				 Posted: Thu May 06, 2010 3:24 pm    Post subject: What a fine airplane! |
				Flying the PH-DIY is much easier than we could imagine.
 May 5th we made our first real trip with the PH-DIY: we went to
 Helgoland (EDXH).
 (Helgoland is a very small island about 30nm North of Germany).
 The longest runway is 480 meter, fairly small, and for that reason only
 allowed for pilots with a minimum of 100 flying hours. Well, the PH-DIY
 came to a stop halfway down the runway.
 It is just about 1 hour flying from our homebase EHHO.
 Our review can be found at www.vfrflights.nl/verslagen/helgoland
 Fuel consumption for an economy cruise of 110 knots IAS is 13 liters per
 hour, not bad!
 With 13 hours on the hobbs we now appreciate the avionics we installed
 and the "user interface". So, for the "not-yet-flying" people, this is a
 list of things we found very usefull:
 - The SmartASS (Talking Airspeed Indicator of Smart Avionics) is a real
 "must have". Apart from a non-panel-space-consuming redundanct backup
 airspeed indicator (I gave it its own pitot), it is a real assistant
 during take off and landing. During take off we set it in talking
 airspeed mode so we can focus on the outside world while monitoring the
 airspeed auraly. During landing, on final, I press and hold the green
 button on the stick for a moment to capture the airspeed, and it
 announces periodically "speed good" if I remain within 5% of the target
 airspeed, or "slow", "very slow", "fast", "very fast" if I stray off
 that speed. It becomes very easy to keep the eyes focussed on the runway
 all the time and correct any speed deviations immediately. It is one of
 the reasons we find landing this airplane so easy: it is like flying
 with a teacher who is telling you what to do all the time.
 - We have the flaps switch on the stick as well. This worked out as
 planned: during take off and landing we keep one hand on the throttle,
 and the other hand on the stick, and it is convenient this way to adjust
 the flaps without moving your hands. It feels natural to adjust the
 flaps with the same hand that also controls the speed and pitch. The
 other hand is for power, prop and  brakes.
 - The Smart Avionics prop controller works perfectly! Easy to use as
 well. The mode button is duplicated on the stick, and the pitch toggle
 is duplicated next to the throttle, so it can be operated with the hand
 resting on the throttle.
 - The Trio Avionics autopilot is another favorite piece of equipment.
 The auto pilot release is connected to the "trigger" of the stick. This
 works particularly intuitive for the Pilot Command Steering: while the
 auto pilot is active, pull the trigger, change heading and release the
 trigger, and the auto pilot continues on the heading just set with
 releasing the trigger. (And of course the auto pilot can also follow a
 programmed GPS route, or direct to a GPS target).
 - The overhead vent is a real winner. Works perfectly and is very
 convenient. A close second are the "ultimate ventilators" at the corners
 of the wind screen. They work, but it is impossible to direct the air
 and regulate the amount of air at the same time. Still we like them.
 The windows at the side are nice for making pictures and avoiding the
 visual distortion of the canopy. Ilona doesn't like these windows so
 much, because they suck her hair out!
 Of course there are also things that didn't work out so well:
 - Forget about an aileron trim. I never used it, except for confirmation
 that it works, and to discover that precisely in neutral the airplane
 flies straight and level. There is nothing to trim. Thinking about the
 time invested to devise this trim tab, what a waste!
 - I don't like the Andair gascolator so much (I have the bigger one). It
 needs to be wire locked (making it less attractive to "field clean" the
 gascolator) and the rubber O-ring breaks far too easily. I spoiled
 already the spares I had, if I break another one this means I'm
 grounded.
 Well, this is it for now, hope it is usefull to someone.
 Frans
				 Posted: Thu May 06, 2010 6:47 pm    Post subject: What a fine airplane! |
				Thanks for the inspiration Frans, and your review of your flight is lovely, though my "Americanishe-schnell-Deutsch" did not allow for much understanding of your text...perhaps I missed the English prompt.
 Fred
 On May 6, 2010, at 4:23 PM, Frans Veldman wrote:
 [quote]Flying the PH-DIY is much easier than we could imagine.
 Helgoland (EDXH).
 Our review can be found at www.vfrflights.nl/verslagen/helgoland[b]
		air.guerner(at)orange.fr Guest
				 Posted: Fri May 07, 2010 9:02 am    Post subject: What a fine airplane! |
				Frans,
  I agree with you regarding the Andair gascolator. I  have been using a GAS 375 for 8 years/700 hours now and it is really a pain  to fit the bowl every time I remove it for service. The problem is the  O-ring which expands while in contact with Mogas. As there is no chamfer  inside the body the O-ring is catched by the sharp angle. Coating the O-ring  with grease helps a lot, but does not solve the problem. Replacing the O-ring at  every 50 hours inspection is an expensive option. More over, there is no way you  can visually check that the O-ring is at the right place as it is masked by  the nut while the bowl is pushed in place. This can be dangerous as you can  have the bowl fitted, the nut tightened and safety wired without knowing  the O-ring is damaged. It happened to me once.  A really bad  design !
  Remi Guerner
  F-PGKL
  <<<<I don't like the Andair gascolator so much (I have the  bigger one). It
 grounded>>>>>>>>>>>>
				 Posted: Sun May 09, 2010 11:32 am    Post subject: What a fine airplane! |
  	  | Quote: | 	 		   - The SmartASS (Talking Airspeed Indicator of Smart Avionics) is a
  real
 Frans,
 Where did you locate your 2nd pitot?
 Fred
				 Posted: Tue May 11, 2010 1:32 am    Post subject: What a fine airplane! |
				On 05/09/2010 09:29 PM, Fred Klein wrote:
  	  | Quote: | 	 		  > - The SmartASS (Talking Airspeed Indicator of Smart Avionics) is a real
 On the starboard wing, at exactly the same (mirrored) position as on the
 port wing.
 Both ASI's agree heavily with each other.
 Frans
