		Thom Riddle
				 Posted: Tue Apr 20, 2010 12:33 pm    Post subject: Excellent treatise on LOP operation |
				With all of the recent discussions on operating Lean of Peak and EGT variation among cylinders I thought it would be useful to post a link to an excellent treatise on the subject, including the fundamentals of 4-stroke engine operation. Those who think they really understand 4-stroke engines well, may be tempted to skip the first part. I suggest you not skip this part no matter how well versed you are on the subject.
 http://www.buy-ei.com/Manuals/The%20Pilots%20Manual%20(by%20EI).pdf
 If you have already seen and read this, great. If not have fun reading this long but informative article and learning what we all should know to operate our engines properly for long life and efficiency.
 Thom Riddle
 Buffalo, NY
 http://sites.google.com/site/riddletr/a&pmechanix
  |  | - The Matronics JabiruEngine-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?JabiruEngine-List |
  _________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
		BobsV35B(at)aol.com Guest
				 Posted: Tue Apr 20, 2010 1:59 pm    Post subject: Excellent treatise on LOP operation |
				Good Afternoon Thom,
  E.I. makes great product and I applaud their effort to spend time and money  trying to write something that will help us all operate our engines safer and  more efficiently.
  Unfortunately, they have taken the bait and made a number of very wrong  interpretations of fact. It would take a full fledged engine course to refute or  reevaluate each statement in their lengthy narrative, but it is a very poor  document.
  There is no doubt that when an engine has very poor fuel distribution  between cylinders it is going to be difficult to operate well. The E.I products  do a fine job of telling the operator just how good that distribution really  is.
  E.I. spends a lot of time presenting excellent information and then asks  engine rebuilders how an engine should be operated. That is a completely  irrational method of evaluating the problem.
  I agree that most engine shops see a lot of heat damaged engines. If they  assume the engines are being damaged because the pilot leaned when he should not  have, they are making an unwarranted accusation.
  My personal opinion is that a very high percentage of heat damaged engines  are seen because the engine is not rich enough during takeoff and other high  power operations, but that is rarely because the pilot has intentionally leaned  the engine. It is more commonly caused by the engine distribution being so bad  that some cylinders ARE operating way too lean or that the fuel system is not  providing enough fuel to avoid detonation at the high power settings. Both  Continental and Lycoming tell us that you can run at any mixture setting you  want when operating at lower power settings. E.I. correctly states that  Continental sets that point at 65 per cent power and Lycoming calls for 75  percent.
  EI made a gross error when they said that the engine runs it's hottest and  that the valves run their hottest at peak EGT.
  That is just not true!
  The engine runs it's very hottest close to best power. Best power is when  you are getting as much power as can be gotten from the amount of air the engine  is sucking in. That is close to the hottest place it can run. The actual hottest  point is just about 40 degrees Fahrenheit on the lean side of best power, but  still about 60 degrees rich of peak EGT.
  Once again, completely discussing this whole subject is far beyond what I  should be doing here, but I am really saddened that a Company such as E.I. puts  out such drivel.
  I have been very pleased with every product I have purchased from E.I and  their service has been excellent.
  They should stick to what they know something about and not present  a false interpretation of what has been taught by Taylor and others. LOP  operations can make an engine last a LOT longer. The airlines ran their big  round engines leaner than Peak EGT for most of the round engines lives. Many of  us have several thousand hours behind various big bore engines being operated on  the lean side of best power. It works!
  Engines last longer and burn less fuel at equivalent cruise speeds. Best  BSFC is a good thing and it was hardly mentioned by E.I. Very Sad.
  Happy Skies,
  Old Bob
  AKA
  Bob Siegfried
  Downers Grove, Illinois.
  Lean side operator for almost sixty years.
   In a message dated 4/20/2010 3:33:48 P.M. Central Daylight Time,  riddletr(at)gmail.com writes:
   	  | Quote: | 	 		  http://www.buy-ei.com/Manuals/The%20Pilots%20Manual%20(by%20EI).pdf
		Thom Riddle
				 Posted: Tue Apr 20, 2010 3:29 pm    Post subject: Re: Excellent treatise on LOP operation |
				Old Bob,
 I appreciate your feedback on the E.I. document. I did not catch their error stating the the hottest an engine gets is at/near peak EGT because I already knew that it is much closer to peak power than peak EGT. Common sense will tell you that, and because it is common sense I choose to believe that the statement as you found it was probably an accidental error on their part. Why the editors did not catch that is another question.  However, they did not dispute the fact that LOP operation, the primary thesis of the paper, is far better for longevity than near highest power.
 I also agree that surveying rebuild shops is not the best way to get the information that they stated they were looking for, but doing that did satisfy another (unstated) purpose which is that ignorant pilots are the cause of most engine longevity problems and therefore every pilot should buy their product. This document, if read and understood by all pilots (errors and all) would go a long way toward reducing the number of pilot induced premature engine overhauls.
 With the exception of some errors, either out of ignorance or misinterpretation, or willful misrepresentation (I doubt this), I maintain that the document has some value. Of course, you are free to disagree vehemently with me.
 As you noted, different engine manufacturers specify different % power over which LOP is not good for the engine. Jabiru apparently uses 70% power since the jet needle they designed for the Bing 94 begins getting much richer at approximately that power setting, assuming the prop used is within the rpm specs. they recommend.
Buffalo, NY (9G0)
- Anonymous |
				 Posted: Tue Apr 20, 2010 4:18 pm    Post subject: Excellent treatise on LOP operation |
				Good Evening Thom,
  Not only will I not disagree vehemently, I will agree  completely.<G>
  I think it is great that they bothered to publish what they did, I just  wish it contained more balanced recommendations. There is a lot of good  information there for those who wish to study it carefully.
  I really like E.I and regularly recommend as well as use their  products.
  Until we get electronic fuel flow and ignition systems that can handle it  all, it is up to we aviators to understand what is happening.
  The best short course on engine management that I am aware of is the one  presented by some associates of Tornado Alley Turbo. (The folks who make the  factory installed turbo for the Cirrus) They teach a two and a  half day weekend course that is outstanding. The same course is available  in a self study mode, but attending the course with a bunch of eager aviators is  a lot more fun!
  As a very minor point, if we can get enough turbo charging, it is possible  to run lean of peak safely at powers of 90 percent or more!
  As Always, It All Depends!
  Happy Skies,
  Old Bob
   In a message dated 4/20/2010 6:30:33 P.M. Central Daylight Time,  riddletr(at)gmail.com writes:
   	  | Quote: | 	 		  -->    JabiruEngine-List message posted by: "Thom Riddle"    <riddletr(at)gmail.com>
 Old Bob,
 Thom Riddle
 Buffalo, NY
 Kolb Slingshot    SS-021
 Jabiru 2200A #1574
 Tennessee Prop  64x32
		jetboy
				 Posted: Fri Apr 23, 2010 3:22 pm    Post subject: Re: Excellent treatise on LOP operation |
				The fact that Jabiru start leaning below around 70% power does not imply they approve of running the engine LOP at any time.
 The econony jetting never operates in the LOP zone, even the first version which was savagely lean in some circumstances, did not operate on the lean side of peak EGT at any throttle setting. (Arguably it would have been better to have operated LOP than in the "just ROP" danger zone that the initial economy kit put it) Jabiru since revised the jetting about 4 times to get it safe, according to the JSB.
 I'm just making the point here that LOP means lean of the peak EGT that occurs  while manually leaning the mixture, at the current operating power setting. LOP operation can be confirmed by applying carb heat and observing an increase of EGT, rather than the usual decrease, that occurs when the mixture is at or rich of peak EGT.
 its good to see the Aerocarb and Rotec injector carbs being used but won't take the risk or expense with mine as I've already replaced 4 exhaust valves at 310 hrs and feel a top overhaul is going to occur in a similar time. I would consider doing it on a new engine once the track record of those engines  proven, but mine's half cut already and I want it reliable for the remainder, theres enough other issues to be concerned about.
 Ralph
 [As you noted, different engine manufacturers specify different % power over which LOP is not good for the engine. Jabiru apparently uses 70% power since the jet needle they designed for the Bing 94 begins getting much richer at approximately that power setting, assuming the prop used is within the rpm specs. they recommend.[/quote]
  _________________ Ralph - CH701 / 2200a |
