Taxi Test
Speedy11(at)aol.com
PostPosted: Wed Apr 28, 2010 6:32 am    Post subject: Taxi Test Reply with quote
Matt,
You are going to be very impressed with the full power takeoff. On your first takeoff, don't rush the throttle forward as you might do in a Cessna. If you do, the P factor and torque will turn the airplane.  Feed power in smoothly and quickly, but not suddenly - if that makes sense. I was surprised at the power on my first takeoff. So much was happening so fast that I was at liftoff speed before I'd checked all the gauges.
I had the same smoking brakes during my taxi test. I did a long taxi and then a run down the runway. I had obviously been dragging the brakes, just as you did, and mine were smoking after clearing the runway. Fortunately, I did only one "abort" down the runway rather than two and my brakes did not get as hot as yours. I believe we need to advise first time builders who are ready to do a taxi test about the problem of inadvertently dragging the brakes. Dragging the brakes is very easy to do and it overheats the brakes and makes a huge mess. I am now very careful about dragging the brakes - although normally you only taxi out to the runway and as soon as you take off the airflow rapidly cools the brakes. The problem will occur if you have to abort the takeoff - better have a fire bottle handy.
I believe new builders should do taxi tests with the wheel pants off. That allows for better brake cooling. I did my taxi test with the pants on and the restricted airflow around the brakes contributed to the problem.
Stan Sutterfield
Oh my... What will FULL throttle be like!?
Speedy11(at)aol.com
PostPosted: Thu Apr 29, 2010 5:51 pm    Post subject: Taxi Test Reply with quote
Taxi tests are fine so long as they are not high speed. The definition of high speed depends on the length of the runway. What Van is concerned about is guys doing a high speed test and inadvertently getting airborne on a flight they are not prepared for. His concern is well founded.
However, if the test run is done on an 8000' runway, the danger diminishes greatly. One could actually get airborne and land again safely on that much runway. I'm not advocating taxi tests that are so fast as to get airborne. I believe 45 KIAS is more than enough for a taxi test.  You will be able to get the nose to pitch up (or raise the tail) without the danger involved with an unplanned liftoff. And a long runway, even if done downwind, allows the airplane to slow in idle power without overuse of the brakes.
I believe hot brakes on RVs occurs because the pilot (I did it) inadvertently rides the brakes during taxi and the wheel pant restricts air flow from cooling the brakes. A single taxi run is all that should be attempted on one day. Two runs in a short time are almost guaranteed to overheat the brakes.
We takeoff and land into the wind due to limited runway lengths.  If one had 3 miles of runway for an RV, then landing with or into the wind makes little difference. The only difference would be ground speed at touchdown which might cause a tiny bit of additional tire wear on downwind landings. However, in most cases, our runway lengths are limited thus dictating taking off and landing into the wind for safety.
Stan Sutterfield
I don't think that Van approves the "High Speed" Taxi. And I agree.
Too many times when people have found themselves off the ground, totally
unprepared.
You also saw the power of TO's and Landings down wind. I don't think there
is an airplane made today that allows more than a 10 knot tailwind.
edwclg
PostPosted: Fri Apr 30, 2010 7:13 am    Post subject: Taxi Test Reply with quote
Just wondering, Is that a new engine and if it is has it been run on a test stand?
Ed Clegg
On Thu, Apr 29, 2010 at 8:50 PM, <Speedy11(at)aol.com (Speedy11(at)aol.com)> wrote:
[quote] Taxi tests are fine so long as they are not high speed.  The definition of high speed depends on the length of the runway.  What Van is concerned about is guys doing a high speed test and inadvertently getting airborne on a flight they are not prepared for.  His concern is well founded.
Stan Sutterfield
unprepared.
et="_blank">http://www.matronics.com/Navigator?RV8-List
tp://forums.matronics.com
n747jg(at)earthlink.net
PostPosted: Fri Apr 30, 2010 7:46 am    Post subject: Taxi Test Reply with quote
My question exactly. My engine builder wanted me to PUSH my airplane to the runway before the first flight, after a few very short test runs, primarily looking for leaks. Prior to that, it was run on a test stand for almost an hour, with sufficient cooling provided.
Jim Gray
N747JG RV-8 180 hours
On Apr 30, 2010, at 9:12 AM, edward Clegg wrote:
[quote]Just wondering, Is that a new engine and if it is has it been run on a test stand?
Ed Clegg
Stan Sutterfield
unprepared.
href="http://www.matronics.com/Navigator?RV8-List">http://www.matronics.com/Navigator?RV8-List
Speedy11(at)aol.com
PostPosted: Sat May 01, 2010 12:33 pm    Post subject: Taxi Test Reply with quote
Yep - I understand. Mine was new also and had been run on a test stand for 1.5 hours. Still I found things during my 3 engine runs of 15 minutes each that I could not have found otherwise. I'm glad I did some short engine runs.
I think Matt's is a new IO-390 also.
Stan Sutterfield
Site Admin
PostPosted: Sat May 01, 2010 5:10 pm    Post subject: Taxi Test Reply with quote
Yes, it is. However, I had Bart run it for 11.5 hours on the test stand. This gets it well past the most critical part of the break-in. The difference in cost was basically the cost of fuel. Well worth the investment and piece of mind.
RV-8 #82880 N998RV
http://www.mattsrv8.com - Matt's RV-8 Construction Log
Status: Test Flying
amorgan53(at)charter.net
PostPosted: Sat May 01, 2010 5:33 pm    Post subject: Taxi Test Reply with quote
tried to post this to matt's channel as a link
but i can't seem to post links in comments sections
of youtube .. maybe they set it up that way
http://www.youtube.com/watch?v=Z1iOcDSVin0
some theme music for the sky
robin(at)PaintTheWeb.com
PostPosted: Sat May 01, 2010 5:39 pm    Post subject: Taxi Test Reply with quote
Snip>>The difference in cost was basically the cost of fuel
Correct for Bart/Aerosportpower.com, their pricing for additional run time
is the way to go (IMHO). Most charge much more / hour.
Robin
