Sam
Posted: Wed Jun 09, 2010 5:05 am Post subject: Off Topic - Special gain amplifier |
I came across this special amplifier, guaranteed to boost and smooth your signal. I can't wait to order one.
I hope the photo comes through.
Sam
82.34 KB |
6460 Time(s) |
_________________ Sam Hoskins
www.samhoskins.blogspot.com |
harley(at)AgelessWings.co Guest
Posted: Wed Jun 09, 2010 5:25 am Post subject: Off Topic - Special gain amplifier |
Sam...
Cool! Wonder how many were sold, and how many people to this day think it did something? <G>
If I had "invented" it, I would have put in some more useless wires and parts to make it look like the trim pots connected to something. Just in case someone opened it up, as was done here! And maybe run the coax through another, sealed, interior box so that it's routing wouldn't be so obvious.
At least the power light is real!
Harley
On 6/9/2010 9:03 AM, Sam Hoskins wrote: [quote]I came across this special amplifier, guaranteed to boost and smooth your signal. I can't wait to order one.
Sam
mrspudandcompany(at)veriz Guest
Posted: Wed Jun 09, 2010 6:55 am Post subject: Off Topic - Special gain amplifier |
Sam
Can you get a special deal If you order
several of these, like 10% premium for 10 or more?
I am sure many on the list are as anxious to
have one of these beauties as you are.
Roger
DO NOT ARCHIVE
 Download |
| Filename: |
winmail.dat |
3.45 KB |
| Downloaded: |
1262 Time(s) |
simon(at)synchdes.com Guest
Posted: Wed Jun 09, 2010 7:07 am Post subject: Off Topic - Special gain amplifier |
Sam,
The frequency range shown on the cover implies that you are going to use it for VOR amplification, since COM is a two way street, and any amplifier in a simple in-line connection will interfere with one way.
I see several things wrong with the amplifier and its use. First, it is poorly built and may not stand up to aircraft quality standard. Second, an in-line amplifier can boost a signal, but it cannot "smooth" unless it filters our certain frequencies. If you know the "smoothing" function, then you can determine what frequencies are being attenuated. Are these frequencies crucial to your application? Third, any in-line active amplifier will add noise. Do you know what its SNR is? If it is low enough, it may be tolerable. If it isn't, you're just adding another problem.
Most equipment, especially our aviation equipment, is made to connect to antennas without amplification to avoid the above problems. Do you have a specific problem with the system you're trying to fix? Can it be fixed without amplification?
Simon Ramirez
LEZ N-44LZ
Sam
Posted: Wed Jun 09, 2010 7:54 am Post subject: Off Topic - Special gain amplifier |
Sam,
problem.
Simon Ramirez
LEZ N-44LZ
Simon,
Are you serious??????????
Roger
Sam
DO NOT ARCHIVE
 Download |
| Filename: |
winmail.dat |
5.04 KB |
| Downloaded: |
768 Time(s) |
rampil
Posted: Wed Jun 09, 2010 8:33 am Post subject: Re: Off Topic - Special gain amplifier |
Simon,
The frequency range on the box actually specs broadcast and bands of cable TV, airband anything
