rparigoris
Posted: Tue May 11, 2010 12:20 pm Post subject: Anyone use D-sub connectors to connect instrument module? |
Has anyone mounted D-sub connectors flush with bottom of instrument module, outboard near fuse to aid install and removal? (Male plug lives on fuse harness, female plug lives on bottom outboard of instrument module)
What sort of shells did you use? 90 degree, 45 degree or straight for wires coming in from fuse?
Any pics of hook up from fuse to instrument module would be appreciated.
Thx.
Ron Parigoris
rampil
Posted: Wed May 12, 2010 5:45 am Post subject: Re: Anyone use D-sub connectors to connect instrument module |
I think the dbs on the panel module should be male instead of female as you propose. After all, the module is inserted into the fuse!!
Actually, I used CPC connectors because they are engineered for
applications like this and are far more rugged
rparigoris
Posted: Wed May 12, 2010 1:17 pm Post subject: Re: Anyone use D-sub connectors to connect instrument module |
Hi Ira
Thx. for the reply.
Did you mount CPC connector on the bottom of the instrument module?
Did you install on both left and right sides of instrument module to accept fuse wires?
Thx.
Ron Parigoris
rampil
Posted: Wed May 12, 2010 5:38 pm Post subject: Re: Anyone use D-sub connectors to connect instrument module |
I have three CPCs, left right and center tunnel.
I am not sure what you are referring to as "fuse" wires. Do you mean
thin wires ala Nuckolls? Why would you put them in a plastic connector
when if they actually overload, they flame and melt.
Although I did put two sets of those fusible wires in my plane to
protect my two ammeters. If I have to do it again, I'd use auto blade
fuses for access and serviceability.
rparigoris
Posted: Wed May 12, 2010 6:57 pm Post subject: Re: Anyone use D-sub connectors to connect instrument module |
Hi Ira
"I have three CPCs, left right and center tunnel."
How do you get to your left and right CPCs?
Are they located inside instrument module where with instrument module in place and front panel inserts removed you access CPCs inside instrument module? If this is the case are they mounted to instrument module or firewall?
Or are CPCs mounted to bottom of instrument module where they are accessed from the bottom of instrument module (could access with instrument module and front panels in place)?
Sorry for confusing, when I mentioned fuse wires I was referring to fuselage wires, we have a bundle on the port side and also on starboard that needs to get into instrument module, low amperage stuff for the most part (nothing to do with fusible links), fuselage wires for:
*switches on sticks
*fuel flow transducers (2)
*fuel gage sender
*stabilator antiservo servo
*aileron servo
*E-Bus and always Hot-bus that live resident on back of starboard headrest need to plumb electron flow into instrument module
*airspeed switch for gear warning
*D10a magnitometer
*20% throttle reed switch
*gear down latch reed switch
ron Parigoris
rampil
Posted: Fri May 14, 2010 5:14 am Post subject: Re: Anyone use D-sub connectors to connect instrument module |
My CPCs are mounted on the forward lateral bottoms of the IM.
The center tunnel CPC is mounted forward bottom, above the port
side of the tunnel.
The "fuse" connectors are short pigtailed from the wall of the fuselage
