		cschmokel
				 Posted: Sat May 29, 2010 10:19 pm    Post subject: Flaperon tube looseness? |
				Hey guys,
 I noticed something a little strange about my Kitfox 5.  With the control sticks completely secured, the flaperons have roughly 10 degrees of wiggle room.  It appears that the flaperon tubes remain firmly in place, and the flaperons wiggle about these tubes due to a bit of rivet looseness.  Is this normal?  Thanks!
 Carl
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		dave
				 Posted: Sun May 30, 2010 1:39 am    Post subject: Re: Flaperon tube looseness? |
				If you can see loose rivets allowing movement then I would investigate further.
 Loose rivets will only get looser and migjht be a early warning sign of something.
 BTW -- how much should a model 5 weight empty with a 0240  >?
  _________________ Realtime Kitfox movies to separate  the internet  chatter from the truth
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
		lcfitt(at)sbcglobal.net Guest
				 Posted: Sun May 30, 2010 11:21 am    Post subject: Flaperon tube looseness? |
				Carl,
 I don't think that amount of looseness is normal.  In thinking of the
 construction, there should be a steel bulkhead / rib on the inboard end of
 the flaperon that the tube is riveted to as well as to the mass balance
 weights.  The rivets should be Stainless Steel.  If the movement is between
 the tube and the steel rib it should be addressed.  I think what I would do
 is drill out the rivets and install larger rivets.    There is also a
 tendency to develop slop in the linkages as well, but I think 10 degrees is
 too much.
 Lowell
 Sent: Saturday, May 29, 2010 11:19 PM
 Subject: Flaperon tube looseness?
  Hey guys,
  Carl
  http://forums.matronics.com/viewtopic.php?p=299332#299332
		cschmokel
				 Posted: Mon May 31, 2010 7:50 pm    Post subject: Re: Flaperon tube looseness? |
				Thanks guys.
 Lowell, I think you're right on.  I'm going to drill the rivets out and pop in some larger ones.  I'll tell you how this happened (I think) .. I had the plane parked facing away from the wind on a really gusty day with the control column locked.  I think the buffeting loosened up the flaperon rivets, unfortunately.  Hard lesson.  Will replacing the rivets require any disassembly?
 Carl
				 Posted: Tue Jun 01, 2010 6:04 am    Post subject: Flaperon tube looseness? |
				Carl,
  I don't think so, unless the rivet tails rattling around in the spar is a
 problem to you.  I think I'd do one at a time to keep the flaperon  in
 alignment.  I had a situation once where the rivet ends were noisy and I
 just injected a small amount of epoxy and they settled down.
 Lowell
 Sent: Monday, May 31, 2010 8:50 PM
 Subject: Re: Flaperon tube looseness?
  Thanks guys.
  any disassembly?
  Carl
  http://forums.matronics.com/viewtopic.php?p=299517#299517
