		chris r
				 Posted: Mon May 10, 2010 5:15 am    Post subject: exhaust mounting from engine |
				Has anyone mounted there exhaust pipes directly from engine as opposed to attaching down pipes to engine mount, I remember seeing some info on it a while back,
  |  | - The Matronics RV6-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?RV6-List |
		HCRV6(at)comcast.net Guest
				 Posted: Mon May 10, 2010 9:03 am    Post subject: exhaust mounting from engine |
				Yes.  That was the standard Vetterman method back in 2003 when I hung my engine and it has been trouble free for coming up on 700 hours.  The hangars attach to two of the bottom bolts that secure the oil pan and use the same rubber hose and steel tube attachments that Vetterman supplies.  I don't understand why he went away from that method because it makes much more sense, at least to me, to hang the pipes from the engine.
 Harry Crosby
 RV-6 N16CX, 684 hours
		Smcm75(at)aol.com Guest
				 Posted: Mon May 10, 2010 11:12 am    Post subject: exhaust mounting from engine |
				In a message dated 5/10/2010 1:03:42 PM Eastern Daylight Time,  HCRV6(at)comcast.net writes:
   	  | Quote: | 	 		  Yes.  That was the standard Vetterman method back in 2003 when I    hung my engine and it has been trouble free for coming up on 700 hours.     The hangars attach to two of the bottom bolts that secure the oil pan and use    the same rubber hose and steel tube attachments that Vetterman supplies.     I don't understand why he went away from that method because it makes much    more sense, at least to me, to hang the pipes from the  engine.
  The reason why he changed the mounting from attatched to the engine to  attached from the engine mount was the engine hanger steel ends were cracking  off where they were attached to the engine pan bolts
				 Posted: Mon May 10, 2010 3:27 pm    Post subject: exhaust mounting from engine |
				Interesting, I have heard about that so I check those hangars at each oil change.  No cracks yet, and if they did it would not be a big deal to replace them.
 Harry Crosby
