Pat Reilly
Posted: Sun May 02, 2010 5:57 pm Post subject: Larger tail Wheel |
Kitfoxers, My model 3 has a Maule tailwheel bracket with the ACS Home Builders small tailwheel. I have the 12" wide Tundra tires on the main gear. Has anybody got a suggestion on a larger tailwheel to compliment the big main gear tires?
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
Av8r3400
Joined: 22 Sep 2008 Posts: 83 Location: North Central Wisconsin (KRRL)
Posted: Tue May 04, 2010 3:19 pm Post subject: Re: Larger tail Wheel |
I've heard guys having good luck with the Matco tail wheels. The 7" pneumatic Matco is larger and lighter than the 6" Maul while not being so tall as to ruin your AOA on the gear. The 8" Matco is a little heavier and much taller, but this may not be an issue for you...
_________________ Thanks,
Av8r3400
Kitfox Model IV-1200 W/912UL & IVO
Kitfox Model IV-1050 W/912UL & Warp
YouTube Videos |
Pat Reilly
Posted: Wed May 05, 2010 2:32 pm Post subject: Larger tail Wheel |
Thanks for the Matco referral. Taller is better for my aplication. I have 4" taller bush gear with tall tundra tires. My AOA is already excessive. Heavier is no problem either.
Pat reilly
Mod 3 582 REBUILT
Rockford IL
On Tue, May 4, 2010 at 6:19 PM, Av8r3400 <theav8rweb(at)yahoo.com (theav8rweb(at)yahoo.com)> wrote:
| Quote: | --> Kitfox-List message posted by: "Av8r3400" <theav8rweb(at)yahoo.com (theav8rweb(at)yahoo.com)>
Av8r3400
http://forums.matronics.com/viewtopic.php?p=296781#296781
ist Un/Subscription,
www.matronics.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
akflyer
Posted: Thu May 06, 2010 12:09 pm Post subject: Re: Larger tail Wheel |
| Pat Reilly wrote: | Thanks for the Matco referral. Taller is better for my aplication. I have 4" taller bush gear with tall tundra tires. My AOA is already excessive. Heavier is no problem either.
Pat reilly
Mod 3 582 REBUILT
hmmm is there such a thing? I have the taller gear and 24" tires, going to 26" tires and still want more AOA. I can drag it in and touch the tail wheel with the mains still a couple feet in the air. This makes for short landings, but takeoffs could be much quicker with a higher AOA.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Pat Reilly
Posted: Fri May 07, 2010 2:24 pm Post subject: Larger tail Wheel |
Len, My experience is drasticly limited as a new pilot. I think your right about AOA. Just as long as you are prepared and don't get airborne before your ready on take off, I guess there is no such thing as excessive AOA..
Â
Pat Reilly
On Thu, May 6, 2010 at 3:09 PM, akflyer <akflyer_2000(at)yahoo.com (akflyer_2000(at)yahoo.com)> wrote:
| Quote: | --> Kitfox-List message posted by: "akflyer" <akflyer_2000(at)yahoo.com (akflyer_2000(at)yahoo.com)>
Pat Reilly wrote:
| Quote: | Thanks for the Matco referral. Taller is better for my aplication. I have 4" taller bush gear with tall tundra tires. My AOA is already excessive. Heavier is no problem either.
> Â Pat reilly
| Quote: | Â Mod 3 582 REBUILT
hmmm is there such a thing? Â I have the taller gear and 24" tires, going to 26" tires and still want more AOA. Â I can drag it in and touch the tail wheel with the mains still a couple feet in the air. Â This makes for short landings, but takeoffs could be much quicker with a higher AOA.
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
http://forums.matronics.com/viewtopic.php?p=296976#296976
lities such as List Un/Subscription,
://www.matronics.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
href="http://forums.matronics.com/" target="_blank">http://forums.matronics.com
          -Matt Dralle, List Admin.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
