jonlaury
Posted: Fri Apr 23, 2010 10:31 pm Post subject: Big load on BAT BUS |
In an attempt to keep redundant critical items from the same bus, I have placed the fuse (10-15 amp) for my EFI injectors on the Bat Bus.
However, this violates BoB N's limit of <7a on that bus. How does one deal with this? I would like to keep it on the Bat Bus so if both alts go down, my plane doesn't. I know it's unlikely, but if I'm on the back up alt, I'd still like to know that the Bat is in reserve.
The sister fuse is on the E-bus.
Also, the feed from the bat to the bat bus is about 20". It will come through the FW with a bundle of wires in firesleeve via a "towel bar" pass through. I am contemplating sheathing it in SS braid for crash protection. Good or bad idea? Effective or no?
jonlaury
Posted: Fri Apr 23, 2010 10:38 pm Post subject: Re: Big load on BAT BUS |
Never mind about the SS sleeve question. It will only be a 10 gauge wire and I will 18 ga fuselink it at the battery.
J
Posted: Sat Apr 24, 2010 6:08 am Post subject: Big load on BAT BUS |
At 01:31 AM 4/24/2010, you wrote:
Then you need a "mini-contactor" at the battery
bus as illustrated in Z-32, except that the
feeder is for the EFI instead of the E-bus.
It would be nice if it were a solid state
relay. I believe Eric Jones still offers
on.
Posted: Sat Apr 24, 2010 7:08 am Post subject: Big load on BAT BUS |
At 01:38 AM 4/24/2010, you wrote:
This sounds like another "loose cannon"
implementation of fusible links. Fusible
links are ROBUST circuit protection and should
never be used in an always-hot feeder from
a battery. If you've attached a wire to
a battery that calls for this kind of circuit
protection, it should enjoy upstream, crew-
controlled management of power.
As a general rule, please do not add fusible
links to any application not already illustrated
in the Z-figures without discussing it here
on the List . . . and I can tell you in advance
there's a 90+ percent chance that the proposed
application is not recommended.
Always-hot feeders should be breakered at
5A or less, fused at 7A or less. Anything
larger should still take a fuse or breaker
but CONTROLLED IMMEDIATELY ADJACENT to
the bus with a relay like that shown in Z-32.
klehman(at)albedo.net Guest
Posted: Sat Apr 24, 2010 7:23 am Post subject: Big load on BAT BUS |
There are details that aren't mentioned but I would be cautious with
this. I'd only recommend an additional mini contactor if it is truly
redundant and can't fail the engine. Risk from engine stoppage is likely
far higher than the risk from electrical fire. Other considerations
might be whether the EFI system already has a relay to supply injector
power - many do have an ecu controlled relay that might be easily placed
near the battery. Or is there a mechanical switch in the injector
circuit - there is in my system and it is close to the battery which is
under the instrument panel. The 10 amp fuse is at the battery.
Ideally a redundant engine control system would be powered by its own
power source with no shared wiring.
To understand where I am coming from, understand that the so called
"redundant" electronic engine systems that I've examined do not come
close to true redundancy. Most do not have dual injectors and most share
a single feed to the injectors.
Ken
Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
> <jonlaury(at)impulse.net>
on.
jonlaury
jonlaury
Posted: Wed Apr 28, 2010 8:19 am Post subject: Re: Big load on BAT BUS |
| klehman(at)albedo.net wrote: | There are details that aren't mentioned but I would be cautious with
this. ..snip...
Ken
Ken,
Thanks for your observations and I'm sorry for the delayed response. My ISP has been down for awhile. It's not often that we have rain and low temps in April in Central Calif and the wireless system antenna on a 6500' peak took a load of ice and collapsed.
My EFI system is the quasi-redundant type that you referred to. A single ECU, injectors, TPS, etc. I inquired about "dualing" up the system but they said that they had tried that and that the result, because of the additional complexities, was a far less reliable system than the single system. SDS has accumulated 15,000+ flight hours, over 12,000,000 ground ops hours and bench top set up that has been firing away, 24/7, for years, all without a single equipment failure that was not caused by customer wiring/installation errors. MTBF far exceeds that of any reciprocating engine. I decided that the track record that Simple Digital Systems has accumulated gave me sufficient confidence to run the single system.
BUT... as long as I had multiple sources of power (2 alts, 1 bat), I wanted to hedge my bets by connecting my single EFI to all 3, via Z-13. The Z-32 contactor add-on will be the third power source after losing two alternators.
