Pat Reilly
Posted: Tue Apr 20, 2010 7:08 am Post subject: Gas fitting sealant |
KFer's, What is the best sealant to use for fittings into worn threads on the plastic header tank. I am using the red hard setting 3M pipe sealant. I also have some black non hardening 3M. But, it is messy as hell to use. My 1st experience with it wasn't successful. I had it all over everything but the threads and it didn't seal. In addition my post script has been Mod 3 582 Rebuild. N942EJ , "Its an airplane again" to quote my test pilot yesterday after 1st flight. Exciting as Hell to see a
2 1/2 year total rebuild project rise from the ashes and take flight, even if someone else is doing the flying.
Pat Reilly
Mod 3 582 REBUILT
Rockford, IL
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
Lynn Matteson
Posted: Tue Apr 20, 2010 8:11 am Post subject: Gas fitting sealant |
Good going, Pat. It's nice to be able to change the signature isn't it?
I use Permatex sealer thta comes in a tube....it's a lot stiffer than
the brush-on stuff, and I'm pretty sure the container says "non-
hardening".
Lynn Matteson
Jabiru 2200, #2062, 915.1 hrs (since 3-27-2006)
Countdown to 1000 hrs~85 to go(97 days to go)
Sensenich 62"x46" Wood (summer)
Rotec TBI-40 injection
Status: flying (and learning)
On Apr 20, 2010, at 10:24 AM, Patrick Reilly wrote:
| Quote: | KFer's, What is the best sealant to use for fittings into worn
Pat Reilly
Mod 3 582 REBUILT
Rockford, IL
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
www.matronics.com/contribution _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Guy Buchanan
Posted: Tue Apr 20, 2010 9:38 am Post subject: Gas fitting sealant |
At 07:24 AM 4/20/2010, you wrote:
| Quote: | What is the best sealant to use for fittings into worn threads on
Best I've found after lots of trials is 2-part polysulfide sealant:
http://www.aircraftspruce.com/catalog/appages/ps890.php
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 400 hrs. and counting
Deceased K-IV 1200
A glider pilot too. |
mikeperkins
Posted: Wed Apr 21, 2010 12:20 pm Post subject: Gas fitting sealant |
The best fuel sealant that I’ve found for threaded fittings is Dow 730 Solvent Resistant Sealant. It was specifically designed by Dow for use with fuel and other solvents. It’s been on my airplane for 16 years now. It doesn’t harden, so it doesn’t crack. Also, it really doesn’t have to cure before you let gasoline at it – the fittings are ready to use right away. But it’s not cheap. Sit down for this – it costs $99.50 for a 3-oz tube from Aircraft Spruce. Years ago I convinced Phil to start stocking it. At first he thought I was crazy. Maybe you all will, too. But no fitting has ever leaked with it. A tube will probably do 10 airplanes, which is why I loan it to my friends. We have all had good experience with it. I’ve kept mine in a frig since I bought it and it’s still good.
- Mike
Pat Reilly
Posted: Wed Apr 21, 2010 1:07 pm Post subject: Gas fitting sealant |
Mike, Thanks for the recommendation. I put mine back together today with the Permatex non hardening that I already had and that Lynn says he uses. I'll put gas in it tomorrow. If it leaks again, I will bite the bullet and try the stuff you recommend. Did you use it on fittings going into plastic tanks with worn threads?
Pat Reilly
Mod 3 582 REBUILT
Rockford, IL
On Wed, Apr 21, 2010 at 3:18 PM, Perkins, Mike <Michael.Perkins(at)rauland.com (Michael.Perkins(at)rauland.com)> wrote:
- Mike
arget="_blank">http://www.matronics.com/Navigator?Kitfox-List
ttp://forums.matronics.com
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
mikeperkins
Posted: Thu Apr 22, 2010 6:57 am Post subject: Re: Gas fitting sealant |
Pat, I've never used Dow 730 on anything with worn threads. It's not a structural material, so it wouldn't add strength. I suppose it would depend on how worn the threads are. If the fitting doesn't stay put on its own without some kind of goop, I might recommend drilling and tapping to the next larger size. Another possibility is to glue on a fiberglass or aluminum doubler plate drilled and tapped for your fitting. I'd use fiberglass resin for the fiberglass doubler. However, if you decided on an aluminum doubler plate, I'd use 3M structural adhesive. It so happens I've used this structural adhesive to attach aluminum fuel-gauge bosses to fiberglass tanks and it's worked well. Either way, I don't see any reason a doubler plate wouldn't work.
Pat Reilly
Posted: Thu Apr 22, 2010 1:46 pm Post subject: Gas fitting sealant |
Mike, Thanks for the info. I guess the next size bigger would be the best way. The threads stilll hold and are tight. I used Permatex non hardening. Filled the tank today and no leaks. guess I'm OK. Just makes you wonder when the stuff is still barely tacky after a day to set up.
Pat Reilly
Mod 3 582 REBUILT
Rockford, IL
On Thu, Apr 22, 2010 at 9:57 AM, mikeperkins <michael.perkins(at)rauland.com (michael.perkins(at)rauland.com)> wrote:
| Quote: | --> Kitfox-List message posted by: "mikeperkins" <michael.perkins(at)rauland.com (michael.perkins(at)rauland.com)>
http://forums.matronics.com/viewtopic.php?p=295273#295273
www.matronics.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
