jonlaury
Posted: Tue May 11, 2010 10:50 am Post subject: Shunt/Hall Sensor placement |
In Z-13, I would like to place a Hall Sensor for the AUX Alternator between the battery contactor and the Batt Bus to locate it in the cabin and within it's recommended ambient temperature operating envelope.
Ditto for the Primary Alternator between the Batt Contactor and the Main Bus.
Any caveats here?
If only one alternator will be online at a time, is there any reason why I should not run the alternator outputs through just one Hall Sensor?
jonlaury
Posted: Tue May 11, 2010 11:48 am Post subject: Re: Shunt/Hall Sensor placement |
After looking long enough at my proposed HS placement, I can see that one of the shortcomings is that in the intended location, the sensors would only show alt throughput to the bus. In the case of the main bus, I could see alt output to the bus if the main contactor was open. But if it's closed, I'd have no way of knowing for sure if the alt was functioning at all because battery current throughput could be masking a dead alternator.
On the batt bus there would be no way to know if the Aux alt was contributing or not.
RETHINK time.
Sorry for the bother.
J
Posted: Tue May 11, 2010 9:17 pm Post subject: Shunt/Hall Sensor placement |
Check the chapter on batteries in the 'Connection
again . . .
Batteries deliver energy at 12.7 volts and BELOW
while alternators deliver energy at 13.8 volts
and ABOVE.
If an alternator is working, it will have a
positive indication of output current consisting
of aircraft system loads PLUS anything the battery
is asking for in order to replenish a discharge.
Alternators mask dead batteries . . . but batteries
don't mask anything.
Further if the alternator is working, then the bus
voltage is high enough to keep low voltage warning
lights out which are calibrated at 13.0 volts.
Same principals apply for both alternators.
jonlaury
Posted: Wed May 12, 2010 12:04 pm Post subject: Re: Shunt/Hall Sensor placement |
I re-read CH2 on Batteries, but it seems that with the sensor on the contactor-main bus leg, the sensor would only see the current(amps) going through that leg to the main bus. The bus voltage would show up on the voltmeter indicating alternator condition, but I don't see how the HS could detect current going to the battery if it is located on a branch of the system.
So I'm happy that I can at least verify that the alternator is working with the sensor inside the cabin, but it seems that if I want to know how hard, I will need another sensor at the alternator, or use a shunt per Z-13 and forget the hall sensor.
J
Posted: Wed May 12, 2010 5:18 pm Post subject: Shunt/Hall Sensor placement |
Correct.
How would you use that information if you had
it?
You KNOW how hard the alternator is working
before you ever fly the airplane. I.e., it
HAS to be large enough to carry all of system
loads PLUS recharge a battery.
If your low volts warning light is out, the
alternator IS WORKING. If the battery cranked
your engine to get you airborne and you're
confident of its CAPACITY, then the battery
IS WORKING. If in the rare instance that you
loose either alternator or battery contactor,
the e-bus alternate feed gives you a means by
which you get comfortably on the ground . . .
preferably at airport of intended destination.
Ammeters of any style installed connected to
measure any current flow in the aircraft are
diagnostic tools where the data offered is best
considered on the ground. Ammeters are
not particularly useful for making Plan-A/Plan-B
decisions in flight.
Joined: 28 Mar 2008 Posts: 1948 Location: Riley TWP Michigan
Posted: Thu May 13, 2010 5:35 am Post subject: Re: Shunt/Hall Sensor placement |
jonlaury,
You can place the current sensor wherever it will give you the most useful information. The current sensors in Z-13/8 provide the total current produced by each alternator. Some builders locate the current sensor between the battery and main contactor. In that location and under normal conditions, the ammeter will show battery charging current, which is not very useful information. Other builders locate the current sensor in the wire that feeds the main power bus. In this location, the ammeter shows the total current used by the aircraft (except for current used for battery charging and for devices connected directly to the battery bus). It can be useful to know the total aircraft electrical load and the power consumed by each device. In case of alternator failure, a knowledgeable pilot can shut off unneeded devices that consume the most power. Given a choice between a voltmeter and an ammeter, a voltmeter is more useful. With a modern EFIS, one can monitor both voltage and current without having extra gauges on the panel. It does not matter where the current is monitored (or if it is monitored). Just be aware of the advantages and disadvantages of different locations.
Joe
_________________ Joe Gores |
Posted: Thu May 13, 2010 7:45 am Post subject: Shunt/Hall Sensor placement |
jonlaury,
Joe is quite correct . . . and I would like
to apologize for my terse responses earlier.
There are reasons but they are not excuses . . .
I'll attempt to make amends.
It is also more difficult to do and requires
that the alternator b-lead be brought to the
main bus instead of tying it into the fat-wire
network on the firewall.
Since one of the design goals for Z-figures
is to eliminate bringing the alternator b-lead
into the cockpit, implementation of the battery
ammeter is more difficult. We don't want to
apply cranking current stresses to the ammeter
equipment and still expect it to be well calibrated
for normal operation.
Finally, interpreting the readings of a battery
ammeter take some study and understanding of
what the readings show under various operating
conditions.
Exactly. Jonlaury was wrestling with the trade-offs
of the various ammeter locations and getting a
handle on the significance/usefulness of the
readings.
When we put an instrument on the panel that
offers up NUMBERS that represent performance
values, the cognizant system designer considers
when and how those numbers are useful. In
the case of the Z13/8, normal operations may
load the e-bus to greater than 8A and it's
no problem as long as the main alternator is
functioning. An alternator loadmeter
in the SD-8 feed line allows the pilot to
do an as-needed load reduction on the e-bus
when conditions require a shift to Plan-B.
The legacy placement for ammeters has been
in either (1) battery ammeter like your grandpa's
Piper, Cessna and '52 Chevy, or (2) alternator/
generator loadmeters like the rest of general
aviation. But no matter where they are placed,
they'll offer very low-value data. In other
words, it's entirely possible and practical
to craft a system with no ammeters at all.
Active notification of low voltage combined
with what ever electrical system instrumentation
comes with your modern electro-whizzies
can be quite adequate to the task of airborne
electrical system management and crafting
of Plans A and B.
Plan-A says, "I can operate THIS list of
electro-whizzies." Plan-B says, "I can
operate THAT list of electro-whizzies."
It's better that you craft the two plans
before first flight rather than "on the
fly", no pun intended.
jonlaury
Posted: Thu May 13, 2010 10:11 am Post subject: Re: Shunt/Hall Sensor placement |
Joe and Bob,
"Joe is quite correct . . . and I would like
I'll attempt to make amends. "
Thank you both for your learned observations and attempts to understand my thinking on this.
Bob, your prodigious and continuing contribution to the OBAM aircraft community on this forum unequivocally qualifies you as the most patient teacher I've ever encountered. I didn't think your response was "terse". I thought it was patient, good-natured disgruntledness or self-effacing comic exasperation of having explained, about a gazillion times on this forum, that knowing how many amps your system is using is not very useful.
When I read your response, the annunciator light went on that says "oh yeah, I've read this before" and felt foolish for wasting forum space.
And in spite of knowing how many amps are careening about my system, I also know that it's only useful in making me feel like I'm more in control. Yet the control freak in me wants to know. So with your and Joe's clarifications about what the different placements of the current sensor mean, I will confidently sally forth to appease my inner demons.
Posted: Thu May 13, 2010 8:18 pm Post subject: Shunt/Hall Sensor placement |
Everyone learns differently. If some new light
bulbs have lit up for you, then what we've done
here is a good thing.
Speedy11(at)aol.com Guest
Posted: Fri May 14, 2010 6:05 pm Post subject: Shunt/Hall Sensor placement |
I also appeased my "demons" and inserted current detections where I wanted it. I'm not an aero electric expert, but I've been flying numerous aircraft for 35 years and I know what info I like to have displayed in the cockpit. I wanted current measurements.
So, I inserted a HE device along the wire from the alternator to the #1 battery and a shunt on the wire from the #2 battery. My thinking was that I could monitor the amps going to the #1 battery to see how much load was on the alternator. It works great in that function and shows the high amps used to recharge the battery and then once it is recharged, it shows the load being used by the entire aircraft. The shunt will indicate the amps being drawn from the #2 battery should the alternator and #1 battery fail.
I like having information in the cockpit. Control freak? Perhaps. Guess I've been a control freak for 35 years and didn't realize it.
For me, just as I like to know what my fuel flow is, what my oil pressure is, what my system voltage is, - I also like to know my amperage load.
Build it the way you like it.
Stan Sutterfield
| Quote: | So with your and Joe's clarifications about
