		wingnut
				 Posted: Tue Apr 18, 2006 2:03 pm    Post subject: Budget hangar door ideas? |
				I'm building a hangar on a tight budget and I'm stuck on a hangar door solution. Bifolds start at $3k so that's out. Anyone have any experience with 'do it yourself' hangar doors?
 I once built a pair of sliding doors for a horse barn using half inch plywood and a 2x6 frame but a single 10x6 door weighed close to 100 lb. I can get by with a pair of 16 ft doors and a really big shoehorn to get my Model 4 in the hangar. Any ideas?
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		henrysfork1(at)msn.com Guest
				 Posted: Tue Apr 18, 2006 2:56 pm    Post subject: Budget hangar door ideas? |
				Build yourself a bi-fold using a steel frame welded together and sheet it with metal. Its rather simple to do and when your done you have something worth while. I have a hanger with a wood frame door and it's a pain in the butt. I also have a hanger with a Schweiss bi-fold door which is great. I have a friend who duplicated a commercially built bi-fold and it works just as good as the Schweiss.
 Dee Young
 Model II
 Do not Archive
		bmwebb(at)cox.net Guest
				 Posted: Tue Apr 18, 2006 3:05 pm    Post subject: Budget hangar door ideas? |
				Better yet, sheet it with those wavy plastic panels, use for roofing, at the
 builders supply. It would be lighter, easy to repair, and let light in.
 You could build tracks at the top and bottom, and roll them open and closed.
 This way the weight is supported by the trucks, and you're just moving them,
 not trying to lift them.
 Bradley
		Rex Hefferan
  Joined: 10 Jan 2006 Posts: 147 Location: Olney Springs, Colorado USA   "NOT a Kitpig"
				 Posted: Tue Apr 18, 2006 3:12 pm    Post subject: Re: Budget hangar door ideas? |
				I don't have complete information for you, however I have done some research. There is a company named The Ultimate Door, Inc. which can supply a kit. There is at least 1 person on this list which has a door from them and stated he was very happy with it.
 http://ultimatedoor.homestead.com/ultimate.html
  Theirs is a single panel door and I perferred a bi-fold. Like you I'm resistant to spend $3K for a garage door, but my garage would benefit from the bi-fold features more than any other design. I figured that if I could build a kit plane how much trouble could it be to design and build a garage door? ( I don't know the answer quite yet    )
  I'm planning on building my own home made Bi-fold door for my garage door opening which is 16 X 8 feet. I haven't had time to complete the concept, but I was thinking of using 1" square tubing as the basis for the 2 frames and 2 wall polycarbonate to skin the frames.
  Hey, I just noticed as I was writing this on the forum page that Dee mentioned a friend who duplicated a Schwiess door. Maybe he could get some details?
 Rex
 Florida
  _________________ Rex
N740GP - M2/582
Colorado |
		7suds(at)Chartermi.net Guest
				 Posted: Tue Apr 18, 2006 3:16 pm    Post subject: Budget hangar door ideas? |
				Wingnut,
 Some food for thought, I have seen several low dollar hanger door ideas, 1)
 Use two 16' fiberglass garage doors side by side, outside rails are fixed
 and the inside rails are mounted on a swing up center post. When the doors
 are up the center post is swung up and latched to allow a 32' opening. 2)
 Swing up door sections that are framed and covered with light fiberglass
 panels, uses a cable and boat winch to lift, heard of the same thing covered
 in non-certified aircraft cover.
		Richard Rabbers
  Joined: 09 Jan 2006 Posts: 114 Location: Benton Harbor, MI - USA
				 Posted: Tue Apr 18, 2006 3:28 pm    Post subject: Re: Budget hangar door ideas? |
				Garage door shopss tend to toss away a lot of good doors. I hate waste!
 Many shops accumulate old doors then toss them all.
 My 'preferred model' has fiberglass panels and is translucent.  For a hanger door the panels could be joined or free to hinge depending on your design. The fiber glass type usually has an aluminum framework so very light. Sliding, bi-fold, or standard garage OHD. all options. Materials free!
  _________________ Richard in SW Michigan
Model 1 / 618 - full-lotus floats (restoration) |
		wingnut
				 Posted: Tue Apr 18, 2006 3:30 pm    Post subject: Re: Budget hangar door ideas? |
				I might be interested in attempting to duplicate the bifold idea with a good set of plans or even an example to copy. Anyone in the Greenville, SC vicinity with a bifold that I can examine?
 That UltimateDoor looks like it might be a good option as well. Looks like it's made of wood which is a plus since I've never done any welding. I guess $35 for a set of plans is a safe bet just to see some details of the lift mechanism.
 Thanks for the help guys.
		lcfitt(at)sbcglobal.net Guest
				 Posted: Tue Apr 18, 2006 3:31 pm    Post subject: Budget hangar door ideas? |
				Luis,
 I live in an air park and almost all of the houses have hangars attached.
 We have bifold, rolling and roll-up here.  Mine is roll-up.  Actually it is
 a pair of 16 ft wide garage doors that moves into the ceiling of the hanger.
 My door is about 12 feet tall.  The trick is that the center pillar - track
 for the guide wheels will move out of the way with both doors up.  It is on
 a track with an indexing fixture at the top and a pin that goes into the
 floor at the bottom to secure itin the center position.  The track is sloped
 to the side so that when the pillar is moved it elevates it about 6 inches
 when it is fully at the side and there is a detent on the floor there for
 the pin also.  This secures it in the side position.
 The only issue with this set-up is that you are in pretty deep do-do if you
 start to lower the doors with the pillar still at the side.  I have solved
 this by always lowering the left door (the door nearest the side stowed
 pillar) first.  It won't go down as there is an interference on that side.
 Experience has taught me this.  Both my doors are manually opened by chains
 that rotate wheels on the top.
 A neighbor has my door and uses power to roll his up.  He has figured a way
 to have the center pillar swing up to the side using a cable attached some
 how to his electric system.  The only negative on that is that the cable is
 visible as a diagonal line in front of the door when it is closed.
 I don't know how much this cost, but a quick check of garage door companies
 would give an estimate.  If you are interested in this idea I would be happy
 to take some photos and send them direct.
 Lowell
		gjfpilot(at)yahoo.com Guest
				 Posted: Tue Apr 18, 2006 4:27 pm    Post subject: Budget hangar door ideas? |
				Hi,
   I have some bi-fold door info if you're interested.
 My local EAA Chapter had planned at one time to build
 a hanger and since I do mechanical
 designing/engineering for a living, I did the plans
 for the building and the door. I looked at about half
 a dozen different doors at a few airports and drew
 what I needed on the computer.
 Grant Fluent
 Newcastle, NE
 Classic IV 912ULS
 --- wingnut <wingnut(at)spamarrest.com> wrote:
 http://forums.matronics.com/viewtopic.php?p=29250#29250
		n79rt(at)kilocharlie.us Guest
				 Posted: Tue Apr 18, 2006 5:52 pm    Post subject: Budget hangar door ideas? |
				Hi,
 Grant Fluent
 Newcastle, NE
 Classic IV 912ULS
 <snip>
 Would love to see your plans...am a steel draftsman myself...but have
 learned to not reinvent the wheel unless you have to
 Am about to have to build a door myself and am tickled that this
 discussion came up...hadn't thought about asking a bunch of PILOTS about
 hangar doors (DOH!!!)  I was sitting around thinking about how to
 reinvent the wheel
 Jeremy Casey
 Jeremy(at)kilocharlie.us
		Rex Hefferan
				 Posted: Tue Apr 18, 2006 6:17 pm    Post subject: Budget hangar door ideas? |
				I'm interested in your plans too. Also once was a draftsman.
 Rex
 Florida
 Jeremy Casey wrote:
 Hi,
 Grant Fluent
 Newcastle, NE
 Classic IV 912ULS
 <snip>
 reinvent the wheel
 Jeremy Casey
 Karla and Rex Hefferan
 Gypsy Bee Innkeepers
 719-651-5198 or 719-651-9192
N740GP - M2/582
Colorado |
				 Posted: Tue Apr 18, 2006 6:24 pm    Post subject: Budget hangar door ideas? |
 the
 <snip>
 Food for thought...the translucent wavy panels let more light in...which
 means more UV exposure for the fabric.  Heck it might decrease the life
 of your fabric by .7 minutes.
 I'm just thinking out loud so don't call me bad names...I also once read
 that florescent lights were as bad as sunlight as far as UV goes...don't
 have any reference to back that up either.
 I keep my plane in a blacked out box and use night vision goggles to
 move around it (big
 Jeremy Casey
		sonex321(at)msn.com Guest
				 Posted: Tue Apr 18, 2006 7:17 pm    Post subject: Budget hangar door ideas? |
				Hi Wingnut,
 When I had my Kitfox in an old wooden T hangar, I made a "cheapy door" out
 of 1x2s and 3 mil plastic.  Later I used 6 mil plastic which is still
 working for the current hangar renter after at least 4 years.
 For the first "half door", I stapled one plastic end to a 1x2, rolled the
 plastic around the 1x2 a few times, added a few more staples, then screwed
 another 1x2 to the first one.  I measured and cut off excess plastic so the
 rest would extend just past the middle of the hangar.  Next I stapled
 another 1x2 to that end, rolled a few turns, and stapled again.  I took
 another sheet of plastic and made another "half door" just like the first.
 Then the 2 ends of each half door with only one 1x2 were screwed together
 temporarily, with the plastic of each making a straight line from one half
 door to the other to eliminate twisting.  Test for length that encloses the
 hangar, and adjust center connection for best fit.  Then add nails on each
 side of the hangar (assumes wooden hangar!), drill holes in door ends and
 add rope which ties to the nails, securing the full door to the hangar.  I
 left one side tied all the time and untied the other end to access the Fox.
 I also had a rope tying the top of the door's center posts to the top of the
 hangar.
 This may seem like lots of work, but it was a real cheap solution which is
 still working after 8-9 years!
 Have fun,
 bh
 ex N194KF, 582ed IV-1200, 800+ hrs
  	  | Quote: | 	 		   I'm building a hangar on a tight budget and I'm stuck on a hangar door
		Ceashman(at)aol.com Guest
				 Posted: Wed Apr 19, 2006 1:44 am    Post subject: Budget hangar door ideas? |
				message from; Jeremy Casey
  	  | Quote: | 	 		  Food for thought...the translucent wavy panels let more light in...which
 Hi Jeremy.
 Who knows, the translucent panels may filter the UV radiation from entering
 the hangar interior. But if not, there still are three walls and a roof to
 protect from UV and that means there will be shadow/shade on the aircraft for most
 of the day. Most clear roofing material has UV blockers to allow longevity of
 the roof material. Otherwise the panel would degrade after a very short time.
 If you consider building a hangar and you have the freedom to position it at
 the airport, I think it best to have the opening facing north, north/east, for
 us folks in the hot South. That way you will not get the full effect of the
 afternoon sun warming the hanger contents even higher with Infra Red and sun
 tanning you and the aircraft fabric with Ultra Violet
  	  | Quote: | 	 		  I'm just thinking out loud so don't call me bad names...I also once read
 There is no UV radiation emitted from normal florescent lamps. Of course, you
 can buy florescent lamps that do emit UV. These are used in tanning salons.
 Cheers Eric, Atlanta
		jeburke94je(at)direcway.c Guest
				 Posted: Wed Apr 19, 2006 2:44 am    Post subject: Budget hangar door ideas? |
				Grant, I am building hanger doors this summer and would be interested in
 your plans.
 Thanks in advance,
 Jim
 jeburke94je(at)direcway.com
		morid(at)northland.lib.mi Guest
				 Posted: Wed Apr 19, 2006 3:05 am    Post subject: Budget hangar door ideas? |
				Grant, I think it would be ideal if you could upload these plans to
 Sportflight.com for the archives.  Everyone can benefit, even if it might be
 years later.  Just send them to Don Pearsall <donpearsall(at)comcast.net>,
 Kitfox List co-administrator, and he'll take care of the rest.  Might be
 best to contact him first with instructions.
 Deke Morisse
 List administrator
				 Posted: Wed Apr 19, 2006 3:12 am    Post subject: Budget hangar door ideas? |
				LOL
 Bradley
				 Posted: Wed Apr 19, 2006 2:12 pm    Post subject: Budget hangar door ideas? |
				Deke,
   Posting the bi-fold door info on Sportflight sounds
 like a good idea. After sending the message I realized
 that the door was drawn in Autocad but that I hadn't
 made the drawings for the door - just the building.
 That really isn't a big deal because the drawings
 wouldn't take long to do.
   What I could do is take what I have and make a
 generic example that would work for most planes with a
 36' wingspan or less. I could also include a little
 writeup so that a person can calculate the amount of
 counterweight needed and safety things such as not to
 use cable clamps on plastic coated cable, etc...
 Grant Fluent
 Newcastle, NE
 Classic IV 912ULS
  these plans to
  the rest.  Might be
  Deke Morisse
  List administrator
				 Posted: Wed Apr 19, 2006 3:22 pm    Post subject: Budget hangar door ideas? |
				That would be great Grant.  I'm sure many of us would like to have a look at
 it and by being in the archives future hangar builders can benefit.
 Deke
  Deke,
  Grant Fluent
  Newcastle, NE
  Classic IV 912ULS
  > these plans to
  > the rest.  Might be
  > Deke Morisse
  > List administrator
		rjdaugh(at)rapidnet.com Guest
				 Posted: Thu Apr 20, 2006 5:13 pm    Post subject: Budget hangar door ideas? |
				Rex may be talking about me.  I used the ultimate door on my hangar and am
 real happy with it.  It don't know what could be better if I had spent
 several thousand more dollars on a door.
 It does take some time to build.  The materials that I used make it good for
 a 90 mph wind.  I used translucent plastic to skin it.  It does let some
 light in.  - Plenty of light.  I don't have electricity up on the field
 where the hangar is so I have a hand crank.  It takes 10 seconds to raise it
 or lower it.
 Directions are good.   Kit is complete as far as hardware except for winch
 which can be had at local hardware store.  If you can build a fox, this is
 child's play!
 I could maybe post some pictures if desired.
 Randy
