upgrade question
Goto page 1, 2, 3  Next
Lee Steensland
PostPosted: Tue May 18, 2010 7:05 pm    Post subject: upgrade question Reply with quote
Who knew you had to be a machinist to install the upgrade!
I'm learning about all sorts of new things: transfer punches, reamers,
solid rivets.
The plans state that the main spar attach bolt holes in the center spar
should be drilled undersized then reamed to the proper diameter (5/16).
To me that appears to be a pretty open ended statement. If you google
"reamer" you get many and varied hits for all different kinds of
reamers. Does anyone have a suggestion as to what kind of reamer we
should use and where to get one?
Should we also ream the bolt holes for 6-ZU-2-4?
What have other people done?
Thanks!
View user's profile Send private message Send e-mail AIM Address MSN Messenger
psm(at)att.net
PostPosted: Tue May 18, 2010 11:03 pm    Post subject: upgrade question Reply with quote
Hi Lee,
Reamers do indeed come in a lot of different forms. For this kind of work, I prefer hand reamers. They tend to be several inches longer than other kinds and mount in tap holders. I selected "Left hand spiral, Right Hand cut" for my Zodiac XL spar work, but other choices would probably work about the same.
What you probably don't want is "Chucking Reamer" types. These are meant for milling machines and fancier "Machining Centers" where the machine provides the stability rather than the shape of the reamer.
I like to drill 10 or 20 thousandths undersize before reaming a hole in aluminum.
There are many "Cutting Tool" vendors that all supply good stuff. Travers tool is a good one on the East coast, MSC works well in most parts of the USA.
I don't know which holes should be reamed, so I'll let someone else address that question. I personally think this is a big issue when a wing is attached to the fuselage with one bolt, but when there are six of them I doubt the perfection of the hole is a big deal.
Paul
XL installing upgrade (slowly)
Terry Phillips
PostPosted: Tue May 18, 2010 11:08 pm    Post subject: upgrade question Reply with quote
Hi Lee
I am definitely not a machinist, but I can tell you what I am doing, though
I am still in the early stages. Most of what I've learned about reamers was
by buying the wrong thing at $18/ea.
I think the best ones are the "piloted reamers," e.g.,
http://browntool.com/Default.aspx?tabid=255&txtSearch=reamer&List=1&SortField=ProductName%2cProductNumber&catpageindex=2&ProductID=1010
which has a short pilot of 0.2969" dia. to fit in your sub-5/16" pilot
hole, followed by a section of 0.3125", to ream the hole precisely to
5/16". That assumes that you hold your drill perfectly normal to the
spar---or are using a good drill press. There are (slightly) cheaper
reamers that are not piloted.
I don't trust my hand drill skills, so I think I'll bolt my drill press to
my work table for the reaming.
I'm also using reamers for the bolt joints through the 1/8" spar cap, spar
cap doubler, web, and spar root doubler plate. I'm using AN4's rather than
AN3's, because the holes in my spar cap and my spar cap doubler are
substantially larger than 0.1875" . I bought a .247 x .231 HSS Piloted
Chucking Reamer for those holes (my AN4's measure about 0.245").
Good call on the 6-ZU-2-4 bolts. You're way ahead of me. I believe that the
bolts in the main spar are loaded primarily in shear (so a tight bolt hole
is critical to avoid stress concentrations, which can lead to fatigue
failure). I suspect the center spar bolt are in tension between the bolted
spar caps, but in shear between the spar caps and the spar uprights. In any
case, I do not believe that a tight bolt hole hurts (assuming that holes
line up in the different layers), so I'll plan to use my .247 x .231 AN4-
piloted reamer for those holes also. 'Good idea.
Terry
solid rivets.
Thanks!
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
ZU-601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail & flaps are done;
Upgrading wings & ailerons per the AMD Safety Directive
http://www.mykitlog.com/N47TP/
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings.
Brady
PostPosted: Wed May 19, 2010 9:25 am    Post subject: Re: upgrade question Reply with quote
Lee,
The reamer you want to use is called a chucking reamer.
It has straight flutes and can be turned by hand or by a drill motor.
I suggest you turn it by hand.
A piloted reamer is best but not totally necessary.
5/16” is .3125”
The upgrade instructions specify the tolerance to be +.004”
This means you holes cannot be larger than .3165”or you will need to go to an over sized bolt that is less than 3/8th.
these are very expensive.
The reamer size you want is .3125"
It is not necessary to ream the bolts in the main spar.
These bolts are not in shear really, they are mostly in tension.
as the spar is stressed the caps want to separate or bend away from each other. this would allow them to collapse.
The bolt (&or rivets) hold them together and force them to flex in the correct direction which is edge wise.
Clear as mud?
I hope this helps,
Brady
Brady McCormick
Poulsbo, WA
www.magnificentmachine.com
Ron Lendon
PostPosted: Wed May 19, 2010 11:49 am    Post subject: Re: upgrade question Reply with quote
Lee,
Brady and I are machinists, here is a picture of how I keep things square when I can't use a machine. It's a vee block, not show is my hand holding it in place while I use the reamer and cutting oil everywhere.
http://mykitlog.com/users/display_log.php?user=rlendon&project=113&category=0&log=24457&row=671
I used this method on one upgrade and the fit was good on all the holes.
YMMV
Practice, practice, practice, and oh yeah, practice.
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
JohnDRead(at)aol.com
PostPosted: Wed May 19, 2010 9:28 pm    Post subject: upgrade question Reply with quote
Brady;
 I would not use a chucking reamer by hand the straight flutes are designed to be driven by a machine tool such as a milling machine or a lathe. Reaming by hand is best done with a hand reamer which has spiral flutes and a taper to the diameter for a short distance.
Regards, John
CH701 - Colorado - Jabiru 3300
Cell: 719-494-4567
Home: 303-648-3261
In a message dated 5/19/2010 11:26:28 A.M. Mountain Daylight Time, brady(at)magnificentmachine.com writes:
--> Zenith601-List message posted by: "Brady" <brady(at)magnificentmachine.com>
Lee,
A piloted reamer is handy but not totally necessary.
5/16” is .3125”
Clear as mud?
I hope this helps,
Brady
Brady McCormick
Poulsbo, WA
http://forums.matronics.com/viewtopic.php?p=298202#298202===============================================
_-= Use the ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp;   ===================================================
mhubel
PostPosted: Thu May 20, 2010 4:24 am    Post subject: upgrade question Reply with quote
John,
On the issue of a chucking reamer, I did use one by hand. I don't
recommend it for everyone. By using the existing hole as an alignment
guide and then having the hole in the new metal only 0.015 under size,
it was very easy to get a clean hole. The clear issue is that one must
not put any side pressure on the existing hole. That is a matter of
practice. Even a hand reamer can take some metal off the existing hole
if one is not careful so there is no perfect solution short of standing
the wing on edge and mounting a "mini" drill press on the spar to ream
out the holes.
Even better would be to have a special reamer that only had cutting
flukes for the first 1/8 inch and then was smooth but the same diameter.
I have never heard of such a tool.
Mark Hubelbank
NorthEast Monitoring
2 Clock Tower Place
Suite 555
Maynard, MA, 01754 - USA
mhubel(at)nemon.com
978-443-3955
Mark Hubelbank
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
Sensenich ground adj prop.
240 hr TAF
Pictures at photo.hubbles.com
zenith-list(at)steensland
PostPosted: Thu May 20, 2010 8:25 am    Post subject: upgrade question Reply with quote
Fortunately I'm in a fairly unique situation. I don't have the center
spar installed nor the wings complete. Everything is free and away from
the plane, so setting it up in a drill press is child's play (for the
most part).
On Thu, 2010-05-20 at 08:23 -0400, Mark Hubelbank wrote:
John,
out the holes.
Brady
PostPosted: Thu May 20, 2010 9:56 am    Post subject: Re: upgrade question Reply with quote
JohnDRead(at)aol.com wrote:
Brady;
�I would not use a chucking reamer by hand the straight flutes are designed to be driven by a machine tool such as a milling machine or a lathe. Reaming by hand is best done with a hand reamer which has spiral flutes and a taper to the diameter for a short distance.
Regards, John
John,
Actually that is not true, and I don't think the Reamer can tell who or what is turning it.
Page 807 of the Machinery's Hand Book 26th edition says:
"Hand reamers are made with both straight and helical flutes. Helical flutes provide a shearing cut and are especially useful in reaming holes having keyways or grooves, as these are bridged over by the helical flutes, thus preventing binding or chattering."
Because the hole we are reaming do not have a keyway or grooves (intentionally) a spiral reamer is not necessary.
But every situation is different and everyone's skill level may vary.
I would expect builders to use their noggin.
My advice was free and general.
take it or leave it as you may.
Brady McCormick
Poulsbo, WA
Terry Phillips
PostPosted: Thu May 20, 2010 10:23 am    Post subject: upgrade question Reply with quote
Brady or John
Assuming that one wanted to turn a chucking reamer by hand, what would you
use as an handle? My reamers have round shafts whose diameter is a bit
smaller than the reamer size.
Terry
> Brady;
> Regards, John
John,
what is turning it.
Brady McCormick
Poulsbo, WA
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Ron Lendon
PostPosted: Thu May 20, 2010 10:39 am    Post subject: Re: upgrade question Reply with quote
Terry Phillips wrote:
Brady or John
Terry
Terry,
I used a tap handle like the one in the bottom of the picture.
http://en.wikipedia.org/wiki/Tap_wrench
Turned the reamer counterclockwise through existing hole till it met the new hole. Then I turned it clockwise to finish the new hole. The new hole was .015 small before reaming.
Ron Lendon
CH 601 XLB
N601LT - Flying
Brady
PostPosted: Thu May 20, 2010 10:40 am    Post subject: Re: upgrade question Reply with quote
Brady or John
Terry
Terry,
You can grind 4 flats on it and turn it with a tap handle.
After you modify it will still be usable as in a chuck.
most of mine are modified this way.
Brady McCormick
Poulsbo, WA
Terry Phillips
PostPosted: Thu May 20, 2010 1:32 pm    Post subject: upgrade question Reply with quote
Thank you Brady & Ron.
Between your two posts I think I get the idea. The link to wikipedia which
had links to reamer articles was especially helpful.
Terry
> Brady or John
> Terry
Terry,
Brady McCormick
Poulsbo, WA
> Brady or John
> Terry
Terry,
Ron Lendon, Clinton Township, MI
Zodiac XL, ScrapBuilder Wink
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
chuck960
PostPosted: Thu May 20, 2010 7:56 pm    Post subject: Re: upgrade question Reply with quote
Why do the bolts have to be smaller than 3/8"? Is it edge distance that is the problem? With all the drilling and back drilling it's hard to get a perfect hole. The bolt may seem tight but the hole might not be uniform through many layers of material. I thought of drilling a larger hole after all the 5/16 bolts are in place by removing one bolt at a time. A 3/8 bolt is much stronger than 5/16.
Chuck
paulrod36(at)msn.com
PostPosted: Fri May 21, 2010 2:04 am    Post subject: upgrade question Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Good question. I've heard of several people who have done that, and apparently, nobody has complained about the result. While we're at it, do any of the guys with real-world structural backgrounds have any strong objections to using AN-3 bolts instead of rivets? Zenith said they don't mind, and several A&Ps have said it's okay. With the proposed number of bolts in the spar, the .008 (average) difference isn't going to matter. I guess this goes back to Chris' comment one time, "You're building a tractor, not a space shuttle".
Paul R
bill.pagan(at)yahoo.com
PostPosted: Fri May 21, 2010 4:01 am    Post subject: upgrade question Reply with quote
I asked the same question after discovering that a couple of my spar bolt holes were out of tolerance (It is a quickbuild and came that way but thats another gripe). ZAC (Caleb) told me that 3/8 was the maximum you could go to due to edge distances but cautioned that the tolerance was only .004. If you should go over that, which is easy to do, you would need to replace the spar etc. which would be in excess of $2K.
Bill Pagan
Sent: Thu, May 20, 2010 11:56:11 PM
Subject: Re: upgrade question
--> Zenith601-List message posted by: "chuck960" <chuckde(at)roadrunner.com (chuckde(at)roadrunner.com)>
Chuck
http://forums.matronics.com/viewtopic.php?p=298400#298400
; bsp; -Matt D=============
mhubel
PostPosted: Fri May 21, 2010 5:16 am    Post subject: upgrade question Reply with quote
Bill,
Has anyone thought of using metric bolts. I expect there are the
same grade bolts available (perhaps even better) in 8 mm (about 0.0024
over and a standard metric size) and 9 mm (0.0418 over or 0.021 under
3/8, but a hard to get size).
Mark Hubelbank
2 Clock Tower Place
Suite 555
mhubel(at)nemon.com
978-443-3955
Mark Hubelbank
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
240 hr TAF
Afterfxllc(at)aol.com
PostPosted: Fri May 21, 2010 7:57 am    Post subject: upgrade question Reply with quote
All of this reamer talk got me thinking (Scary Huh) and I went to Lowes and bought a 5/16 drill bit and just for shits and grins then drilled about 20 holes in a test piece of spar caps that came from the wing jigs and lo and behold all of my holes done by hand with a drill came out to .312 to .314 and the bolts were snug so if you are half way careful you should be able to just drill the holes.
And you can also buy oversized NAS bolts for the inept drillers out there. Smile
Jeff
In a message dated 5/21/2010 8:16:53 A.M. Central Daylight Time, mhubel(at)nemon.com writes:
--> Zenith601-List message posted by: Mark Hubelbank <mhubel(at)nemon.com>
Bill,
Mark Hubelbank
2 Clock Tower Place
Suite 555
Maynard, MA, 01754 - ================================================ Use the ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp;   ===================================================
flyboy3847(at)onecommail.
PostPosted: Fri May 21, 2010 9:48 am    Post subject: upgrade question Reply with quote
We used a reamer but just chucked it up in a hand drill. That worked fine.
Leroy Wheeler 601HD plans built just about done flying off the 40 hours.
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Afterfxllc(at)aol.com
Sent: Friday, May 21, 2010 11:56 AM
Subject: Re: Re: upgrade question
Jeff
Bill,
Mark Hubelbank
2 Clock Tower Place
Suite 555
Maynard, MA, 01754 - ======================= Use the ties Day ======================= - MATRONICS WEB FORUMS ======================= - List Contribution Web Site sp; =
No virus found in this incoming message. Checked by AVG - www.avg.com 271.1.1/2886 - Release Date: 05/20/10 14:26:00 [quote][b]
PostPosted: Fri May 21, 2010 9:51 am    Post subject: upgrade question Reply with quote
I discussed this option with a friend of mine a retired tool maker who is making the upgrade to his 601. I am a retired mechanical engineer. If you can ream the holes for a snug slide fit of A3 bolts into the holes then bolts should be OK if the holes are over sized then rivets are the safe way to go as they expand during setting the fill the holes. Just our two cents worth
Regards, John
Cell: 719-494-4567
Home: 303-648-3261
In a message dated 5/21/2010 4:05:04 A.M. Mountain Daylight Time, paulrod36(at)msn.com writes:
[quote] Good question. I've heard of several people who have done that, and apparently, nobody has complained about the result. While we're at it, do any of the guys with real-world structural backgrounds have any strong objections to using AN-3 bolts instead of rivets? Zenith said they don't mind, and several A&Ps have said it's okay. With the proposed number of bolts in the spar, the .008 (average) difference isn't going to matter. I guess this goes back to Chris' comment one time, "You're building a tractor, not a space shuttle".
Paul R
Page 1 of 3
