rob10(at)tlb.sympatico.ca Guest
Posted: Wed Apr 21, 2010 5:41 am Post subject: Fuel pump rebuild |
Hi all, anyone knows the part number for a rebuild kit for the fuel pump on a 912 and a good place to buy it?
thanks
Jack
Roger Lee
Posted: Wed Apr 21, 2010 4:41 pm Post subject: Re: Fuel pump rebuild |
No rebuild kit for the mechanical 912 pump. It is sealed. You have to buy the pump.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Dick Maddux
Posted: Thu Apr 22, 2010 5:55 am Post subject: Fuel pump rebuild |
Jack,
You will have to buy a new pump. They come with or without the hoses.As you are going to have to buy a new pump anyway check out the new "billet pump" It is a far better quality pump made for the 912/914. I saw them at Sun-n-Fun. There is no doubt that this is the pump I will get when mine craps out ! It is made in the USA,smaller than the original pump. It has no diaphragm,valves,rocker arm,or gaskets. It is made of hardcoated 6061-T6 aluminimun with stainless steel internal parts. It only flows as much fuel as the engine requires. The 912 pump is $368.00 and the 914 $396.00 If interested the outfit is: Corbi Air INC, Salem ,Ohio 877-267-2424.
Dick Maddux
Fox 4
Milton,Fl
taildragon(at)msn.com Guest
Posted: Thu Apr 22, 2010 6:59 am Post subject: Fuel pump rebuild |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]-->
"... when mine craps out !..." Do these fail all at once or gradually? Are there any warning symptoms that the pump is about to fail?
vetdrem
Posted: Fri Apr 23, 2010 3:30 am Post subject: Re: Fuel pump rebuild |
I just installed the second new pump on my 912. At about 120 hr. run time, I noticed a small amount of gas at the vent hole on the bottom side of the diaphragm. Nothing to do except write a check for $182 (includes shipping) to get a new one. I wasn't flying the Kitfox much at the time, and after about 75 hrs and over a years time on that pump, it started leaking again. I called Pam at Leading Edge Air Foils to order a new one and to complain loudly. She sold me a new one and had me fill out the paperwork for a warranty claim. It was well beyond the warranty period, but she was able to get the factory to cover it.
The two points that I learned from this is, 1) a pump is good for about 100 hours on my airplane, and 2) buy from Pam at LEAF, she will do what ever she can to make things right.
Louie
KeysFox
Posted: Fri Apr 23, 2010 4:37 am Post subject: Fuel pump rebuild |
A friend who works with one of the light sport factories mentioned that
Rotax has been seeing failures of fuel pumps on new engines recently. My
bet is Rotax will get it sorted out fairly quickly, in the mean time there
may be some failure prone units within the delivery system.
As an aside, the fuel pump on my senior citizen 912 lasted over 15 years
when it developed a small oil leak which the folks at Lockwood picked up
on instantly.
B Jones
Kitfox IV
N154K
Kitfox-List message posted by: "vetdrem" <vetdrem(at)hotmail.com>
Louie
http://forums.matronics.com/viewtopic.php?p=295379#295379
_________________ B Jones
N154K
443-480-1023 |
