180 turn back to the runway video
Goto page Previous  1, 2, 3  Next
lcottrell
PostPosted: Tue Apr 27, 2010 8:52 am    Post subject: 180 turn back to the runway video Reply with quote
I found in my experiments with this situation that a slow flat turn was better than a steep quick turn. Keeping that in mind if there is any increase in G forces it was negligent, therefore the stall would not increase. Of course I had VG's Smile
Larry
Note: If you forward this email, please delete the forwarding history, which includes my email address.
by0ung(at)brigham.net
PostPosted: Tue Apr 27, 2010 9:08 am    Post subject: 180 turn back to the runway video Reply with quote
his prop is going to spin and slow him down a lot. All he had to do was to apply throttle and he is running again, so the danger that he put himself into was no worse than any power off landing, whether it be straight in or not.
Have you ever heard of an accelerated stall. It usually happens when yanking and banking. Maybe I am out of place because I have not seen the video. But I have not seen these thoughts expressed in this thread. If the turns are less than 30 deg and the g load less than 1.5,, you may be ok… if the turn is 60 or more deg bank and g load 2 or above. You best know what the stall looks and feels like, and at what speed, in that configuration. In these conditions the stall can occur well above the straight and level stall speed. And a stall at a high bank angle at 500 ft and under can cause a sudden end to a very good day. Even if your engine is running.
Boyd Young
Jason Omelchuck
PostPosted: Tue Apr 27, 2010 9:12 am    Post subject: Re: 180 turn back to the runway video Reply with quote
Hello Pat,
The wind would have to be blowing on the order of 10 to 15 knots (an estimate) down the runway to be in danger of running out of runway on the landing roll.
I recommend you not taking this information and applying it to your airplane. From your description of the way you plane can take off, it obviously has much different flight characteristics than mine. I would highly recommend you go to altitude and practice full power climb to descending 180. If you get comfortable doing them at altitude, you may want to work up to finding a nice safe place and doing some testing yourself. Just hearing about someone else doing it will not replace training or practice.
Best Wishes
Jason
pj.ladd(at)btinternet.com wrote:
Jason Omelchuck wrote:
Hello All,
One of the things I have always wanted to test was the height required to
get back to a runway after take off.>>
Neatly done and a good video.. The cut back of the engine and the lowering
of the nose were simultaneous. In a real emergency you will lose a couple
of seconds at least wondering `What the *******has happened`. Also there
was no or very little wind. A few knots on your nose turning rapidly to a
few knots up your tailfeathers will reduce your flying speed and INCREASE
you ground speed and the length of your landing run considerably.
You took off from pretty well down the runway and consequently had a good
length of runway behind you to land on. My Xtra would have been at 500 feet
while you were still on the ground and in the event of a 180 degree turn
back there would have been considerably less useable runway.
I dont know how much difference there is in the glide produced by a stopped
prop as opposed to a windmilling one., perhaps someone has the figures.
Thanks for doing the experiment. I shall make sure I do not turn back at
500ft or less.
Cheers
Pat
Jason Omelchuck
PostPosted: Tue Apr 27, 2010 9:15 am    Post subject: Re: 180 turn back to the runway video Reply with quote
Hello Boyd,
Again, a descending (power off) turn at constant air speed is a 1G maneuver.
Jason
[quote="by0ung(at)brigham.net"]his prop is going to spin and slow him down a lot. All he had to do was to apply throttle and he is running again, so the danger that he put himself into was no worse than any power off landing, whether it be straight in or not.
Boyd Young
Dana
PostPosted: Tue Apr 27, 2010 9:19 am    Post subject: 180 turn back to the runway video Reply with quote
At 11:00 PM 4/26/2010, Jason Omelchuck wrote:
In a descending (power off) turn at constant airspeed your airplane will stall at the same speed it does straight ahead with power off...
Jason,
This is simply not correct. I suggest you review "accelerated stalls". In a coordinated turn, the stall speed increases as a function of the bank angle. The effect is small for shallow turns, but, for example, in a 60° banked turn when you're pulling 2g, the stall speed is 41% higher.
Trying to turn too tight at low altitude, whether it's a flat skidding turn leading to the inside wing stalling, or an accelerated stall, is what does in a lot of pilots.
-Dana
Illegal aliens have always been a problem in the United States. Ask any Indian. [quote][b]
Jason Omelchuck
PostPosted: Tue Apr 27, 2010 9:25 am    Post subject: Re: 180 turn back to the runway video Reply with quote
Hello Dana,
If you are not descending and under power you are correct. If you are power off and loosing airspeed, you are correct. If you are power off and descending at a constant airspeed, it is a 1G maneuver.
Jason
Jason,
This is simply not correct. I suggest you review "accelerated stalls". In a coordinated turn, the stall speed increases as a function of the bank angle. The effect is small for shallow turns, but, for example, in a 60� banked turn when you're pulling 2g, the stall speed is 41% higher.
-Dana
Eugene Zimmerman
PostPosted: Tue Apr 27, 2010 9:38 am    Post subject: 180 turn back to the runway video Reply with quote
Kolb pilots,
Another thing that I always try to make a habit when I take off is
whenever I reach the point where an abort straight ahead back to the
remaining runway becomes doubtful or unlikely is to drift off to the
downwind side of the runway from whatever crosswind there may be, so
that a turn back to the runway is into the wind and also requires less
degree of turn to reach the runway again.
I like to stack the deck in my favor as much as possible when I am
taking off.
Also being aggressive in air speed and bank angle in a turn back
reduces the time required to make a 180 and shortens the distance back
to the threshold.
IOW, Control the airplane, don't let the airplane control YOU. YOU put
the airplane down, don't let the airplane put YOU down.
Gene
On Apr 26, 2010, at 11:00 PM, Jason Omelchuck wrote:
Hello Crystal,
The risk is keeping the turn coordinated so that remains true for
both wings. The tendency is to try to put in too much rudder to
tighten the turn and you then run the risk of the inside wing
stalling. when I first started practicing at altitude, I noticed I
could feel the wing start to bobble at stall and that it would
increase the bank and start the beginning of a spiral. It was a
little unnerving at first, but I noticed I could keep it from
developing by a little opposite rudder and of course getting the
nose down ever so slightly to keep the airspeed up. I did practice
(at altitude) going from a full throttle climb to a descending 180
turn while trying to keep a constant airspeed. One of the things I
think I have learned while doing this close to the ground is that
the fear of hitting the ground is a very ingrained in my brain. It !
is an un-natural act to put the nose down to save yourself from
hitting the ground. I believe this has caused many an airplane
accident because it is just does not make sense, your instinct
really wants to pull back on the stick to extend the glide just that
little bit more. This sensation does not get triggered when flying
at altitude. I believe this is the reason that many a Kolb landing
gear has been bent by people who are used to flying GA aircraft. To
the pilot of a faster airplane, the angle of approach that must be
kept close to the ground before round out is alarming until you do
it many times.
My $.02 worth
Jason
>> Hello All,
>> required to get back to a runway after take off. On Sunday, I got
>> a chance to do some testing and I got a video of it. The runway I
>> am flying from is about 2500 feet long. I found that it required
>> about 500' for me to make the 180 and get back to the end of the
>> runway. I tried it at 400' but the ending was not pretty (nothing
>> bent). The interesting thing is that at 600' I could not make the
>> runway because I had traveled further away from the runway than
>> the extra 100' in altitude allowed me to make up. My engine has a
>> clutch, so the prop windmills at engine idle just like it would
>> windmill if the engine failed.
>> http://www.youtube.com/watch?v=Pn6T8ynRDLk
>> FWIW
>> Jason
>> MKIII Yamaha powered
>> Portland, OR
> Wish I had that many open fields to choose from for emergency
> landing spots.
> Please be careful. Do you know your stall speed on a steep turn?
http://forums.matronics.com/viewtopic.php?p=295828#295828
Last edited by Eugene Zimmerman on Tue Apr 27, 2010 10:41 am; edited 1 time in total
lcottrell
PostPosted: Tue Apr 27, 2010 10:17 am    Post subject: 180 turn back to the runway video Reply with quote
Every thing and every plane is different, and I intend to pursue my findings further, but the turns that I did last spring in testing this theory proved to me that I lost much more altitude in a steep turn than what I did in a slow flat turn. Of course I have VG's and that made my findings different from most of you. I tried it both ways and I found that clam, slow and easy worked the best for me. Your experience may be different!
Larry
Jason Omelchuck
PostPosted: Tue Apr 27, 2010 12:49 pm    Post subject: Re: 180 turn back to the runway video Reply with quote
Hello All,
Here is where this very topic was discussed in detail on this list before. FWIW.
http://forums.matronics.com/viewtopic.php?t=38477&highlight=descending+turn+stall
Jason
jbhart(at)onlyinternet.ne
PostPosted: Tue Apr 27, 2010 1:03 pm    Post subject: 180 turn back to the runway video Reply with quote
At 11:46 AM 4/27/10 -0500, you wrote:
Jack H/Gang:
Do VGs increase lift? The reason I ask is I do not know.
I thought VGs decreased stall speed.
Also, could you explain "twitchyness" during steep turns with the Firefly?
John,
You are correct in that VG's reduce stall speed. Therefore it stands to
reason that if one flys at the previous stall speed or faster, the VG's will
generate more lift than the wing did before the addition of VG's. Also when
in level flight the AOA will be less and the drag associated with that IAS
will be less too.
When I installed the VG's, the 447 was mounted on the FireFly and after I
had changed from 15 inch chord ailerons to 9 inch chord ailerons. The
description of what happened when I installed them can be found at:
http://jackbhart.com/firefly/firefly18.html
What I mean by twitchy is the feeling one gets through the lower cheeks that
things are not going well or as one expects. I had the feeling that if I
pushed the FireFly on a downwind to base bank that it felt like it wanted keep
right on going over onto its back. As a result I never made very steep left
banks. I had no problem with banks to the right. After I mounted the VG's
this sensation disappeared, and flying enjoyment increased.
Jack B. Hart FF004
Winchester, IN
slyck(at)frontiernet.net
PostPosted: Tue Apr 27, 2010 1:25 pm    Post subject: 180 turn back to the runway video Reply with quote
I usually read the responses to a post before I offer my 2 cents. BUT, unless you a re a really low time Kolb pilot
you should eventually pick up on how your wing is feeling. Smooth, low pull turns like we saw in that excellent video
would not cause a problem. -that is as long as the driver has a good feel for load inducement and keeps his buttocks
free from excessive compression. Lowering the nose will do just fine.
Once again, you cannot stall an airplane at zero Gs.
BB
On 27, Apr 2010, at 1:15 PM, Jason Omelchuck wrote:
Hello Boyd,
Jason
Boyd Young
> [b]
http://forums.matronics.com/viewtopic.php?p=295874#295874
Dana
PostPosted: Tue Apr 27, 2010 1:57 pm    Post subject: 180 turn back to the runway video Reply with quote
People argued with me in the previous thread you referenced, but I stand by what I said: It is impossible to maintain a turn at constant airspeed without exceeding 1G, unless your rate of descent constantly increases at an acceleration rate corresponding to the loss of lift due to the bank.
Take a 45 degree bank, for example. In a normal, coordinated, level turn, you pull 1.41G. If you put your aircraft into a 45 degree bank and hold 1G, the vertical component of lift will be only 0.707g; thus you'll have a downward acceleration of 0.3g, or 9.4 ft/s/s, or 566 fpm/s. This means that after one second, your rate of descent will have increased by 566 fpm. After four seconds, you're descending at 2264 fpm, which is a pretty steep dive, and you WILL pull more than one g pulling out of it.
-Dana.
Wernher von Braun settled for a V-2 instead of a V-8. [quote][b]
PostPosted: Tue Apr 27, 2010 3:22 pm    Post subject: 180 turn back to the runway video Reply with quote
The most ignored indicator that indicates stall independent of the ASI and
angle of bank is the AOA meter. Few have them mounted in their
aircraft.
Jack B. Hart FF004
Winchester, IN
JetPilot
PostPosted: Tue Apr 27, 2010 5:12 pm    Post subject: Re: 180 turn back to the runway video Reply with quote
Jason,
That was a great video you did on returning to the runway in the event of an engine failure. The lesson to learn here is not to take a piece of advice like " Never try to return to the runway if your engine quits " and apply it to every situation. Many times Kolb pilots are flying from 5000 foot general aviation runways that you would be close to 1000 feet at the end. If you had houses, or trees in front, 1000 feet of altitude, and 5000 feet of general aviation runway just behind you when the engine quit, only a fool would take the common advice and land into a house or a tree in this situation. As the runway gets shorter, it becomes more dangerous to turn back, and one should look for the best place ahead or even 90 degrees left or right. On a super short runway, the only option will be straight ahead. A good pilot should know about what runway length and altitude will allow a return to the runway if the engine quits in his airplane.
Its needless to say brand new Kolb pilots should not practice this until they know their airplanes well and can do a banked power off turn without stalling. Again, its just a matter of being smart. For most of us, practice like this will make us safer in case of an engine failure. There are always a few new or poorly skilled pilots that are safer never testing the limits of their planes. Trying to apply one rule to everyone, or one rule for every situation just shows a poor understanding of aviation.
Mike
Kolb MK-III Xtra, 912-S
PostPosted: Wed Apr 28, 2010 2:04 am    Post subject: 180 turn back to the runway video Reply with quote
a flat skidding turn leading to the inside wing stalling,>>
Hi Dana,
reminds me of an incident I saw just around the end of the war.
An Albemarle, which was a twin engined light/medium bomber reduced to glider tugging was struggling into the sky from my local field pulling a Waco glider. The glider got out of position and pulled the tail of the Albemarle to starboard. The Albemarles port wing stalled and she dropped into a straight down nosedive with both engines flat out. Unfortunately there was not enough height and she hit the ground about 10 degrees from vertical. The pilot had obviously realised what was happening and dumped the tow line as his plane dropped out of control thus certainly saving the glider pilot from filling his pants or as a worst case causing the glider to crash with its full complement of squaddies aboard.
Sports gliders with their long wing span are prone to this on final turn when they are close to the ground and skid into a flat turn instead of banking properly.
Cheers
Pat
PostPosted: Wed Apr 28, 2010 2:40 am    Post subject: 180 turn back to the runway video Reply with quote
landing roll.>>
Hi Jason,
working the accurate math for that is beyond me but a 10knot windspeed and
say 35knot airspeed at take off is going to produce a ground speed on
takeoff of 25knots. Landing downwind is going to require at least 45 knots
ground speed and to keep proper control, a bit more. That will certainly
take a lot more runway than you expect.
I will tell you how I know. I flew to a fly in last weekend. Viz was not
great and I was non radio. The wind was light and I couldn`t see the
windsock. I saw another a/c in the circuit and decided to follow him around
the circuit. As I turned I lost him in the haze and the next time I saw him
he was on the ground having (I assumed), just landed. I tracked round to
follow and landed in the same direction. I realised that something was not
quite right when the hedge wizzed under me a bit faster than I expected.
Then the plane plonked herself down a bit more solidly than usual and I
found myself charging down the grass and applying brakes hard. I taxied to
the clubhouse where I was given a (richly deserved) b*******ing from the
CFI.
What I had seen was not the other plane landing, but BACKTRACKING after he
had landed. A stupid error whch to salve my pride I shall put down as being
due to the first away flight of the season and not being really switched on
yet.
Take it from me. Down wind landings take MUCH more runway than you expect.
Cheers
Pat
PostPosted: Wed Apr 28, 2010 2:51 am    Post subject: 180 turn back to the runway video Reply with quote
If you bank steeper you descend faster and you are still at 1G.>>
Hi Jason,
If that were the case then any bank angle would not increase the `G`.
Ascending, descending, power on or off. None of these is germane to the
case.
Cheers
Pat
Eugene Zimmerman
PostPosted: Wed Apr 28, 2010 3:48 am    Post subject: 180 turn back to the runway video Reply with quote
expect.
Ok,
You perhaps. What do you expect?
Unrealistic expectations inevitably make pilots unsafe.
Gene,
Watkinsdw
PostPosted: Wed Apr 28, 2010 4:39 am    Post subject: Re: 180 turn back to the runway video Reply with quote
Hi, Gang,
Just for fun, and since it doesn't seem to have been mentioned, when safely practicing at altitude, perform a 270 degree turn to establish your altitude loss.
Unless we take off sideways across a football field, it takes a 45 to return to the runway, and another 45 to line up for landing. All that is after the initial 180.
Richard Pike
PostPosted: Wed Apr 28, 2010 6:54 am    Post subject: Re: 180 turn back to the runway video Reply with quote
Here is a very good video about the "Impossible Turn" as performed by two guys in a C172.
http://www.aerobats.com/seminar_02-07.html
Richard Pike
MKIII N420P (420ldPoops)
Page 2 of 3
