision to buy
 it.
 Brian.
		lcfitt(at)sbcglobal.net Guest
				 Posted: Tue Mar 30, 2010 7:59 am    Post subject: Wing repair |
				I guess it is OK to agree and disagree.  I liked Brian's method of removing
 the front spar.  Cutting the spar into sections and then adressing each rib
 individually seems to be a great idea.  Doing the repair without having wing
 building experience would eliminate most of us that built after about 1995
 or so when the quick build wing came out.  I don't see any more challenge
 with the repair than building a wing, and the wing building was formerly
 done many times with only an instruction manual as help.  I would say,
 however, if the repair guy doesn't have much experience with tools, then
 look for some help somewhere.  Removing the fabric?  I think that would be
 necessary simply from the sake of fabric integrity.  It would also be good
 experience for understanding and maintaining the airplane down the road.
 Lowell
		edgraydallas
				 Posted: Tue Mar 30, 2010 8:49 am    Post subject: wing repair |
				Lots of interesting ideas on the bent wing spar.  I will clarify what I had
 in mind.  I don't think splitting the old spar would harm the ribs, but if
 so, that could be avoided by putting a kerf near the attach point for each
 rib.  If you totally detach all ribs from the spar, the wing will lose its
 shape and require some sort of jig.  If you lay it out flat and shim for the
 washout, you could leave only a skeleton of the old spar, not necessarily
 half of it, but avoid detaching all the ribs and basically starting all
 over.  You could preserve the dimensions and washout and attach a new tube
 with cement and rivets, no big mess that I can foresee.  I certainly would
 not just "go fly it and hope its ok".  That's my 2 sense worth, but I aint
 no enjunear.
 Ed Gray K2  and K4 building Dallas
		Pat Reilly
				 Posted: Tue Mar 30, 2010 5:47 pm    Post subject: Wing repair |
				Brian, Now that makes sense.
  Pat Reilly
  On Mon, Mar 29, 2010 at 8:44 PM, Brian Leach <leach(at)infogen.net.nz (leach(at)infogen.net.nz)> wrote:
   	  | Quote: | 	 		    Pat Reilly and Dave.   I think you have both misunderstood my post.  I was suggesting a way of completely removing the old spar without stressing the rest of the wing structure, so that the new spar could be glued in.  If the old spar could be successfully removed without damaging the ribs the end result would be the same as a new wing.
  Brian.
   	  | Quote: | 	 		   From: Patrick Reilly (patreilly43(at)gmail.com)
  Pat Reilly
  Mod 3 582 Rebuild
  Rockford, IL
  Pat Reilly
 Mod 3 582 Rebuild
 Rockford,IL
  | 	    	  | Quote: |
 Pat Reilly
 Mod 3 582 Rebuild
 Rockford,IL
