Posted: Wed Apr 14, 2010 5:47 pm Post subject: Paint system choices |
It's that time - paint. I have a HVLP turbine system, rebreather, and
the space to setup a booth of some type. Need a paint scheme and most
importantly, a paint system to commit to.
I sure would like to get some feedback on Loehle's system. Seems like a
lot of people use the pinhole filler (John G) and others the whole
system (Rick). I've contacted them for some further information.
I'm also looking at going to my local Dupont distributer and working
with them. It wasn't clear to him or me that he had access to the
aircraft line of products, at least not the aircraft top coat products.
But it would be nice to have a local resource I'm thinking.
Any and all suggestions or guidance is appreciated. Please contact me
directly if more appropriate.
Thanks in advance,
Bill "head spinning before inhaling any fumes" Watson
jfrjr(at)roadrunner.com Guest
Posted: Wed Apr 14, 2010 7:52 pm Post subject: Paint system choices |
Bill (and others): I had painted cars as a kid and thought I was pretty good so I decided to paint the 10. I used the Loehle system throughout including his hole filler (works very well with minimum "coats".) I started with a turbine HVLP but was getting crummy results so went back to what I used as a kid (big compressor, refriged air, but used the new lower pressure guns with multiple tips). It did not come out as well as I hoped: 1) booth was too small especially for the fuselage. 2) I painted it over a long period of time so some of the colors don't exactly match (? different humidity, ? improper mixing, ? different batches from Loehle, ???)and, 3) most importantly, shitty lighting because of the too small booth and lack of money to really buy good lights. To me lighting is the most important factor in applying good coats. If I had it to do over I would do it after the plane was together, do it in my hanger in a large very well lit temporary booth. No, I take that back. If I had it to do over I would pay someone to do it!!! If you have any specific questions please feel free to call me (207) 322-6167. Jay Rowe 40301
---- Bill Mauledriver Watson <MauleDriver(at)nc.rr.com> wrote:
Thanks in advance,
Posted: Wed Apr 14, 2010 8:11 pm Post subject: Paint system choices |
Yeah, I painted model airplanes as a kid and quickly realized that I was
a bulider and flyer but not a finisher. The advent of Monokote and
it's many descendants saved me. I feel your pain.
I swore up and down that I would be farming out the paint but finances
and some sort of misguided pride has me determined to do it myself. I
lack the skills and the patience but I have the space so I'm just going
to have learn to take the time to learn, prep, and paint. Plus I have a
Maule that REALLY needs a nice new cover and paint job. Flying in the
rain challenged the original paint. We'll see.
Sounds like doing it all at one time is good - but it seems that doing
it in parts is easier. Putting those 2 thing together with lot's of
light looks like a good approach.
Bill
jfrjr(at)roadrunner.com wrote:
| Quote: | Bill (and others): I had painted cars as a kid and thought I was pretty good so I decided to paint the 10. I used the Loehle system throughout including his hole filler (works very well with minimum "coats".) I started with a turbine HVLP but was getting crummy results so went back to what I used as a kid (big compressor, refriged air, but used the new lower pressure guns with multiple tips). It did not come out as well as I hoped: 1) booth was too small especially for the fuselage. 2) I painted it over a long period of time so some of the colors don't exactly match (? different humidity, ? improper mixing, ? different batches from Loehle, ???)and, 3) most importantly, shitty lighting because of the too small booth and lack of money to really buy good lights. To me lighting is the most important factor in applying good coats. If I had it to do over I would do it after the plane was together, do it in my hanger in a large very well lit temporary booth. No, I take that back. If I had it to do over I would pay someone to do it!!! If you have any specific questions please feel free to call me (207) 322-6167. Jay Rowe 40301
> Thanks in advance,
martinaerodrome(at)gmail. Guest
Posted: Thu Apr 15, 2010 5:38 am Post subject: Paint system choices |
Most of the modern paint systems will work well on metal airplanes. I have used both HVLP and high pressure systems. I found that the HVLP systems worked best on fabric surfaces and the high pressure worked best on metal airplanes. (note fabric jobs require a flex additive).
I would like to advise you to use caution when using modern urethane paints because of the toxic materials used in them (methyl ethel keotone) . I would suggest you consider an outside fresh air supply instead of charcoal masks. the charcoal masks have a very short life and will not filter the toxic vapors. I speak from experience, I now suffer from a tremor in my right arm and hand caused by the hexamethaline di iso cyanates used in all of the urethane paints. Note also use surgeons gloves (the blue ones).
Good luck.
Dick Martin
RV8 N233M
the fast one
On Wed, Apr 14, 2010 at 8:26 PM, Bill Mauledriver Watson <MauleDriver(at)nc.rr.com (MauleDriver(at)nc.rr.com)> wrote:
[quote]--> RV10-List message posted by: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com (MauleDriver(at)nc.rr.com)>
It's that time - paint. I have a HVLP turbine system, rebreather, and the space to setup a booth of some type. Need a paint scheme and most importantly, a paint system to commit to.
I sure would like to get some feedback on Loehle's system. Seems like a lot of people use the pinhole filler (John G) and others the whole system (Rick). I've contacted them for some further information.
I'm also looking at going to my local Dupont distributer and working with them. It wasn't clear to him or me that he had access to the aircraft line of products, at least not the aircraft top coat products. But it would be nice to have a local resource I'm thinking.
Any and all suggestions or guidance is appreciated. Please contact me directly if more appropriate.
Thanks in advance,
List Un/Subscription,
www.matronics.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
Posted: Thu Apr 15, 2010 6:41 am Post subject: Paint system choices |
The advice is well taken. I do have a fresh air system (one of the Axis
systems from Spruce with fresh air and gun supply combined into one). I
think that makes this a 1 person spary operation however. I will be
getting the 'blue' gloves though not sure of their composition yet. And
a suit and full face mask will be used.
If only I was ready to shoot paint.
Thanks.
Bill "driving the slow one" Watson
Richard Martin wrote:
| Quote: | Most of the modern paint systems will work well on metal
airplanes. / / I have used both HVLP and high pressure systems. I
Good luck.
Dick Martin
RV8 N233M
the fast one
information.
I'm thinking.
Thanks in advance,
AV8ORJWC
Posted: Thu Apr 15, 2010 8:46 am Post subject: Paint system choices |
I have to second Dick's comments with a hearty "Do not discount the importance of protection from chemicals". Back in the days of Lacquers and Testor Model cement, things were a bit more basic with a higher survival rate. The newer urethane and iso-cyanates should always (without exception) have painter protection of the eyes, nasal cavities, lungs and skin. My tremors were central nervous system pains that appeared immediately after using charcoal filters and no sealed hood. The cost is a worthy investment in years of enjoyable flight. We are negotiating language for our professional painters at the airline to have annual chemical workups because so many die early from cancers in a most alarming rate.
As a collective group, we could pool resources and get a system which can be passed from builder to builder like the composite countersink bit.
John Cox - Ready with the first $300.00 and five Tyvek bodies suits for the next five participants in the size of your choice.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Richard Martin
Sent: Thursday, April 15, 2010 6:38 AM
Subject: Re: Paint system choices
Good luck.
Dick Martin
RV8 N233M
the fast one
Thanks in advance,
<![if !supportLineBreakNewLine]> <![endif]>
[quote] - The RV10-List Email Forum -[/b][/b][/b][/b][/b] --> http://www.matronics.com/Navigator?RV10-List[b] - MATRONICS WEB FORUMS -[/b][/b] --> http://forums.matronics.com[b] - List Contribution Web Site -[/b] Thank you for your generous support![/b] -Matt Dralle, List Admin.[/b] --> http://www.matronics.com/contribution[/b] [b]
Lew Gallagher
Posted: Thu Apr 15, 2010 9:33 am Post subject: Re: Paint system choices |
Hey Bill,
The "blue gloves" I use are green: WW Grainger, "TouchNTuff" (Ansell), 92-500, medium. I started using them years ago when I asked EMS workers what they used since they are very aids aware and use the best. I happily discovered later that since they are Nitrile, they stand up to thinners better, but still give a nice touch.
The chemical scare with urethane is real -- MANY years ago I was working in a cancer research lab where we gave mice subcutaneous pops of urethane to give them lung cancer so they could study the tumors. Most forget to cover up their skin.
I have an explosion proof exhaust fan in my shop and get lots of cross draft, cover up pretty good, use a fresh carbon cartridge every time I shoot urethane, no hood, no problems. Painted it in pieces. I used automotive acrylic enamel just to keep the weight down. (basecoat/clearcoat on cars, I use three coats of each and it adds up)
The way I paint, it is very labor intensive, and you may want to listen to those who say "hire someone!", but some of us take pleasure in the process -- something about unwrapping after shooting is almost perverse. Oh, make sure you use good automotive masking tape -- especially around the windows inside and out -- sticky and tough, but won't leave residue. My paint shop's good tape is light green now.
Come see us! Later, - Lew
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
msausen
Posted: Thu Apr 15, 2010 9:52 am Post subject: Paint system choices |
Those would be Nitril gloves. You can get them from HF also in the Nitril or, for double protection, nitril/latex combination.
This is also a good system for fresh air without having multiple hoses being dragged around.
http://www.eastwood.com/pure-air-2000-with-opti-fit-respirator-med.html
Just be sure your compressor has fresh air. I pulled the cheesy little paper filter off of my compressor and plumbed a new intake from outside and well above the building. I also used a water filter with a paper element for a cheap DIY inlet air filter that works great. You could even use a charcoal filter if you really wanted. My compressor now has shorter run intervals and is staying cooler because it doesn't have to suck so hard.
http://www.homedepot.com/h_d1/N-5yc1vZ1xkk/R-100471282/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Michael
jeff(at)westcottpress.com Guest
Posted: Thu Apr 15, 2010 10:07 am Post subject: Paint system choices |
I'd be inclined to prep and prime in parts and look to shoot the
topcoat in as few sessions as possible.
Jeff Carpenter
40304
On Apr 14, 2010, at 9:10 PM, Bill Mauledriver Watson wrote:
was a bulider and flyer but not a finisher. The advent of Monokote
and it's many descendants saved me. I feel your pain.
finances and some sort of misguided pride has me determined to do it
myself. I lack the skills and the patience but I have the space so
I'm just going to have learn to take the time to learn, prep, and
paint. Plus I have a Maule that REALLY needs a nice new cover and
paint job. Flying in the rain challenged the original paint. We'll
see.
doing it in parts is easier. Putting those 2 thing together with
lot's of light looks like a good approach.
Bill
> take that!
>> information.
>> I'm thinking.
>> Thanks in advance,
Posted: Thu Apr 15, 2010 10:08 am Post subject: Paint system choices |
Hi Bill,
I've been working with the Loehle system, so far on the inside of the
cabin top and the interior of the plane. I plan to use it as well on
the exterior. What I can tell you is that his black primer on the
composite parts is a huge help. It is high build and very glossy.
Low spots and pinholes are easily seen after sanding... and visibility
is everything in this process (here I concur with Jay) so lighting is
extremely important. Mike Loehle himself is very helpful, and that
help is as important to the novice painter as the paint itself.
Jeff Carpenter
40304
On Apr 14, 2010, at 6:26 PM, Bill Mauledriver Watson wrote:
information.
Thanks in advance,
