912 valve cover O-rings
icrashrc
PostPosted: Mon May 17, 2010 9:47 am    Post subject: 912 valve cover O-rings Reply with quote
Does anyone have a line on replacement o-rings for the valve covers on a 912uls? The Rotax listing shows them at 105x2.5. $28 each seems a little pricey for something that normally sells for $1 each in a 10 pack. Thanks!
Scott
Scott
www.ill-EagleAviation.com
Roger Lee
PostPosted: Mon May 17, 2010 9:58 am    Post subject: Re: 912 valve cover O-rings Reply with quote
http://mdmetric.com/or/oringsizelisting.htm
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
kevann(at)gotsky.com
PostPosted: Tue May 18, 2010 4:53 am    Post subject: 912 valve cover O-rings Reply with quote
Roger,
Thanks for the link to metric O-rings.
I'm thinking of ordering the 105x2.5 valve cover o-rings.
Do you know the size to order for the small valve cover bolt o-ring?
Perhaps you have list of other o-ring sizes for the 9xx series engine?
I want to put together a kit of spares for a trip to Alaska.
Thanks, Kevin
Europa XS, 914
Roger Lee
PostPosted: Tue May 18, 2010 6:07 am    Post subject: Re: 912 valve cover O-rings Reply with quote
The smaller inside "O" ring is 6.4 x 1.8.
You can find all the "O" ring sizes for the 912 in the parts manual.
Roger Lee
Tucson, Az.
Cell 520-349-7056
icrashrc
PostPosted: Wed May 19, 2010 2:44 am    Post subject: Re: 912 valve cover O-rings Reply with quote
Roger,
Thanks for the link! Have you ordered from these people before?
Scott
Roger Lee
PostPosted: Wed May 19, 2010 5:33 am    Post subject: Re: 912 valve cover O-rings Reply with quote
Yes I have. They have many types of "O" rings.
Roger Lee
Tucson, Az.
Cell 520-349-7056
rparigoris
PostPosted: Wed May 19, 2010 2:53 pm    Post subject: Re: 912 valve cover O-rings Reply with quote
Hi Roger
What compound and durometer did you select for valve cover o-rings?
If you purchased other o-rings for Rotax, what were they for and what compound and durometer did you select?
Thx.
Ron Parigoris
Roger Lee
PostPosted: Wed May 19, 2010 3:28 pm    Post subject: Re: 912 valve cover O-rings Reply with quote
The ones I have used in the past were Viton. You can search their website and read about different "O" ring materials.
Roger Lee
Tucson, Az.
Cell 520-349-7056
