jeff(at)rmmm.net Guest
Posted: Thu Apr 29, 2010 1:12 pm Post subject: Charging Problem Solved |
HI All,
Several people have been asking so I sent this out the other day. For
some reason the list did't except my e-mail address anymore so I had
to sigh up again. On to the reason of this post.
I believe there we're two different things causing my problem but
anyway my problem has been resolved. Not only was there a bad
connected ground... I believe when I quit cooling the regulator it may
have taken it's tole on it as well. Just to clarify some time ago
there was some discussion on making sure the regulator was not getting
very hot so I took the precaution and ran a small scat tube up from
the bottom NACA I wasn't using. About a few months back I didn't re-
connect it thinking it wasn't necessary. Needless to say thats when I
started noticing this problem. Coincidence? After fixing the ground I
re-connected it as I was trying to cover everything. Put 2 or 3 hours
on it last week before I left for a trip. I left it sit while I was
traveling. Flew it some more when I got back. Just connected the
tester to the battery and it's holding 12.7 amps and is at 90%. Before
after a few flights it was down to about 30%. So there it is. Not sure
if the cooler regulator had anything to do with it, but it was still
not charging correctly after I fixed the bad ground. I will keep you
all posted if you like but this time it really looks like I'm good to
go.
Thanks very much for all your help.
Jeff R. N128LJ Gold Rush
steven.pitt2(at)ntlworld. Guest
Posted: Sat May 01, 2010 9:55 am Post subject: Charging Problem Solved |
Jeff R et al,
I too have been experiencing issues with my regulator (I am on my second
after 200 hours and the current one is acting up) and so whilst at Sun'n'Fun
I did some research by talking to Rotax distributors and also to Vans (in
view of the RV12 installation of the 912S).
Today at the Microlight Flyin at my local field, Popham, I also had the
chance to speak to our Rotax distributors and can advise the community of my
findings.
Firstly all the wise heads were advising that the issues with the regulator
seemed to be confined to Europas in the main, the issues being overheating
and pulling too much load. Neither of these conclusions have been
scientifically tested but the anecdotal evidence seems overwhelming towards
the first issue.
Vans have decided to provide an air duct to blow cool air onto the regulator
so they have decided that there must be a cooling issue. Bear in mind that
the RV12 is an LSA machine and therefore must be built according to the
manual - no modifications.
Jeff - your observations also point to this conclusion so thanks for the
input.
Our UK distributor (Conair) has talked to Rotax who say that there should
not be any issues and so are not willing to make any changes. However, the
UK agent has been concerned about the capacity of the regulator on well
equipped 914 Europas and therefore has been exploring the Schicke GR6 (a
German device already fitted by several UK owners). In conversations with
our Club Modifications Rep, Ian Rickard, it has been decided that we will
support Conair with investigating the Schicke in order to obtain an 'all of
type' modification within the rules of the UK Light Aircraft Association. As
I need to change my regulator I have offered to trial fit the regulator, but
I will move it to within the wheel well of my trigear in order to remove any
possibility of overheating influence.
Anyone who has already fitted a Schicke, could you please contact me off
forum so that we can obtain background and backing information towards this
modification.
I do not profess to be an expert on this topic merely an interested and out
of pocket installer.
The Europa club will keep the forum informed.
Steve Pitt
G-SMDH
PS Sorry we did not see you at Sun'n'Fun
pete(at)lawless.info Guest
Posted: Sat May 01, 2010 10:38 am Post subject: Charging Problem Solved |
Hi Steve
Trouble is if you move the location to somewhere cool it will not prove the
Schicke cures anything.
I must be lucky my mono is still running the original regulator after 500
hours mounted on the top of the footwell with no cooling air. Mind you I
only run a single Microair com, a turn co-ordinator and a mode C
transponder, plus occasional bursts of trim and prop pitch. So in my case
it could be the lack of load.
Pete
Posted: Sat May 01, 2010 11:59 am Post subject: Charging Problem Solved |
Steven Pitt a écrit :
| Quote: | Firstly all the wise heads were advising that the issues with the
regulator seemed to be confined to Europas in the main, the issues
being overheating and pulling too much load. Neither of these
conclusions have been scientifically tested but the anecdotal evidence
seems overwhelming towards the first issue.
Steven,
Some years ago we conducted some investigations on the Ducati-Rotax
alternator and regulator, and the Schicke GR-4 in a university electric lab.
The following abstracts of our findings might be of interest :
http://contrails.free.fr/elec_ducati_en.php
http://www.foxpapa.com/spip.php?article429
http://www.foxpapa.com/spip.php?article436
I finally elected to use the Schicke GR-4. The newer GR-6 is advertised
as having better heat rejection properties.
FWIW
Best regards,
Gilles
