rparigoris
Posted: Mon Apr 12, 2010 7:51 pm Post subject: Why exactly shouldn't you run a 914 without a prop? |
I have read in the past you shouldn't run a 91X without a prop. Why exactly is that?
Here's a guy running a 914 without a prop, seems at low idle without flywheel effect it isn't quite as happy as with a prop, but just a little higher it seems pretty happy.
http://www.youtube.com/watch?v=uksKDll6n7M
Ron Parigoris
Thom Riddle
Posted: Tue Apr 13, 2010 3:13 am Post subject: Re: Why exactly shouldn't you run a 914 without a prop? |
The primary reason is that with too much throttle and it could very easily over-rev. As this video shows, if you make sure that the throttle is limited, it can be done.
Keep in mind that the spring pulls the throttle to wide open in normal configuration. The spring can be hooked to the other side of the throttle arm to pull it closed. If I felt a need to run one without a prop that is what I would do.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Roger Lee
Posted: Tue Apr 13, 2010 5:23 am Post subject: Re: Why exactly shouldn't you run a 914 without a prop? |
It's an absolute no no to run the 912 or 914 with no prop. It can over speed at a very small throttle setting and you won't be able to react in time to save your engine. Prop it and be happy to know it's the right thing to do.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
cicrn(at)telus.net Guest
Posted: Tue Apr 13, 2010 12:06 pm Post subject: Why exactly shouldn't you run a 914 without a prop? |
Years ago, I ran a two stroke (503 w 'A' Box) for a few minutes
without a prop. About 20 hours later during a gearbox oil change, I
noticed lots metal stuck to the magnetic drain plug. I flew for a
couple more hours and changed the oil again. Lots more metal debris.
I ended up dismantling the gearbox and found that there was evidence
of the hard surface coming off of the gears. The subsequent rebuild
was expensive. Coincidence? I think it was a direct result of running
it without a propeller.
YMMV
Joe
On 13-Apr-10, at 12:15 PM, rparigoris wrote:
<rparigor(at)suffolk.lib.ny.us>
Hi Rick
Thx. for the reply.
"Regardless of what someone else has done, or gotten away with, the
engine is designed to run with a prop. Why would you want to risk
it to run it without one?"
At the moment I have no need to run without a prop, but got to
wondering. I have run plenty of motorcycles and cars that
are a lot hotter tune than a 914 and have yet to over rev one in
neutral.
Easy to over rev, not very hard to keep within limits. If I ever
had a need to run without a prop would keep kill switch close at
hand. Running without
prop is a lot safer if you needed to check something, like
intermittent
miss where you could observe one of those transparent spark plugs like
Bing sells? Had a nagging charge problem that would allow you to
have a volt meter hooked up and aggressively wiggle and polk at
connections? Wanted to check exhaust for leaking by blocking
exhaust pipe and listening? If you had a nagging coolant or fuel or
oil leak that only dripped with engine running? Start up I think
can be a bit harder without flywheel which could stress spraigue I
imagine, but sure do like the idea of keeping ones self at less
risk compared to performing mentioned checks with spinning prop
close by.
Ron Parigoris
http://forums.matronics.com/viewtopic.php?p=294086#294086
lucien
Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
Posted: Tue Apr 13, 2010 3:06 pm Post subject: Re: Why exactly shouldn't you run a 914 without a prop? |
[quote="cicrn(at)telus.net"]Years ago, I ran a two stroke (503 w 'A' Box) for a few minutes
YMMV
Joe
<rparigor>
Hi Rick
Thx. for the reply.
neutral.
intermittent
close by.
Ron Parigoris
No no no... Trust me, the hammering the gears get _with_ a prop attached is way worse than the little bit of lash they get running free.....
The real hazard, as Roger and others have said is overrevving. Even at a typical idle speed, the load a prop puts on the engine is considerable, so the throttles are open a surprising amount even at idle. If you remove the prop without also reducing the idle throttle setting, it'll likely spin up and overrev....
For example, the 503 dual carb needs the slides completely bottomed out to idle with no load and even then the lowest it'll go is about 1800 rpm.....
But it idles perfectly at 1800 rpm with no load and I'd assume the flywheel in the 912 series would be plenty for it to idle without a load
__IF__
the throttles were closed enough....
Still I agree, don't try this at home!
LS
_________________ LS
Titan II SS |
AmphibFlyer
Posted: Wed Apr 14, 2010 5:32 am Post subject: Re: Why exactly shouldn't you run a 914 without a prop? |
| rparigoris wrote: | I have read in the past you shouldn't run a 91X without a prop. Why exactly is that?
Ron Parigoris |
That's Russ Garner, a friend of mine. The reason Rotax says not to run their engines without a prop is that they attach the carb springs to keep the throttles wide open unless something pulls them closed. Russ has the springs on the other way (which is standard for all SeaReys), so the engine idles very nicely until you open the throttles manually. I ran that very engine three days ago myself with no prop and it idled perfectly smoothly.
blackmore(at)platinum.ca Guest
Posted: Thu Apr 15, 2010 6:07 am Post subject: Why exactly shouldn't you run a 914 without a prop? |
scottmschmidt(at)yahoo.co Guest
Posted: Thu Apr 15, 2010 9:51 am Post subject: Why exactly shouldn't you run a 914 without a prop? |
I just joined this group so I can start learning about the Rotax. Just started an RV-12.
I may have missed something discussed earlier about this thread, but why would you ever run this motor before mounting it on the plane with a prop?
What is the advantage of running it without a propeller? When I built my RV-10 I had to be very careful not to bet my CHT's over 200 during my 3 test runs before the first flight. I just made sure the mag and ignition system worked, the oil pressure was up and the prop cycled. But I don't know the break-in procedures for the 912 yet so that is why I am asking.
Thanks.
Scott Schmidtscottmschmidt(at)yahoo.com
To: rotaxengines-list(at)matronics.com
Sent: Thu, April 15, 2010 7:46:16 AM
Subject: Re: Why exactly shouldn't you run a 914 without a prop?
--> RotaxEngines-List message posted by: "lucien" <lstavenhagen(at)hotmail.com (lstavenhagen(at)hotmail.com)>
Gilles.Thesee(at)ac-greno wrote:
| Quote: | AmphibFlyer a �crit :
How do you qualify a "perfectly smooth" idle ?
My engine also idles perfectly smoothly (with a prop attached, though)
between 1100 and 1800 rpm, and yet Rotax advises against idling below
1400 rpm, due to stress and chatter in the reduction gear, which to date
I have never been able to detect.
Like you said, tho, that doesn't mean everything is necessarily ok and there won't be long-term problems.
In fact, I was in a nasty thread a while back on another group where someone was advocating a shutdown procedure that introduced the possible hazard of running the engine below the specified minimum if it weren't carried out just exactly right. The claim was that it came from Eric Tucker or something like that but was otherwise backed up with nothing else but that heresay.
My contention is, at 20 large (and continuing to go up) a pop, the 912 is a poor platform for testing these oddball procedures gotten off the Internet or somewhere, unless you really have a lot of money to burn.
As for running the 912 series without a prop, it's also very likely that not a lot of field testing has been done with the 912 in that particular configuration .
So basically, these oddball ideas are done at one's own risk, both financially and in terms of support from Rotax and dealers, etc. On something relatively inexpensive like an auto or motorcycle engine you're not likely to be out a whole lot of cash if something breaks, but not with our 912's.
Let's be careful out there,
LS
LS
Titan II SS
http://forums.matronics.com/viewtopic.pharget="_blank" href="http://www.matronics.com/Navigator?RotaxEngines-Li also available via the Web nbsp; -Matt Dralle,://www.matronics.com/contribution">http://www.matronics.com/contribution
rickofudall
Posted: Fri Apr 16, 2010 3:50 am Post subject: Why exactly shouldn't you run a 914 without a prop? |
Guys and gals, I know it's been said before, but, again, how about just because, for 99% of 914 installers it's a bad idea because it will void your warranty and the good folks at Rotax who have put over a quarter century into refining the 912 / 914 series say it's not a good idea. As Brian Carpenter of Rainbow Aviation said to our LSARM class many moons ago, "They (Rotax) have a hundred or so white coated engineers running around who are paid to figure out this stuff, what chance do you think you have of finding something they haven't". When Ron Pagoris first asked this question of the group, my response was, "Why would you want to?". Ron came up with a list of reasons that centered around his dislike for working around a spinning propeller. I can appreciate that, for sure. I didn't respond because I didn't know if it would have made any difference to the discussion and I respected his reasoning.
However, with a few days reflection, I did come up with a few ideas that addressed his concerns.
Intermittent coolant, fuel or oil leaks.....use fluorescent dyes. I'm doing that right now in my 582 to track down a pesky coolant leak. $20 for the blacklight and $5 for the dye and I've eliminated the need to work around a spinning prop.
Intermittent ignition problems.....use a spark plug tester, oscilloscope, ohm meter, well, you get the idea. You may have to spin the prop, but you can at least get away from it.
Ron, I know I haven't addressed all your issues here, sorry, I'm an AR deleter of posts and just right now too lazy to go to the forum to back track.
Last, and I think this is the big one, simply use a club prop and a cage around it. Now, I'm quite sure this isn't in most tool kits, it isn't in mine, although if needed I have the equipment to make both in a few days.
Last fall our EAA chapter was lucky enough to have some of the volunteers from Bomber Force bring out one of Doc's R-3350's mounted on a test stand to do a night time run up of that big radial engine for us. The B-29 runs a 16' (4.88 m) prop which would have required a massive test stand. Instead they have a 3' (.9 m) club prop. With it they were able to run the engine all the way to take off power without damage. On the other end of the scale, when my friend Dave worked for Cascade Ultralights he used a 2' (.6 m) wooden club prop to do break in and diagnostic work on the 250cc Zenoah's.
My point is that there are work arounds for darn near every situation you can come up with that don't require running any engine against the advice of its manufacturer.
Just a thought.
Rick Girard
Dick Maddux
Posted: Fri Apr 16, 2010 4:40 am Post subject: Why exactly shouldn't you run a 914 without a prop? |
Ron,
Now you see what you did ? You should spank yourself for starting this thread !
Dick Maddux
Milton,Fl
rparigoris
occom
Posted: Sat Apr 17, 2010 3:15 am Post subject: Why exactly shouldn't you run a 914 without a prop? |
That unit is possible because of the design of the "C" box. It does allow
for the smooth idle of the engine, but the 912 doesn't suffer terribly from
that problem. Of interest is the statement about shock loads in the small
info blurb. I do not regard the prop on the gearbox as a contributor to a
smooth and continuous idle as some others do. I see it is a large inertia
load, contributing to load spikes and gearbox shocks. It isn't a problem
because Rotax designed for it obviously, but observation says it doesn't
make things smoother. There is a similar clutch engagement type device on
one of the Subaru conversion engines, not sure which one. I wonder how badly
the freewheeling prop will contribute to drag in the case that the engine
stops and the clutch disengages, can the freewheeling prop overspeed itself,
etc.
dave
Posted: Sat Apr 17, 2010 4:47 am Post subject: Why exactly shouldn't you run a 914 without a prop? |
I have thousands of Rotax powered hours. Clutches on C box are just not
that exicting to me. It an attribute when on floats for docking but the
cons out weight any advantage.
suberu are a heavy engine, they wok ok but the weight disadvantage
is a real drawback.
lots of rotax powered flicks heres http://www.youtube.com/user/kitfoxflyer
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
lucien
Posted: Sat Apr 17, 2010 4:50 am Post subject: Re: Why exactly shouldn't you run a 914 without a prop? |
| occom wrote: | That unit is possible because of the design of the "C" box. It does allow
etc.
For what it's worth, my Kolb FSII ran a 503 equipped with the RK-400 clutch. I finally had to stop talking about when I was on the Kolb list because several of its most prominent members just couldn't resist telling me over and over what a useless device it was, even tho they never used one and despite my repeating my positive experience with its use.
The truth is, the 503 idles much _more_ smoothly disengaged from the prop with the clutch than it does with a normal gearbox/prop. However, when you add the clutch you also readjust the idle speed and you also don't have the overspeeding hazard in any case (you still have the prop!).
As for the performance in the air, that's a whole 'nother topic.
Finally, I also wish there was a similar device for the 912 series. I'd add it in about 2 seconds
LS
Titan II SS |
lucien
dave
Posted: Sat Apr 17, 2010 6:20 am Post subject: Why exactly shouldn't you run a 914 without a prop? |
Not able to hand prop
extra parts that "could " give troubles
giant airbrake
dave
Posted: Sat Apr 17, 2010 6:22 am Post subject: Why exactly shouldn't you run a 914 without a prop? |
try this with a clutch
http://www.youtube.com/watch?v=osZC56FyM6o
lucien
Posted: Sat Apr 17, 2010 7:06 am Post subject: Re: Why exactly shouldn't you run a 914 without a prop? |
| dave wrote: | Not able to hand prop
giant airbrake
Er, that hardly qualifies as a large set of cons outweighing the (much larger) set of pros of using the RK-400 clutch.
Like I said, most of the folks who go on about how worthless the clutch is have very little, if any, time on a clutch-equipped engine/airplane.
No hand propping is a good try, but I'm not too convinced - the Rotax 2-strokes come with an excellent pull-rope starting system that is very reliable and gives little trouble. Even if, say the rope pulls out of the handle, the pull start is easily fixable in the field with a few hand tools you can keep in your flight bag. So it'd be rare indeed that you'd have to resort to hand starting (a very dangerous proposition on many pusher designs anyway).
If you put a mag-end electric start on Rotax 2-stroke, you get what you deserve anyway. At that point you should have gone with the E box which addresses that concern already.
I totally don't buy the extra-trouble argument. The RK-400 is a very well designed, heavy-duty item that lasts simply forever. On my FSII, the original engine was starting to wear out (at about 400 hours) before even a few _thousandths_ had been worn off the original set of shoes (I still have them out in the hangar in fact). The RK-400 was tested on the 618 and couldn't be made to slip or otherwise give any trouble at all even on that huge monster.
The giant airbrake argument is another I get all the time from folks who don't run the clutch. They don't realize, for example, that when the clutch is disengaged in the air (engine-idle), the plane flies _exactly_ as it would with the engine off. So you can _exactly_ replicate the engine off situation in your emergency procedure practice without having to shut the engine down. This makes getting familiar with the engine-off glide much safer to practice - i.e. if you really do happen to screw up an approach during practice you're not in a real emergency if you can't get the cold engine started again.
So on that day when the engine actually does stop for real, you're not dangerously trying to stretch a glide you've hardly ever practiced in the case of a fixed prop. Instead, it's exactly the same condition you've already practiced a million times before, greatly increasing your chances of a successful descent and landing.
Sorry, don't buy this one either
LS
Titan II SS |
occom
Posted: Sat Apr 17, 2010 8:40 am Post subject: Why exactly shouldn't you run a 914 without a prop? |
Lucien, this is extraordinarily interesting to me. I have always understood
that when the engine is stopped, the prop will accelerate wildly and
generate a huge drag effect. Are you saying that this is not the case? I am
very interested in what is observed and not conceived. Please feel free to
email off list if you care to.
BTW the "E" box is not a candidate for the clutch as you would be unable to
start the engine, I'm sure you already knew that but you made such a case
for it with the electric start that I thought someone might not be aware.
lucien
Posted: Sat Apr 17, 2010 9:16 am Post subject: Re: Why exactly shouldn't you run a 914 without a prop? |
| occom wrote: | Lucien, this is extraordinarily interesting to me. I have always understood
"accelerate wildly" is of course silly and not the case, no. It does windmill in the relative wind but the magnitude of the drag effect is also usually overblown, again by folks who've never flown a clutch equipped plane. On my FSII, for example, the drag added by my 68" WD 3 blade freewheeling wasn't too much more than the added drag of the 66" TPI 2 blade stopped on a dead engine on a friend mine's FSII. My glide ratio was a little worse than his, but not the "drag chute" myth spread by the guys who don't use a clutch.
They also don't understand that the drag that does get added can actually be useful (i.e. if you need extra drag such as when high/hot on final).
No, I was talking about the concern that you couldn't hand prop. My point was the E box kills two birds with one stone there - you have the prop fixed to the crankshaft for hand propping if desired and you can also retain the pull start on the mag end in case of an electrical problem.
LS
Titan II SS |
