		vince(at)devonwindmills.c Guest
				 Posted: Tue Apr 20, 2010 4:24 am    Post subject: RotaxEngines-List Digest: 9 Msgs - 04/19/10 |
				My experience of declutched freewheeling propellers is that in event
 of engine off, glide distance is significantly reduced, perhaps worse
 than half.
  This in turn cuts reachable landing spots to a quarter as well as
 reducing time available. Yes you can use it intentionally like a
 spoiler or flap, but you cant "reduce flap" to penetrate ahead.
 Also the disturbed airflow over the tail can give you a nasty surprise
 whe you try to do an accurate landing flare
 Vince Hallam
 Torquay, Devon, TQ1 3LZ
 www.devonwindmills.co.uk
 On Tue, Apr 20, 2010 at 7:58 AM, RotaxEngines-List Digest Server
 <rotaxengines-list(at)matronics.com> wrote:
 [quote] *
  Today's complete RotaxEngines-List Digest can also be found in either of the
  two Web Links listed below.  The .html file includes the Digest formatted
  and Message Navigation.  The .txt file includes the plain ASCII version
  of the RotaxEngines-List Digest and can be viewed with a generic text editor
  HTML Version:
     http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 10-04-19&Archive=RotaxEngines
  Text Version:
     http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 10-04-19&Archive=RotaxEngines
                            RotaxEngines-List Digest Archive
                      Total Messages Posted Mon 04/19/10: 9
  Today's Message Index:
      1. 08:37 AM - Re: Fuel consumption for the 912S  (John Goodings)
      2. 09:06 AM - Re: Re: Why exactly shouldn't you run a 914 without a prop?  (Noel Loveys)
      3. 09:08 AM - Re: Re: Why exactly shouldn't you run a 914 without a prop?  (Gilles Thesee)
      4. 09:14 AM - Re: Re: Fuel consumption for the 912S  (Gilles Thesee)
      5. 11:34 AM - Re: Why exactly shouldn't you run a 914 without a prop?  (rparigoris)
      6. 01:29 PM - Re: Why exactly shouldn't you run a 914 without a prop?  (rparigoris)
      7. 03:15 PM - Re: 912s motor mount question  (Guy Buchanan)
      8. 03:52 PM - Re: Why exactly shouldn't you run a 914 without a prop?  (lucien)
      9. 07:06 PM - Desser 4.00-6 8 ply and 6 ply LSA tire  (Roger Lee)
  ________________________________  Message 1  _____________________________________
  Time: 08:37:05 AM PST US
  Subject: Re: Fuel consumption for the 912S
  People have been quoting fuel consumption figures for the Rotax 914
  recently.  The figures quoted seem rather high.  What fuel consumption do
  people get with the Rotax 912S (100 HP)?  We have measured it pretty
  carefully over quite a number of hours, and we are getting slightly under
  16 litres/hr (4.34 U.S. gal/hr) at 5200 RPM cruise.  We use mainly 91
  octane mogas without ethanol additive, but probably 1/3 of the fuel used
  is 100 LL because we don't have a choice at many small airports in
  Ontario.  Here are other details of our aircraft, but I'm not sure they
  are very relevant to fuel consumption.  Our aircraft is a CH601HD with a
  66-inch, 3-blade, GSC prop flying with 2 people (and 1 small Italian
  greyhound!) near 1200 lbs gross weight.  Because of that thick wing, our
  cruise is only about 100-105 mph.
  John Goodings, C-FGPJ, CH601HD with R912S, Carp/Ottawa/Toronto.
  ________________________________  Message 2  _____________________________________
  Time: 09:06:03 AM PST US
  Subject: RE: Re: Why exactly shouldn't you run a 914 without
  a prop?
  Lucien:
  Dave has a video up on you tube where he hand props a 582 in the middle of
  winter up to his backside in snow.  While rotax has good pull cord starters
  they have to come off to put on the standard electric starter.  Being able
  to hand prop a plane can be literally a life saver on a cold Ontario day.
  Noel
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		lucien
				 Posted: Tue Apr 20, 2010 4:56 am    Post subject: Re: RotaxEngines-List Digest: 9 Msgs - 04/19/10 |
				 	  | vince(at)devonwindmills.c wrote: | 	 		  My experience of declutched freewheeling propellers is that in event
 than half.
 Vince Hallam
 Er....,
 With my clutch equipped FSII I noticed neither of these problems. Compared to another FSII that ran a 66" TPI on a 503 B box (no clutch), my glide ratio engine-off was noticeably less than his when engine-off, but nowhere near worse by half.
 Also, I never noticed any disturbed airflow over the tail due to the freewheeling prop. Rudder and elevator control was nominal at all times.
 At engine-idle, it glided like a Kolb with no troubles or wierdness at all.
 The drag effect could be more on a front engined tractor where the prop is unobstructed, tho. But on my Kolb, it was a non-event.
 LS
  _________________ LS
Titan II SS |
