Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
tigerrick(at)mindspring.c Guest
Posted: Fri May 21, 2010 10:20 am Post subject: Landing gear orientation |
Hi, Tim!
I'm also a "big guy", and I'm in the process of turning my gear around so the flat side faces forward. I'd much rather shift my weight forward when boarding, then put up any longer with the inability to hold the nose off after the mains touch in a full stall landing.
Given the low rotation speed of the 601, and the "nose heaviness" with a Corvair, I think it makes sense to move the pivot point forward (assuming tricycle gear).
But I'm used to thinking about the tail going down while boarding - this happens withh Grumman Tigers all the time when two big people get on the boarding steps at the same time.
The solution is to install a skid at the rear tie-down eye, which will protect the tail and the ring.
Rick Lindstrom
ZenVair N42KP (upgrade well underway!)
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Fri May 21, 2010 4:29 pm Post subject: Re: Landing gear orientation |
Tim,
I am also a big guy. Only once when two of us were boarding the wing at the same time did we even start to tip the airplane. My current practice, anyway now, is to board and strap in my passenger first and then I board. No problems what so ever. I am to the point where I can hold the nose off for a good 5-9 seconds after landing on the mains.
Go flat forward with your Jabiru and you will not look back.
Dave
_________________ David Gallagher
Cincinnati, OH area |
