Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27955 Location: Toledo Washington (KTDO) USA
Posted: Mon Apr 19, 2010 12:51 pm Post subject: Check Valve For Static System Cabin Venting... |
Dear Listers,
Looking at the requirements for IFR certification of the RV-8, it looks like the only thing I don't have is an "alternate static source". This seems like it would be as simple as adding a "T" valve in the 1/4 neoprem static air tube that goes along under the left hand canopy rail.
Does anyone have any suggestions on something I could just cut the tube and stick in line with a little thumb screw to switch between the fuselage or cabin source?
I'm assuming this will meet the requirement?
Thanks!
PS - Attached are a couple of pictures from Taxi-testing and Magnetometer calibration this weekend. Cool?
RV-8 #82880 N998RV
http://www.mattsrv8.com - Matt's RV-8 Construction Log
Status: Final Bits/Inspection/Test Flight
118.16 KB |
17033 Time(s) |
111.58 KB |
17033 Time(s) |
100.12 KB |
17033 Time(s) |
105.41 KB |
17033 Time(s) |
104.35 KB |
17033 Time(s) |
93.51 KB |
17033 Time(s) |
84.37 KB |
17033 Time(s) |
77.18 KB |
17033 Time(s) |
95.49 KB |
17033 Time(s) |
98.4 KB |
17033 Time(s) |
92.02 KB |
17033 Time(s) |
99.33 KB |
17033 Time(s) |
107.22 KB |
17033 Time(s) |
168.96 KB |
17033 Time(s) |
94.25 KB |
17033 Time(s) |
167.76 KB |
17033 Time(s) |
113.65 KB |
17033 Time(s) |
101.8 KB |
17033 Time(s) |
95.41 KB |
17033 Time(s) |
_________________ Matt Dralle
Posted: Mon Apr 19, 2010 6:48 pm Post subject: Check Valve For Static System Cabin Venting... |
At 03:53 PM 4/19/2010 Monday, you wrote:
Matt, cut the tubing, insert a 'T' with a short stub of tubing. Put a plug in the tube of a type that you can pull out easily if needed.
Simple, light, and inexpensive.
Linn
Matt Dralle wrote:
>Dear Listers,
>Thanks!
What a great idea, Linn! Thanks. Here's what I did tonight including a couple of pictures...
I added a small "T" Nylon fitting in the 1/4" tube for static air just in front of the instrument panel under the left cockpit rail. I cut a short piece of 1/4" tubing and filled it with black RTV and then put a piece of heat shrink tubing over it to form a handle. The whole thing fits nicely under the cockpit rail and from the pilot's position is just barely visible, yet can be accessed easy. In the event that icing conditions occur, the fitting can be unscrewed and the plug removed for cabin venting.
RV-8 #82880 N998RV
251.37 KB |
17026 Time(s) |
160.45 KB |
17026 Time(s) |
162.27 KB |
17026 Time(s) |
Kelly McMullen
Posted: Mon Apr 19, 2010 7:42 pm Post subject: Check Valve For Static System Cabin Venting... |
Not sure where you are finding this "requirement". #1. There is no IFR
certification of OBAM aircraft. #2.You only have to meet the
requirements of 91.205, para a, b, c and d. There is no mention of
alternate static source in that FAR. You can't fly IFR until you
complete Phase I and your operating limitations will state after Phase
I that for night VFR you have to meet 91.205 C and for IFR meet 91.205
D. It is up to you, the builder to decide if you need anything else.
If your static system is at all like the RV-10, with a port on each
side of the tailcone, and you incorporated an uphill section to the
top of the tailcone to join the lines from each port, there really is
no need for an alternate static source. Mooney used the same design
and through the 1960s had no alternate source and no drain. Only after
Part 23 was issued did they start incorporating those features. IMHO,
just adds complexity and potential for leaks. Perhaps I would think
differently if you were based outdoors in Oregon or NJ, but hangared
in most parts of the country, you will almost never get any water into
the system.
Kelly
#40866
On Mon, Apr 19, 2010 at 1:50 PM, Matt Dralle <dralle(at)matronics.com> wrote:
Dear Listers,
Thanks!
RV-8 #82880 N998RV
A&P/IA, EAA Tech Counselor
KCHD |
sean(at)stephensville.com Guest
Posted: Mon Apr 19, 2010 7:43 pm Post subject: Check Valve For Static System Cabin Venting... |
Matt,
Really enjoy your videos. Nice work.
Here's an interesting idea for an alternate source:
http://www.rv7blog.com/2008/11/09/alternate-static-air-valve. Safeair
has an alternate source kit, but it seems it would be pretty easy to do
yourself: http://www.safeair1.com/PS_1.htm near bottom of page.
-Sean #40303
On 4/19/10 3:50 PM, Matt Dralle wrote:
| Quote: | Dear Listers,
Thanks!
RV-8 #82880 N998RV
glastar(at)gmx.net Guest
Posted: Tue Apr 20, 2010 1:43 am Post subject: Check Valve For Static System Cabin Venting... |
Hello Matt,
simple, still unscrewing in icing condition would not be my thing.
In 2007 I've posted that once:
hopefully attached, what I did (on a Glastar) a Curtis Drain Valve
CCA-1550 together with a T and two elbows to fit the static line.
And I did an inflight check, error is 4 KIAS to high indication.
br Werner
27.84 KB |
17014 Time(s) |
johngoodman
Posted: Tue Apr 20, 2010 4:20 am Post subject: Re: Check Valve For Static System Cabin Venting... |
Try one of these miniature air control valves from McMaster-Carr, Clippard, or AMR.
2.04 KB |
16998 Time(s) |
2.39 KB |
16998 Time(s) |
6.31 KB |
16998 Time(s) |
Charles Usery
Joined: 14 Jun 2007 Posts: 6 Location: Ferndale, Washington
Posted: Tue Apr 20, 2010 7:07 am Post subject: Check Valve For Static System Cabin Venting... |
Kelly,
You may be right on the requirements but I just had the Seattle MIDO come and inspect my RV-10 and on the list of items they wanted to see was the Alternate Static Source.
Since I had this installed we did not discuss if it was optional/required. Just wanted all to know that these FAA inspectors were looking for it.
Charles Usery
N719PD
Do not Archive
--- On Mon, 4/19/10, Kelly McMullen <apilot2(at)gmail.com> wrote:
Subject: Re: Check Valve For Static System Cabin Venting...
Date: Monday, April 19, 2010, 8:37 PM
--> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)>
the system.
Kelly
#40866
On Mon, Apr 19, 2010 at 1:50 PM, Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)> wrote:
Dear Listers,
Thanks!
RV-8 #82880 N998RV
Status: FSearch & Download, 7-Day Browse, Chat, ; --> http://forums.sp; - List Contribution Web Sbsp; > http://www.======================
_________________ CR Usery
RV-10 N719PD (flying)
38W |
Kelly McMullen
Posted: Tue Apr 20, 2010 7:50 am Post subject: Check Valve For Static System Cabin Venting... |
I appreciate the data point. I think we all know that FAA inspectors are not very familiar with OBAM requirements. Has been discussed many times that there is no IFR certification of OBAM aircraft. I'd still like to see where it is required.
I suspect that the vast majority of RVs are given airworthiness inspection by DARs that are more familiar with what is and isn't required. Tail cone static ports are not exposed to impact in flight icing. Now some aircraft that have a single static port forward of the wing might have an issue, like some Cessnas. Perhaps it is a good question to pose to EAA.
On Tue, Apr 20, 2010 at 8:06 AM, C.R. Usery <drrx60(at)yahoo.com (drrx60(at)yahoo.com)> wrote:
[quote] Kelly,
Charles Usery
N719PD
Do not Archive
KCHD |
Posted: Tue Apr 20, 2010 9:23 am Post subject: Check Valve For Static System Cabin Venting... |
Kelly McMullen wrote:
| Quote: | I appreciate the data point. I think we all know that FAA inspectors are
I've been researching IFR use of non-TSOd equipment and am just as
confused as when I started out. I believe that even if you are OBAM,
you are still subject to a transponder/altimeter certification every two
years.
| Quote: | I'd still like to see where it is required.
I don't think an alternate static port (in the cabin, as it were) is a
requirement. I also don't think it's on the list of the things a DAR is
supposed to look for.
| Quote: | I suspect that the vast majority of RVs are given airworthiness
EAA has a package just for this purpose. It outlines what you need. It
doesn't, AFAIK, say what you DON'T need. I've known DARs that just ask
questions .... because they think these things need to be there ......
and if there isn't an answer that they like they SUGGEST that you add
the widget. I've not heard of a DAR failing an inspection because the
item in question wasn't there or on the list of required widgets.
YMMV
Linn
<mailto:drrx60(at)yahoo.com>> wrote:
Kelly,
Charles Usery
N719PD
Do not Archive
Phil.Perry(at)netapp.com Guest
Posted: Tue Apr 20, 2010 9:48 am Post subject: Check Valve For Static System Cabin Venting... |
Now that I think about it, I don't think there is even a requirement for
Alternate Static even on the certified airplanes.
I may be talking about something I don't know much about, so there is my
disclaimer. But OBAM aircraft flown IFR have to meet the same standards
as certified IFR airplanes.
This is done by the DAR through some creative finger pointing that says
something to the effect of, "After completion of phase I flight testing,
unless appropriately equipped for night and/or instrument flight in
accordance with part 91.205. this aircraft is to be operated under day
VFR."
That means your airplane is a VFR/day aircraft and if you want it to be
anything more than VFR/day, it must comply with the minimum equipment
listed in 91.205. 91.205 outlines the light requirements for night
operations and the instrument requirements for IFR operations.
At no point in 91.205 does it make a reference to alternate static air.
But for what it's worth, I'm installing a Clippard valve in mine.
Phil
Kelly McMullen
Posted: Tue Apr 20, 2010 12:20 pm Post subject: Check Valve For Static System Cabin Venting... |
Yes, transponder and encoder have to meet TSO standards. Encoder may
not be too difficult through FAR 43 Appendix E, but transponder pretty
much will have to have TSO. GPS for IFR has to meet TSO requirements.
Altimeter has to meet same requirements as encoder. Most other
instruments like airspeed and gyros are at your discretion as the
builder. As long as you can fly the assigned clearance accurately with
the instruments you install, I believe you are okay.
On Tue, Apr 20, 2010 at 10:22 AM, Linn Walters
<pitts_pilot(at)bellsouth.net> wrote:
I've been researching IFR use of non-TSOd equipment and am just as confused
as when I started out. I believe that even if you are OBAM, you are still
subject to a transponder/altimeter certification every two years.
KCHD |
dlm46007(at)cox.net Guest
Posted: Tue Apr 20, 2010 7:53 pm Post subject: Check Valve For Static System Cabin Venting... |
It is possible to include a Curtiss valve inside the aircraft that will be opened in the event of a static port icing. I was reminded of this when taxiing to the wash ramp at FFZ. my airspeed read 32 KIAS while taxiing with the static ports taped and pitot cover in place. The EFIS then showed zero when opening the panel valve.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: Tuesday, April 20, 2010 8:27 AM
[quote] Kelly,
Charles Usery
N719PD
Do not Archive
Posted: Tue Apr 20, 2010 7:56 pm Post subject: Check Valve For Static System Cabin Venting... |
check this valve to the left of the Cheltons.
| Quote: | Kelly,
Charles Usery
N719PD
Do not Archive
41.01 KB |
16962 Time(s) |
fehdxlbb(at)gmail.com Guest
Posted: Tue Apr 20, 2010 8:20 pm Post subject: Check Valve For Static System Cabin Venting... |
Sent from my Verizon Wireless BlackBerry
hotwheels
stein(at)steinair.com Guest
Posted: Wed Apr 21, 2010 7:05 am Post subject: Check Valve For Static System Cabin Venting... |
I have a quantity of these on order that I'll at some point have on the
website along with the requisite quick connector that screws directly on to
them. We've used those valves on a lot of panels and planes they are slick,
work well and look pretty good. Anyway, it'll be a couple weeks, but we'll
have them sooner or later!
Stein
Bob Turner
Posted: Wed Apr 21, 2010 10:34 am Post subject: Re: Check Valve For Static System Cabin Venting... |
What do people think of this idea:
I was thinking of permanently leaving my backup (Dynon D-6 most likely) instruments on alternate (cabin) static pressure, and have no "alternate static" valve on the main instruments (most likely GRT).
Yes, they would always slightly disagree with the main instruments. But a static blockage would also be immediately obvious.
_________________ Bob Turner
RV-10 QB |
Posted: Wed Apr 21, 2010 11:06 am Post subject: Check Valve For Static System Cabin Venting... |
This would work .... but why have instrumentation that 'disagrees'.
It's like a dead watch .... accurate time twice a day.
How come you're worried about your static ports becoming blocked, but
haven't addressed a blocked pitot??? Both are subject to ice/water
intrusion ..... but proper plumbing inside the fuse/wing keep that
problem down to a minimum.
I'd put a simple mod to the static line like Matt did.
Linn
Bob Turner wrote:
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=295126#295126
Kelly McMullen
Posted: Wed Apr 21, 2010 11:39 am Post subject: Check Valve For Static System Cabin Venting... |
I have yet to hear of a mechanism for both static ports to get blocked
at the same time. Even with driving rain followed by freezing, only
one side would get blocked, Perhaps if you got mud daubers in both
sides. Blockage should be obvious before or shortly after lift off,
with airspeed being way off. If it makes you feel better, your plan
certainly is a way to always have alternate source of info, but might
drive you crazy with differences in airspeed and altitude.
On Wed, Apr 21, 2010 at 11:34 AM, Bob Turner <bobturner(at)alum.rpi.edu> wrote:
Bob Turner
RV-10 QB
KCHD |
