		keithhickling(at)clear.ne Guest
				 Posted: Sun May 02, 2010 12:38 am    Post subject: Overvoltage problem with regulator |
				Hello  all,
 After all the discussion about lack of charging, I have just  developed an
 overvoltage problem after 100 hrs. The regulator has functioned  fine until
 tle last couple of flights, when I noticed that the voltmeter was  flicking
 up and down once or twice a second around a mean of about 13 volts.  Then
 today just before shutting the engine down, I noticed it was reading 16  - 17
 volts on idle, and when I increased to 300 rpm it went up to 18 volts,  with
 the battery ammeter showing a small charge (half amp). So I suut the  engine
 down and looked under the cowl, and superficially all looked well  with the
 regulator and wiring. I didn't have a voltmeter with me, but will  check the
 connections tomorrow.
 The regulator is wired as on the  Europa diagramme, with the R, B+ and C
 leads all connected together and to  the + terminal of the capacitor, and
 through the 30 amp fuse to the main bus  via an alternator output switch.
 I'd be very grateful for any suggestions  / comments from the pundits - does
 this have to be a regulator problem, or  can any wiring or connection issues
 cause this problem? I'll check that I  have battery voltage at the C terminal
 tomorrow, but the connections looked  fine.
 Many thanks in anticipation,
 Keith Hickling,
 New  Zealand.
 Kit 613, 912 uls.
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		jpg12305
				 Posted: Sun May 02, 2010 4:51 am    Post subject: Re: Overvoltage problem with regulator |
				I had such erratic fluctuations once in the past after an annual inspection.
 I took me a while... to simply discover that my ground connection to the battery was loose. The battery was not playing its buffer role.
 I understand you can see some current going to the battery, but there could be some connection to clean or tighten.
 Just my own experience.
 Good luck,
 Jean-Paul
 Europa 332 - France
