		litesellme(at)yahoo.com Guest
				 Posted: Wed Apr 14, 2010 1:37 pm    Post subject: Why exactly shouldn't you run a 914   without a prop? |
				They say if you run a rotax 4 stroke without a prop you will chatter the gear box; I believe its just BS. I test run all my rotax 914 engines without a prop and they never shed chips.
 --- On Wed, 4/14/10, FLYaDIVE <flyadive(at)gmail.com> wrote:
 Subject: Re: Re: Why exactly shouldn't you run a 914 without a prop?
 To: rotaxengines-list(at)matronics.com
 Date: Wednesday, April 14, 2010, 2:03 PM
  --> RotaxEngines-List message posted by: FLYaDIVE <flyadive(at)gmail.com (flyadive(at)gmail.com)>
 Guys:
 Why are you becoming Theoretical Physicist and reinventing the wheel?
 Here is two hunks of information that are prevalent and should be followed:
 1 - In all my training with internal combustion engines in 45 years...
 You NEVER run an engine with out a flywheel of some type or a load.
 The prop is both a flywheel and a load.
 Now if you don't believe this jump to item 2...
 2 - Call up ROTAX and ask them: if they will warranty the engine if
 you tell them that you ran it without a flywheel or a prop?
 The reason for the flywheel or load is so you reduce or eliminate the
 possibility of the engine RUNNING AWAY... Over reving.  Have you ever
 been to the race track and the drive  shaft shears and WHAM.... One
 hell of a runaway situation.  That is one reason why they put
 explosion blankets around the flywheel.
 Barry
 On Wed, Apr 14, 2010 at 9:51 AM, Gilles Thesee
 <Gilles.Thesee(at)ac-grenoble.fr (Gilles.Thesee(at)ac-grenoble.fr)> wrote:
  	  | Quote: | 	 		   --> RotaxEngines-List message posted by: Gilles Thesee
  AmphibFlyer a écrit :
 >  I ran that very engine three days ago myself with no prop and it idled
 > perfectly smoothly.
  How do you qualify a "perfectly smooth" idle ?
  My engine also idles perfectly smoothly (with a prop attached, though)
   between 1100 and 1800 rpm, and yet Rotax advises against idling below 1400
  rpm, due to stress and chatter in the reduction gear, which to date I have
  never been able to detect.
  Did you take special measures to ensure acceptable stress in the reduction
  gear, or do you simply *think* things are okay ?
  BTW our project uses *no* springs for the throttles, but push-pull controls.
  And of course idle and full throttle stops.
  Best regards,
  Gilles
  http://contrails.free.fr
 http href="http://forums.matronics.com/" target=_blank>http://forums.matronbsp;          - List Contribution Web Site -http://www.matronics.com/contribution
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		ransman
				 Posted: Wed Apr 14, 2010 2:19 pm    Post subject: Why exactly shouldn't you run a 914   without a prop? |
				Interesting discussion!
  Because I am not a rocket scientist
  the only way I know is to read the  manual.
  it says:
 "Never run the  engine without a propeller installed as engine  would
  suffer  severe damage by overspeeding.
  Never fit  propeller directly to crankshaft."
  (this can be read at page 121)
  http://www.rotax-aircraft-engines.com/pdf/dokus/d04050.pdf
  ///  Sauli
  [quote]   ---
  _________________ "Cum propris suis alis volat"
He flies with his own wings |
		rparigoris
				 Posted: Wed Apr 14, 2010 5:51 pm    Post subject: Re: Why exactly shouldn't you run a 914 without a prop? |
				Was turning over my 914 today to move around a little lubrication and figure I should make the point that the Rotax 914 does in fact have a flywheel. Gilles a while back you posted a picture of a crankshaft stating there is no flywheel. You didn't mention the picture that attaches to the aft (opposite the prop) end. #19 which is called by Rotax the Flywheel hub, and #1 Magnito ring that is a big hunk of metal that is attached to the outside OD of Flywheel hub. Together these components are in fact a substantial piece of rotating mass (flywheel). That said if you were to mount a 914 on a motorcycle, it would probably be OK as is, but for easier drivability, you may want more flywheel when operating at lower RPMs.
 For sure if you used a new engine it would be one costly motorcycle!
 Ron Parigoris
