Graeme Toft
Posted: Tue Apr 18, 2006 8:24 pm Post subject: Wing strut |
Hi Guys, I need some help with info about the welded threaded bolt attached to the wing strut end. I need to replace them and Im not sure how to go about it. As there such a critical part Im not prepared to just weld a bolt on and hope for the best. Can anyone share their thoughts as to how to do this please.
Graeme
Ceashman(at)aol.com Guest
Posted: Wed Apr 19, 2006 1:59 am Post subject: Wing strut |
Graeme
My thought is; as this is one of your two sky hooks, I would make sure that
it is hooked firmly.
1/ maybe contact the new Kitfox and find out what the waiting time is for a
new strut. Do not worry about the cost, your life depends on it!
2/ find a licensed weldor, someone who knows the fine art of welding and
understands metals. But then again, if he asks what this triangular thing is for
and you answer "it holds my plane to the wing in the sky" He could be reluctant
to do the job unless he is a darn good qualified licensed professional or an
idiot.
The good thing is, if you ask him for his qualifications, there is no diploma
that shows him as an idiot.
Cheers Eric.
clemwehner(at)sbcglobal.n Guest
Posted: Wed Apr 19, 2006 7:42 am Post subject: Wing strut |
Graeme,
My answer won't help you much, but I had new bolts welded into my lift
struts. I discovered two of them bent during the construction of the
airplane. I sent the struts back to Skystar and they welded new bolts
in. The welded job was beautiful and barely even damaged the wooden
fairing around it. I've showed the welded repair to my son who races pro
race cars and is also a welder. He says the racing community use many
similar parts with welded rod ends. He said he has never seen them fail
and that they are extremely strong if welded properly. He was impressed
by the welding of the Skystar guy.
I haven't flown with them yet, so I have no actual data to offer you. I
thought about new lift struts but realized that rod ends would be welded
into the tubes on a new one also, no different from the repaired one.
If I were you, I'd get an aircraft welder to do it and get a second
opinion about the finished work. That's really about all you can do. I
don't think it's any different than new lift struts with welded rod
ends.
Like with everything else in the airplane you have to weigh the risk vs.
the benefit.
Clem
KF-IV
Lawton, OK
roncarolnikko(at)hotmail. Guest
Posted: Wed Apr 19, 2006 7:56 am Post subject: Wing strut |
Hi Graeme. The threaded portion is factory welded so I'm sure it can be
replaced. To avoid a lot of headache I would buy the end from the
manufacurer and have it welded according to their proccess. John Mcbean
should have the parts available under sportplane llc or whatever the new
Kitfox will be called. Ron NB Ore
| Quote: | From: "QSS" <msm(at)byterocky.net>
Subject: Wing strut
Date: Wed, 19 Apr 2006 14:19:18 +1000
this please.
Graeme
Richard Rabbers
Joined: 09 Jan 2006 Posts: 114 Location: Benton Harbor, MI - USA
Posted: Wed Apr 19, 2006 8:10 am Post subject: Re: Wing strut |
| Quote: | | such a critical part |
I don't know the 'exact process of attachement beyond rosette weld... If I was to design this critical part, I might consider mechanical AND weld connection. If it is possible maybe a combination of 'thread' and weld or 'pin' and weld.
My factory welds look good - I believe this topic has come up before. If I recall correctly.... there is no major history of failure. I hope that's correct.
_________________ Richard in SW Michigan
Model 1 / 618 - full-lotus floats (restoration) |
FLIER(at)sbcglobal.net Guest
Posted: Wed Apr 19, 2006 9:35 am Post subject: Wing strut |
Those 'bolts' are actually AN fittings that slide
into the end of the liftstrut and are rosette welded.
The rosette weld allows the load to be properly
transmitted to the strut tube as opposed to the weld
alone.
My advice would be to find out the AN part number of
the fitting, have the old one carefully removed
(which may require shortening the strut), have the
new one competently welded, then do a die penetrant
test to the end of the strut.
Ted
--- Original Message ---
Subject: RE: Wing strut
<clemwehner(at)sbcglobal.net>
Graeme,
welded into my lift
| Quote: | struts. I discovered two of them bent during the
construction of the
| Quote: | airplane. I sent the struts back to Skystar and they
welded new bolts
| Quote: | in. The welded job was beautiful and barely even
damaged the wooden
| Quote: | fairing around it. I've showed the welded repair to
| Quote: | race cars and is also a welder. He says the racing
community use many
| Quote: | similar parts with welded rod ends. He said he has
| Quote: | and that they are extremely strong if welded
| Quote: | by the welding of the Skystar guy.
| Quote: | thought about new lift struts but realized that rod
| Quote: | into the tubes on a new one also, no different from
the repaired one.
and get a second
| Quote: | opinion about the finished work. That's really about
all you can do. I
| Quote: | don't think it's any different than new lift struts
with welded rod
| Quote: | ends.
[quote]the benefit.
Clem
KF-IV
Lawton, OK
Graeme Toft
Posted: Wed Apr 19, 2006 10:42 pm Post subject: Wing strut |
Thanks for everyones help AGAIN. I have contacted John and he seems
optamistic about a repair so after advice from his welder he is going to
contact me again.
Cheers Guys
Graeme
