		jrlark
				 Posted: Mon May 24, 2010 3:07 pm    Post subject: step drills etc |
				Hi all
  I'm just about done with my elevator construction  and while I'm waiting for the prosealed trailing edges to set up I went to rivet  the trim cable attachment brackets to the cover plates.  The plans call out  for LP4-3 rivets.  I've bought the Cleveland Tools brackets but I can't  figure out why solid rivets wouldn't be used here.  Can anyone shed some  light on why I need to use LP4-3's?
  Question 2:  Can anyone tell me how to  properly use a step drill?  I've been a woodworker for more than 30 years  and have never had a hand tool I couldn't figure out how to use.  I've now  bought 2 different sized drills thinking the first one was a dud, but can't seem  to get the newer one to work worth a d**n either.  Case in point, when I  tried to drill out the .060" front elevator spar for the snap bushing, I would  have bent the spar before I forced it to drill the proper sizes hole.  What  am I missing????
  Regards,  Rick
  #40956
  Southampton, Ont
		ricksked(at)cox.net Guest
				 Posted: Mon May 24, 2010 3:19 pm    Post subject: step drills etc |
				Rick,
 Don't use rivets at all to attach those brackets, use machine screws and stopnuts. You will need to rotate the brackets when rigging the trim, just bolt them up when you have them adjusted.
 I'm not sure what the problem with the step drill except you ARE drilling an hole first before using the drill right? They don't start holes very well.
 Rick Sked
 N246RS
 Annual time!!
 ---- Rick and Sandra Lark <jrlark(at)bmts.com> wrote:
  	  | Quote: | 	 		   Hi all
  Regards,  Rick
  #40956
  Southampton, Ont
				 Posted: Mon May 24, 2010 4:36 pm    Post subject: step drills etc |
				I would guess you might be using the “Harbor Freight” type step drill.  They tend to make rough, less than round holes.  I bought a set figuring I could save a few dollars.  Big mistake.
 Try a Unibit brand step drill.  Smooth hole every time.  If your local Lowes/Home Depot should have them.  If not, Cleaveland Tools does: http://www.cleavelandtoolstore.com/products.asp?dept=21
 Carl Froehlich
 RV-8A (540 hrs)
 RV-10 (systems install)
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick and Sandra Lark
  Sent: Monday, May 24, 2010 7:06 PM
  Subject: step drills etc
 Hi all
 Regards,  Rick
 #40956
 Southampton, Ont
   [/b][/quote]<     - MATRONICS WEB FORUMS via the Web    --> http://forums.matronics.com[/url]         - List Contribution Web generous nbsp;                        --> http://www.matronics.com/c=[/b] [b]
		rv10flyer
				 Posted: Mon May 24, 2010 5:57 pm    Post subject: Re: step drills etc |
				Drill into a piece of scrap first to make sure sizing is accurate or your snap bushings will be loose. My first one was not.
 I used LP-4's but will change out to screws/miniature nut plates later on.
  _________________ Wayne G. |
		jrlark
				 Posted: Mon May 24, 2010 6:20 pm    Post subject: step drills etc |
				Hmmm....Yes you're right Carl.  Both drills  were cheap Harbor Freight type drills.  I don't usually go the cheap route  when it comes to tools.  Not sure now why I even tried.  I'll look for  a "good" drill.  Thx
  Rick
  [quote]   ---
		jrlark
				 Posted: Mon May 24, 2010 6:57 pm    Post subject: step drills etc |
				Ok, thx Rick.  I kind of wondered about those brackets.  I probably will
 just leave them detached from the cover plates until I start rigging, which
 appears to be a ways down the road.
 I have to ask another question.  At this point (elevators just about
 complete), I have 300 man hrs into this project.  I noticed on Tim O's web
 site, he had about 170 hrs at this same point.....  I must be really slow
 or?????    How much time did other builders have at this stage?
 I don't want to set a record as the slowest RV10 build, but still want it
 done correctly.  Maybe I'm a little anal retentive??
 All opinions appreciated.
 Rick Lark
 #40956
		Tim Olson
				 Posted: Mon May 24, 2010 7:25 pm    Post subject: step drills etc |
				I've found that while I think most people *can* move as quick through
 the project as I did, if they want to, that I may be a little bit
 quicker than many.  The thing is, I think I really did devote myself
 to the project when I was on it, and when I wasn't, I really wasn't.
 The more consistent you work on it, and the more you plan ahead, the
 faster it goes.  I didn't cut corners or do sloppy work, and in fact
 worried at first that I was being WAY too anal for the first 50 or
 100 hours.  But, I just really went to it, and got in the groove.
 I think if someone has no big family obligations on a daily basis,
 and doesn't have too many other irons in the fire, that you'd likely
 easily complete any RV-10 in 3 years.  But, most people have obligations
 and other things going on.  I was lucky enough to even have a wife that
 mowed the lawn every time it needed it, so that I didn't have to.
 With a partner like that, it was easy to finish in 25 months...I could
 even go much quicker next time if I wanted.  I even had to take care
 of kids as a single-parent-at-home most evenings, when they were 2,3,4,5
 years old, so I did it with plenty of things going on.  It's just
 a matter of focus and consistent work. Plus...I *really* wanted it
 done.
 Tim Olson - RV-10 N104CD
  which appears to be a ways down the road.
  web site, he had about 170 hrs at this same point.....  I must be really
  slow or?????    How much time did other builders have at this stage?
  it done correctly.  Maybe I'm a little anal retentive??
  Rick Lark
  #40956
		Kelly McMullen
				I stopped trying to track time, oh, around doing the vertical stab.
 Work goes a lot faster when you don't waste time tracking it. I know
 of at least one kit that is below ser. no 40050 that is no where near
 putting the major parts together, much less finishing. Enjoy the
 build, satisfy your own quality requirements, and it will be done when
 it is done.
 Kelly
 40866
 Fuselage/fuel system
 On Mon, May 24, 2010 at 7:56 PM, Rick and Sandra Lark <jrlark(at)bmts.com> wrote:
  Rick Lark
  #40956
A&P/IA, EAA Tech Counselor
KCHD |
				 Posted: Mon May 24, 2010 7:36 pm    Post subject: step drills etc |
				My experience with the HF strep bits is that they work fine for x holes
 (x being dependent on the material drilled). Then suddenly, they seem to
 wear through a very thin, hardened surface on the bit, and become
 completely non-functioning junk.
 Having said that, the HF bits are a good value (!!!). I forget the
 prices but you can get a set of 3 bits for about the 1/3 the cost of 1
 quality bit. I'm on my second set having worn 2 bits out but my '10 is
 close to finished (did I say that?). I have a quality bit which I'm
 saving for any more firewall SS holes but there's little other steel on
 the aircraft. I used the HF bits on aluminum and composite and I'm
 prepared to ruin 1 or 2 more bits if necessary.
 To use the HF bits, you just have to be ready to chuck them as soon as
 they don't seem to be cutting. But on sale, they are really cheap and I
 have room to store them. YMMV.
 Bill
 [quote] Hmmm....Yes you're right Carl. Both drills were cheap Harbor Freight
  Rick
				 Posted: Mon May 24, 2010 8:09 pm    Post subject: step drills etc |
				Enjoy the process. My Dad got sick and passed away during my
 build...during that time all I knew was I couldn't park my car in the
 garage because of my "project" which was nothing in comparison to my
 life at the time My total build time is about 2400 hours, or 5 years 4
 months and 23 days. Build time is like a fingerprint...no two are the
 same. Perserverance is the best ribbon they can give you at Osh....
 Rick
 On May 24, 2010, at 7:56 PM, "Rick and Sandra Lark" <jrlark(at)bmts.com>
  will just leave them detached from the cover plates until I start
  rigging, which appears to be a ways down the road.
  O's web site, he had about 170 hrs at this same point.....  I must
  be really slow or?????    How much time did other builders have at
  this stage?
  want it done correctly.  Maybe I'm a little anal retentive??
  Rick Lark
  #40956
				 Posted: Mon May 24, 2010 8:31 pm    Post subject: step drills etc |
				I watched this carefully...
 http://www.airspacemag.com/multimedia/videos/Go-For-Launch.html
 ... and I noticed a lot of people standing around with their hands in
 their pockets.  I can relate.  Although my project is a one man effort
 (with critical assistance from my rivet bucker and life partner Alicia),
 I spend plenty of time standing around admiring the kit, my progress, my
 lack of progress, thinking about future progress, smoking a cigar,
 watching the Waco depart, and otherwise scritching my cat.  These are
 the best of times.
 Now, I have to admit that I have a Maule to fly when the mood strikes,
 but I increasingly find myself forcing the issue just to maintain some
 proficiency (or to get from A to B).  Fact is, standing around with my
 hands in my pockets trying to remember what I planned to do is a lot
 more fun.. sort of.
 Enjoy the process and remember it's not work.
 Bill "trying to get comfortable with my progress as a 4th anniversary
 approaches"  Watson
  	  | Quote: | 	 		   ....snippetysnip
  really slow or?????    How much time did other builders have at this
  stage?
  Rick Lark
  #40956
		jcumins(at)jcis.net Guest
				 Posted: Tue May 25, 2010 9:34 am    Post subject: step drills etc |
				Rick
 Everyone builds at different speeds. I suspect I am about the same time hours wise as you.  So don’t worry about it take your time pay close attention to the details and you will be fine.
 John G. Cumins
 40864 Mounted elevators to horz stab Emp almost complete
		sean(at)stephensville.com Guest
				 Posted: Tue May 25, 2010 10:25 am    Post subject: step drills etc |
				Here here.  Approaching 5 years and I am just finishing the wings.  Good
 part is that avionics and after market "stuff" just keeps getting better
 the longer it takes me.  Bad part is that kit, engine and prop prices
 keep going up the longer it takes me.
 -Sean #40303
 http://rv10.stephensville.com
  Rick
 > O's web site, he had about 170 hrs at this same point.....  I must be
 > stage?
 > Rick Lark
 > #40956
		rv10flyer
				 Posted: Tue May 25, 2010 2:40 pm    Post subject: Re: step drills etc |
				It depends alot on how you track time. I just write start and end time right on the plans as I check off the steps. At the end of the section go back and add the highlighted times up. My time starts when I am actually working with tools/parts in my hand. I don't count ordering, a picture every now and then, lunch/supper breaks, or reading plans before work starts.
 It also depends on how much you spent on tools up front, shop conditions, your mechanical ability and comfort using tools that can hurt if not used correctly. Like most said...just enjoy the build, hang some pics of finished rv's/trip pics like I did for motivation, fly/hang out with at least one other builder/rv owner for motivation which I do, and save as much $$$ as possible for the next piece but lastly don't forget the family. My wonderful wife of 21 yrs is a really good riveter now...only had to drill out 2 or 3 so far. My 10 & 7 yr olds are good at clecoing and placing rivets for Dad.
		jrlark
				 Posted: Tue May 25, 2010 4:31 pm    Post subject: step drills etc |
				Guys
 Thx for the advise and words of encouragement concerning build times.
 I really am enjoying building this aircraft.  Maybe that's why I'm so slow,
 I'm savoring it too much
 Tim you are one lucky man to have a spouse that mowed the lawn while you
 built.  Having said that I don't think I'd trust my wife with the mower
 anyway.
 I will keep working away at it, and as someone said, "it'll be done when
 it's done".
 Thx,  Rick
 #40956
 Southampton, Ont
		Tim Olson
				 Posted: Tue May 25, 2010 8:07 pm    Post subject: step drills etc |
				  Yes, I'm lucky, but trust me, every time I tell someone how
 it was fun for "me to build an RV-10", she constantly reminds me
 that the only reason I was able to do it was because she picked
 up a lot of the loose ends around the house.    I appreciate the
 heck out of her though.  I'm very lucky we had the same goals.
 Like the others said, enjoy it and make the build the way YOU want
 it.  Some want a relaxing building hobby...that's awesome. Some
 see building as the journey to the reward at the end of the rainbow,
 and they want to get there quick.  Each person can approach it
 with the level of "push" that they want.  The part that gets tough
 is when you want it done soon, but you don't want to dig in.  I
 spent countless nights laying awake just honestly praying for
 spirit of dedication to the task, to enable me to make it though
 the project at a rate that would satisfy the burning want to get
 it done before I got too impatient to appreciate the time spent.
 It's a very tough mental exercise to take on such a project if
 you're impatient for the end result, as I was, because you
 constantly have to see the light at the end of the tunnel lest
 you let it break your spirit if you become discouraged.  It's
 one of the reasons I usually recommend saving enough money ahead
 of time to finish the kit before your money pile runs out....because
 if someone is really driven for that end result, it IS possible
 to build the entire plane in such a short timeline that you
 can easily get to the major spending sections before you have
 the money saved.  You start on the tail, and the next thing you
 know you're buying your panel.  For some people, patience comes
 easy....for others (me), it was a learned thing on this project.
 Thankfully there are numerous "I finished" experiences throughout
 the process, as each section is completed.
 Rick Lark wrote:
  Guys
  slow, I'm savoring it too much
  anyway.
  it's done".
  Thx,  Rick
  #40956
  Southampton, Ont
		fixitauto(at)aol.com Guest
				 Posted: Wed May 26, 2010 5:03 am    Post subject: step drills etc |
				Ordered my kit 40079 on Thursday at osk the year vans started selling them
