Posted: Wed May 19, 2010 4:22 pm Post subject: Flap Motor Circuit using Bosch Ice Cube relays |
At 11:20 AM 5/15/2010, you wrote:
I'm mystified as to how the designer of
this circuit intends the circuit to be used.
There is no OFF for the motor . . . only
FWD and REV.
The classic reversing system for PM motors
looks more like this.
http://www.aeroelectric.com/PPS/Flight/Flaps/Flaps_3.pdf
You use the same SPDT relay as the diagram
cited earlier but the control switch is a
CENTER OFF device that allows BOTH relays to
be relaxed in the OFF or no-motion mode.
Note that in the OFF position, both relays
are relaxed and the wiring places a dead short
across the motor. This is ESPECIALLY useful in
PM motors to supply electro-dynamic braking
to the motor. Coasting is reduced to a small
fraction of what you get when you simply open
the motor's power circuit to shut it off.
When the center-off switch is moved to either
extreme, one of the two relays is energized
causing one lead of the motor to be connected
to DC power while the other remains at ground.
Powering the motor with opposite polarity
by energizing the other relay produces oposite
direction of rotation.
jonlaury
