		Matt Dralle Site Admin
  Joined: 08 Nov 2005 Posts: 26477 Location: Livermore CA USA
				 Posted: Sun Apr 11, 2010 9:28 am    Post subject: Circuit To Combine Mag P-Lead For RPM Measurements |
				Has anyone found a device or circuit to pick off the output from the P leads on the left and right mags for feeding to an RPM measuring device such as the GRT EIS-4000?  The EIS-4000 only has a single RPM input.  The installation manual suggests installing a SPDT switch between the left/right mags and then to the input on the EIS-4000 for manually switching between the mags during drop testing.  But that's pretty hoekey.  Seems like someone should have come up with a simple prioritized switching circuit that would, say, always read the left mag p lead unless there wasn't a signal, then read the right mag P lead output.  In my "spare time" maybe I'll make one if there isn't something already out there like this.
 I thought that once upon a time I saw an electronic gizmo you could screw into the standard tack drive that would give an electronic output.  Anyone have a line on this device and whether its compatible with the GRT EIS?
 Thanks!!
 RV-8 #82880 N998RV
 http://www.mattsrv8.com - Matt's RV-8 Construction Log
 Status: Final Bits/Inspection/Test Flight
  _________________ Matt Dralle
		rene(at)felker.com Guest
				 Posted: Sun Apr 11, 2010 9:45 am    Post subject: Circuit To Combine Mag P-Lead For RPM Measurements |
				I use the switch.  But I think Vans sells the tack drive unit.
 1 plus for the switch.
  	  | Quote: | 	 		  From a raw data point of view, the switch is better since you are looking at
 each mag in isolation.
 Rene
 801-721-6080
		Ron.McGann(at)ausawd.com Guest
				 Posted: Sun Apr 11, 2010 2:24 pm    Post subject: Circuit To Combine Mag P-Lead For RPM Measurements |
				I'm with Rene.  The switch is simple and works fine.  Any electrickery needs to consider that one of the mags may be grounded during start.
 Cheers
 Ron
 VH-XRM flying in Oz
		bcondrey
				 Posted: Sun Apr 11, 2010 6:00 pm    Post subject: Circuit To Combine Mag P-Lead For RPM Measurements |
				Matt,
 You might check with GRT - I've heard that the newer versions of the EIS now come with 2 tach inputs.  Might be an upgrade available.
 RV-10 N442PM
