601XL main spar question
Goto page Previous  1, 2, 3, 4
macstar(at)clear.net.nz
PostPosted: Mon Apr 19, 2010 10:57 am    Post subject: 601XL main spar question Reply with quote
I am both curious and alarmed!
What are you doing to your wing? The “D” section provides much strength and rigidity to the wing structure. Strength will need to be restored before you fly it again.
Ian McClelland
New Zealand
601xl 90% complete
Upgrade 90% complete
sabrina
PostPosted: Mon Apr 19, 2010 12:18 pm    Post subject: Re: 601XL main spar question Reply with quote
bryanmmartin
PostPosted: Tue Apr 20, 2010 7:09 am    Post subject: 601XL main spar question Reply with quote
Cut the ring off and use a cable shackle (AN115-46) to connect the cable.
New question, to all:
My NOS AN47 eye bolts just arrived from Preferred Airparts, I have never seen them with a ring…
For those familiar with an AN47 bolt, if you were going to run a 3/16” cable between two of these AN47 eye bolts, would you cut off the rings or leave them on?
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
Page 4 of 4
