601XL main spar question
Goto page Previous  1, 2, 3, 4  Next
sdthatcher
PostPosted: Thu Apr 15, 2010 6:49 am    Post subject: Re: 601XL main spar question Reply with quote
I've still got mine... from some 40 years ago!
Sabrina wrote:
P.S. Dear John... a better book than CH's is Bruhn's Analysis & Design of Flight Vehicle Structures... a little bit more expensive at $100 used (original cost new was $17 back in the day) but well worth it...
Scott Thatcher, Port Saint Lucie, FL
601XL with Corvair, Registered as E-LSA
N601EL, EAA203 140 hours and not flying currently.
sdthatcher
PostPosted: Thu Apr 15, 2010 6:58 am    Post subject: Re: 601XL main spar question Reply with quote
Sabrina... Is your comment below the reason you felt uneasy about the upgrade?
"Do you think, in a flutter scenario you suggest, the wing fails first in negative gs?"
sabrina
PostPosted: Thu Apr 15, 2010 10:20 am    Post subject: Re: 601XL main spar question Reply with quote
grs-pms(at)comcast.net
PostPosted: Thu Apr 15, 2010 10:50 am    Post subject: 601XL main spar question Reply with quote
Sabrina:
Just a thought here from an old aero engineer: Have you considered that,
if flutter is the problem, the failure mode is quite likely torsion, rather
than bending?
George
psm(at)att.net
PostPosted: Thu Apr 15, 2010 11:03 am    Post subject: 601XL main spar question Reply with quote
Hi Sabrina,
I'm afraid nobody knows the answer to your question. If they did then the
cause of the accidents would not be "Unknown".
All we know for sure is that the airframe seems to always fail in the same
place - the joint between the wings and fuselage. You could get more
detailed description of the failure to include exact part numbers, but the
result is the same.
The upgrade blessed by the FAA, Chris, and apparently everyone who has
installed it merely beefs up the whole wing structure. It also balances the
ailerons (as originally demanded by the NTSB). It does nothing to fix the
control sensitivity gradient that the NTSB also asked for.
Any guesses as to the actual failure scenario would be just that -- guesses.
I truly hope you reexamine your decision to design your own fix for this
totally unknown problem. I would sleep a lot better if you either installed
the approved upgrade or just scrapped your plane. I am currently installing
the upgrade in mine, but I will not take it out of phase I testing until a
significant amount of time (perhaps a year) has gone by with no more
structure failures.
I have no doubt that you are very smart and probably the best educated
person on this list. Still, I don't think that is enough to know what is
wrong with the Zodiac XL design and how to fix it.
Best regards,
Paul
Installing XL upgrade
sabrina
PostPosted: Thu Apr 15, 2010 11:25 am    Post subject: Re: 601XL main spar question Reply with quote
PatrickW
PostPosted: Thu Apr 15, 2010 1:39 pm    Post subject: Re: 601XL main spar question Reply with quote
Sabrina wrote:
I would like to poll the members...
Torsion.
Take a cardboard shoe box. Tape it up nice and tight. You can stand on it.
Take that same cardboard shoe box. Tape it up nice and tight, but with a 9 degree tilt to it. Then try to stand on it. Not nearly as strong.
The question is, "do the upgrades make the wing strong enough...?" It appears that as far as Zenith and the FAA is concerned, the answer is "yes".
Time will tell as more of us complete the upgrades and return to the air.
Patrick
XL/Corvair/BRS
rtdin
PostPosted: Thu Apr 15, 2010 2:51 pm    Post subject: 601XL main spar question Reply with quote
A poll? Nobody here kicked tin at the various accident sites. I would sooner rely on the investigating agencies and not the "experts" who were not there.
"Tearing our wings off ?" Just about all of the wing failures happened in cruise flight. Several in the traffic pattern. One purely weather related case.
"Horizontal stabilizer?" NTSB says that in only one case, the fwd stabilizer brackets collapsed first, followed by total break up. I was asked to look at a project in the area and found the rear bracket cracked. Zero flight time. A more detailed exam revealed cracks left and right side. I posted pictures in ZBAG "photos." I am still tying to get my hands on this part. Any questions, contact me at MaxNr(at)aol.com.
Questions about flutter are not adequately covered in a few posts on a user group. Many people "believe" or "don't believe" only as matter of faith. As for me, I depend on advice from a retired aerodynamicist in my area who worked on USAF flutter projects. Bingelis has archived lots of flutter stuff on the EAA website. Barnaby Wainfan recently wrote columns on flutter in Kitplanes. I also listen a lot to an A.I. who is still a senior inspector at the carrier that I retired from.
I so wanted to stay out of this, but couldn't resist.
Bob Dingley
601XL Plans 6-6791 Jab 3300 (Formerly a Lyc)
Picking away at the recently arrived upgrade.
sabrina
PostPosted: Thu Apr 15, 2010 4:09 pm    Post subject: Re: 601XL main spar question Reply with quote
JohnDRead(at)aol.com
PostPosted: Thu Apr 15, 2010 8:35 pm    Post subject: 601XL main spar question Reply with quote
Pilot error!
Regards, John
CH701 - Colorado - Jabiru 3300
Cell: 719-494-4567
Home: 303-648-3261
In a message dated 4/15/2010 6:27:53 P.M. Mountain Daylight Time, chicago2paris(at)msn.com writes:
--> Zenith-List message posted by: "Sabrina" <chicago2paris(at)msn.com>
You are exactly the person to pull into the discussion... what do your experts think is being addressed by the factory mods... in other words which failure mode is being addressed the most with the upgrade according to your sources...
although we each know very little on our own, we all have an expert of two giving us advice...
http://forums.matronics.com/viewtopic.php?p=294371#294371===============================================
_-= the ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; � ===================================================
PostPosted: Thu Apr 15, 2010 8:36 pm    Post subject: 601XL main spar question Reply with quote
Thanks Bob, there is some sanity out there!
Regards, John
Cell: 719-494-4567
Home: 303-648-3261
In a message dated 4/15/2010 4:52:12 P.M. Mountain Daylight Time, MaxNr(at)aol.com writes:
Bob Dingley
href="http://www.matronics.com/Navigator?Zenith-List">http://www.matron====================================
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
PostPosted: Thu Apr 15, 2010 8:42 pm    Post subject: 601XL main spar question Reply with quote
None of you seem to understand what a monocoque structure is and how it resists both bending and torsion. As I suggested in a recent post - buy a copy of Chris Heintz book and you will understand. There are other books about airframe structure design but none written about the Zenith series of aircraft by the designer.
Regards, John
Cell: 719-494-4567
Home: 303-648-3261
In a message dated 4/15/2010 3:40:50 P.M. Mountain Daylight Time, pwhoyt(at)yahoo.com writes:
--> Zenith-List message posted by: "PatrickW" <pwhoyt(at)yahoo.com>
Torsion.
Take a cardboard shoe box.� Tape it up nice and tight. You can stand on it.
Patrick
XL/Corvair/BRS
http://forums.matronics.com/viewtopic.php?p=294356#294356===============================================
n801bh(at)netzero.com
PostPosted: Fri Apr 16, 2010 5:43 am    Post subject: 601XL main spar question Reply with quote
Yeah... The Yube City fatal crash has pilot error written all over it..... Couple in their 70's, straight and level, below VA, all documented by radar returns.......
from straight and level to massive destruction left scattered all over an orchard in about 40 seconds. Maybe the elderly gentleman was showing his wife how he was going to fly in the Red Bull challange and broke the plane with her in it for her first ride in it.... FAT CHANCE.
Sure looks like pilot error to me.
Ben Haas
N801BH
www.haaspowerair.com
ken Buchmann
PostPosted: Fri Apr 16, 2010 6:51 am    Post subject: Re: 601XL main spar question Reply with quote
Dear Everyone:
I always enjoy these learned discussions pertaining to wings. As a retired farm practice veterinarian, I am now enjoying a life long desire to experience traveling through the air like the birds do, but only in a flying machine.
I have owned a Cessna 172A, CH801, CH701 and now am building a CH750. I have never seen a low winged bird in my entire veterinary experience and what is good enough for God is good enough for me. Also, where wise men disagree, fools step in.
And now at 80 years of age I am considering building a wooden (God's Composite) open cockpit (white scarf and goggles) Biplane (Wright number of wings for mankind)
Ken
bryanmmartin
PostPosted: Fri Apr 16, 2010 8:02 am    Post subject: 601XL main spar question Reply with quote
The Yuba city crash did NOT happen in straight and level flight. The radar track clearly shows maneuvering flight just before the break-up. The radar showed a climb followed by a fairly rapid descent just before the break-up. The accident report shows a failure in negative G loading. Maybe the pilot pushed the nose over suddenly to avoid a bird strike. Or maybe he had a sudden medical problem. We'll never know for sure.
Why do you keep denying the possibility of pilot error in these accidents? It's a fact that pilot error is a factor in more accidents than all other causes combined. It is an especially prevalent problem for low time pilots with low time in type. Low time in type seems to be about the only common thread in these accidents, along with low time on the airframe.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
Terry Phillips
PostPosted: Fri Apr 16, 2010 8:05 am    Post subject: 601XL main spar question Reply with quote
Thank you, Ken
At last someone is spreading some real wisdom on these issues.
You post has made my day!
Terry (still a low wing building fool--not even 70 yet--hope I'll have
finished my 601XL and be building something else when I'm 80)
At 07:51 AM 4/16/2010 -0700, you wrote:
Dear Everyone:
flying machine.
Ken
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
ZU-601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail & flaps are done;
Upgrading wings & ailerons per the AMD Safety Directive
http://www.mykitlog.com/N47TP/
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings.
psm(at)att.net
PostPosted: Fri Apr 16, 2010 8:47 am    Post subject: 601XL main spar question Reply with quote
Hi Bryan,
I believe you are correct when you refuse to rule out pilot error as cause
for all the XL breakups. Indeed, there has never been a determination, by
the accident investigation experts, of any probable cause for these
accidents.
The problem I have with blaming all this on pilot error is:
1. It is too convenient. The pilots are all dead and unable to defend
themselves or their actions. This makes them easy targets for those who
prefer to stay "In Denial" that there is actually a design problem with the
XL.
2. It doesn't make sense for me that only Zodiac XLs attract pilots prone
to errors that remove the wings from their planes. The Zodiac XL is the
only design that has experienced multiple accidents of this, or any, type
among LSA in the last few years. Out of hundreds of designs flying today
only this one has experienced unexplained in-flight structure failures.
Indeed the failures all amounted to the wings coming off at the root.
3. It doesn't provide any useful solutions to the problem. If the whole
cause for these accidents is pilot error then the only remedial action that
would help would be to find better pilots to fly Zodiac XLs. Perhaps a
special pilot's license is called for?
4. I find it odd, perhaps incredible, that the agencies that nearly always
find pilot error as the cause for any accident they investigate have never
found pilot error to be even a consideration in all these accidents. Only
the designer and companies that make their living from selling these planes
has taken a public position that pilot error, or maintenance problems, are
behind all the deaths.
So, while I agree with you that we cannot eliminate pilot error from the
cause of any of the XL accidents I think blaming the whole problem on
unfortunate pilot actions is nothing short of absurd "Denial".
Paul
XL installing upgrade
sabrina
PostPosted: Fri Apr 16, 2010 9:17 am    Post subject: Re: 601XL main spar question Reply with quote
PostPosted: Fri Apr 16, 2010 9:34 am    Post subject: 601XL main spar question Reply with quote
Hi Ken:
You make an interesting point about God's design choices, but don't carry it
too far. There are no recorded sightings of a bird with wing struts, or one
on wheels, floats or even skis. And they do tend to land in trees, so be
careful.
George
pchap(at)primus.ca
PostPosted: Fri Apr 16, 2010 9:53 am    Post subject: 601XL main spar question Reply with quote
At 13:17 16-04-10, you wrote:
Check out this picture of the Zenith load testing... notice the
additional cuff bonded/riveted between the wing and
fuselage... (this really bothers my mentors) would the wing have
failed the load test without that reinforcement? (I know some will
say it is just for aerodynamics, but why test in that configuration?)
Hi Sabrina,
Hope this helps:
It kind of looks like the same heavy plastic sheeting or whatever it
is, that is laid along the wing, under the wood (?) ontop of which
the weights sit.
The sheeting looks a bit like a reflection at first but one can see
it extend a little past the wing tip at the nav light.
A good interpolated zoom of the photo, eg by control - mouse scroll
wheel in Firefox, helps to see it more clearly.
Peter Chapman
Toronto, ON
Page 2 of 4
