John Bolding
Posted: Thu May 13, 2010 3:01 am Post subject: Gear fitting dimension |
In the middle of developing a glass gear for the 701 have hit a semi-snag.
I've discovered what I believe to be a discrepancy in the plans and real
life parts. I know that's hard to believe but I think it's true.
I need a dimension from actual PARTS so that I can get past the mold/plug
stage and into the drop test/ prototype stage.
The two centering pins welded to the main gear fitting is the offending
part, I need the distance CLEAR between them.
As many that can measure and send to me will improve the outcome as I'm
making the mold fit the worst case senario.
Short background,
Gear engineered by former Scaled Composites lead engineer, he plays a
composite aero engineer in real life for money.
Gear is strong enough to meet FAR23 loads criteria. No more bending the gear
on botched landing.
(Something else will bend first, maybe that's good, maybe not, I just
decided I wanted a gear up to specs)
Will save 6-7 #
Same track and camber as original.
MAYBE internal brake lines, we'll see.
Thanks to all, you can respond off list if you wish,
jnbolding1(at)teleshare.net
Kevin, is that YOUR windshield?? Exactly my thoughts on how it should be
done.
LO&SLO
rvickski(at)yahoo.com Guest
Posted: Thu May 13, 2010 7:30 am Post subject: Gear fitting dimension |
Hi John,
I built the gear mounts, and yes either there is a discrepancy with
the drawing or my interpretation.
The gear leg calls for 3 1/4 material and then to file the bolt
reliefs which locates the gear transversely. I used 3 inch material
and still had to file the gear.
Is it not recommended to file the composite gear? If not, perhaps your
gear could be 3.250 between the mounts and say 2.875 on the legs
outboard of the mounts? side shift would then not be an issue.
What I've noticed in operation is that most of the gear flex happens
between the mounts and I would bet money that even the factory gear
mounts are 'as built'.
On May 13, 2010, at 7:01 AM, John Bolding wrote:
snag.
real life parts. I know that's hard to believe but I think it's true.
plug stage and into the drop test/ prototype stage.
offending part, I need the distance CLEAR between them.
I'm making the mold fit the worst case senario.
Short background,
a composite aero engineer in real life for money.
the gear on botched landing.
just decided I wanted a gear up to specs)
Will save 6-7 #
Thanks to all, you can respond off list if you wish, jnbolding1(at)teleshare.net
should be done.
LO&SLO
Roy Szarafinski
roysgarage.com
JohnDRead(at)aol.com Guest
Posted: Thu May 13, 2010 2:24 pm Post subject: Gear fitting dimension |
Hi John;
I took a look at my drawing set and the actual Gear Mounts. On sheet 7-L-2 item 1J shows the gear legs to be 82 mm wide with the notches be 76 mm apart. The Gear Mount on sheet 7-F-17 item 1SP shows the mounting threaded pins to be 77 mm apart. I measured mine and the pins were 76 mm between them. The notches provide the lateral positioning of the gear so they need to be there even with a composite part, I think that if they were made 75 mm apart that should be OK. The Gear Mounts are a substantial part and are probably welded in a fixture so I suspect they are pretty consistent. The factory may be able to help with inspection data.
Regards, John
CH701 - Colorado - Jabiru 3300
Cell: 719-494-4567
Home: 303-648-3261
In a message dated 5/13/2010 5:01:53 A.M. Mountain Daylight Time, jnbolding1(at)teleshare.net writes:
| Quote: | --> Zenith701801-List message posted by: "John Bolding" <jnbolding1(at)teleshare.net>
Short background,
on botched landing.
Will save 6-7 #
done.
LO&SLO
John ========================= Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
John Bolding
Posted: Fri May 14, 2010 4:32 am Post subject: Gear fitting dimension |
I understand that lateral positioning needs to be addressed, if you make the gear from alum, composites, marshmallows or unobtanium it's gotta be held in place, side to side , fore and aft, and restricted against rotation..
They are NOT consistent, that's why I'm asking, I've had almost a 1/4" difference so far on factory parts and slightly less on builder constructed pieces.
You absolutely don't , under any circumstances, want to score the uni fibers in the gear, Composites 101.
Thanks for your measurements.
Hi John;
The notches provide the lateral positioning of the gear so they need to be there even with a composite part, I think that if they were made 75 mm apart that should be OK. The Gear Mounts are a substantial part and are probably welded in a fixture so I suspect they are pretty consistent. Regards, John
Posted: Fri May 14, 2010 7:36 am Post subject: Gear fitting dimension |
Hi John;
I understand the need to keep from nicking composite structures. One dimension that may have a big variable is the lateral distance between the notches. Perhaps a grommet or O ring of hard urethane over the pins would fix the potential contact problem too. If the distance between the notches is not to variable perhaps a step with a curve to the in side would work then the width of the gear outboard of the clamps could be 75 mm or so and the section under the fuselage remain at 82 mm.
Regards, John
Cell: 719-494-4567
Home: 303-648-3261
In a message dated 5/14/2010 6:33:09 A.M. Mountain Daylight Time, jnbolding1(at)teleshare.net writes:
| Quote: | I understand that lateral positioning needs to be addressed, if you make the gear from alum, composites, marshmallows or unobtanium it's gotta be held in place, side to side , fore and aft, and restricted against rotation..
Hi John;
List href="http://www.matronics.com/Navigator?Zenith701801-List">http://www.matronics.com/Navigator?Zenith701801-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Tue May 18, 2010 5:50 pm Post subject: Re: Gear fitting dimension |
Hi John,
Is this addressed to me? And to what are you referring? I posted some pics of Champs top a few days ago. Let me know because I do not have a wind shield yet and do not want to miss lead anyone.
Kevin
STILL working on wings... graduation and fixing the kids cars will be over soon! I hope.
RE:
| John Bolding wrote: | In the middle of developing a glass gear for the 701 have hit a semi-snag.
done.
LO&SLO
John |
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
