		Nanchang CJ6
				 Posted: Tue Mar 30, 2010 7:27 pm    Post subject: Sell  Nanchang CJ6 aircraft parts |
				 	P/N	Des.
 1	SBL-40	inverter
 2	SBL-53	inverter
 3	QDF-1 	Compressed air solenoid valve
 4	1J-S34-1
 5	GZ-14	Tachometer transmitter
 6	H2-6121-106	fuel filter cup
 8	H2-6904-00	fixing pin
 9	H2-6901-320 	rubber bushes
 10	GWR-1	Resistor temperature sensor
 11	H2-3700-00-1	Flap hinge
 12	H2-3204-20	Trim hinge
 14	H2-9840-100A	Air charging hose
 15	 	Airfield power cable
 18	H2-5522-00	Emergency air valve
 19	H2-4230-40	Front gear uplock
 20	H2-4130-50	Main gear uplock
 21	H2-9830-400	Air charging tool with manometer
 22	GR-8	Thermocouple
 1	Ignition coil	DH-2
 2	Indicator light(White)	ZSD-1
 3	Indicator light(Red)	ZSD-1
 4	Indicator light(Green)	ZSD-1
 5	Indicator light(Yellow)	ZSD-1
 6	Indicator light(Purple)	ZSD-1
 7	Tail Light(White)	WD-1
 8	wing tip nav. Light(Red)	HD-3
 9	wing tip nav. Light(Green)	HD-3
 10	Push button	AN-1A
 11	Push button	AN-3A
 12	Push button	AN-2
 13	Gear switch	H2-4260-01/03
 14	uplock A/C	H2-4230-50
 16	PRV assembly	H2-5502-00
 17	valve	H2-5522-00
 18	gear guard plate( right side)	H2-4311-00-1
 19	magnetic compass 	LC-2
 20	front wheel hub	LW-11
 21	brake cable screw	H2-5113-05
 22	pulley	H2-5230-00
 23	pulley	H2-5407-30
 24	pulley	H2-5403-20/5
 25	emergency air bottle	H2-5506-10
 26	plug 	H2-5506-13
 27	Nipple	H2-5505-31
 28	washer	H2-5505-32/1
 29	reducing valve	QS-1
 31	deposit filter	QL-17
 32	 air charging connector	JT-7A
  	P/N
 1	Prop Cap and nut
 2	crush washers for oil sump
 4	Air flap valve
 5	Prop governor control bracket
 6	QS-1 air valve
 7	QS-2 air valve
 8	spark plugs
 9	brake pads
 10	brake air bladders
 11	Small Light bulbs for exterior
 12	Small Light bulbs for interior
 13	Air filters for air pump (box)
 14	Gill shutter rods
 15	Gill shutters
 16	Gill shutter complete assembly ring
 17	Fuel cover Zeus
 18	Copilot lunch box Zeus
 19	Wing tip fairings
 20	Oil cooler wing faring
 21	Air pressure gauge cockpit
  	P/N	Eng Des.
 1	12-5522-00	Double action valve
 2	H2-5522-00	Emergency valve
 3	H2-5503-00	Check Valve
 4	H2-5523-00	Hose
 5	H2-5524-00	Hose
 6	H2-5526-00	Hose
 7	H2-5532-00/3	Hose
 8	H2-5532-00/5	Hose
 9	H2-1030-100	Anti-Dust Cover
 10	H2-0109-110	Seat pad
 11	H2-7510-90	Seat pad
 12	HB2-30B	Pin
 13	BM5GB62	Nut
 14	GB1018-20	Washer
 15	H2-9850-900	Oil Table
 16	H2-9850-100	Screw Jack
 17	H2-9820-200	Screw Jack
 18	H2-9810-200	Screw Jack
 19	H2-9820-300	Control Lock
 20	H2-9820-400	Control Lock
 21	H2-9260-10	Cover
 P/N	Qty
 HB1-101-10x20x2.8	2
 HB1-404G-M10	5
 HB1-104-10x20x2.8	3
 H2-3000-02	1
 BM8GB54-45	1
 HB1-125-5x29.5x2	2
 HB1-404G-M4	4
 HB1-125-5x41.5x2	2
 HB1-125-5x41.5x2	2
 HB1-502LB-4x3.5	2
 H2-4250-00	1
 H2-4150-00	2
 H2-4220-00	1
  _________________ Sarah's E-mail:lcdzkj@live.cn |
		craig ekberg
				 Posted: Wed Mar 31, 2010 5:42 am    Post subject: Re: Sell  Nanchang CJ6 aircraft parts |
				call me 310 990 1111
