		Lew Gallagher
				 Posted: Mon Jun 14, 2010 9:33 am    Post subject: Halotron fire extinguisher |
				Hey Guys,
 With the discussion about the tunnel fire/explosion, I decided to follow up on some of the discussions about tunnel/FF nozzles, extinguishers, etc.  When I called the guy that does my building's fire inspections, he said they haven't made Halon extinguishers since the mid nineties, and that they only do Halotron now.  No flurocarbons, no residue, doesn't destroy electrical, etc.  So I ordered a 2.5 lb one from him (Buckeye, 70256, $88.00).
 Am I late on this?  Is this what everyone is installing now?  I searched briefly and didn't see any reference to it, so I thought I'd ask.
 By the way, the one follow up report on the fire was very generic, and I'd love to hear more from the pilot other than that one quick response where he said he thought he may have hit the flap switch, and that they're basically OK.  Fuel lines, pump -- anything left to diagnose what happened?
 Later, - Lew
  _________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
		Tim Olson
				 Posted: Mon Jun 14, 2010 10:25 am    Post subject: Halotron fire extinguisher |
				True to some extent....but you can still get them for
 Aviation:
 http://www.aircraftspruce.com/catalog/pspages/h3rhalon.php
 Tim Olson - RV-10 N104CD
 On 6/14/2010 12:33 PM, Lew Gallagher wrote:
  Gallagher"<lewgall(at)charter.net>
  Hey Guys,
  ask.
  Later, - Lew
  -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549
  Fly off completed !
  http://forums.matronics.com/viewtopic.php?p=301200#301200
		Lew Gallagher
				 Posted: Mon Jun 14, 2010 11:27 am    Post subject: Halotron fire extinguisher |
				Hey Tim,
 Good to "see" your voice -- missed you there for awhile.  Why would you want
 Halon if it does so much collateral damage and is essentially obsolete?
 Later, - Lew
		Tim Olson
				 Posted: Mon Jun 14, 2010 11:49 am    Post subject: Halotron fire extinguisher |
				I'm not an expert, but Halon is one of the options that
 does NOT do the collateral damage.  The fact that
 it's obsolete isn't really 100% true. They can't
 make it anymore, but, it's still made available for
 aviation and is still legal to sell and use.
 The Halotron is just a more environmentally approved alternate,
 but often the things that are the new thing aren't as effective.
 I know almost nothing about Halotron, but I know that Halon is
 still available to us for planes, so I just wanted to point
 that out.  Halon is still the most effective though.
 I suppose with google and a little
 Halon vs. Haoltron search you could find a lot.
 For instance:
 http://www.h3raviation.com/faq.htm
 http://www.h3raviation.com/press-FAA-Approval-397-398.htm
 http://www.z06vette.com/forums/f5/halon-vs-halotron-85693/
 http://www.vetteworksonline.com/cata...products_id=77"
 http://forums.corvetteforum.com/c3-general/2195274-halon-vs-halotron.html
 http://www.halotron.com/product_origins.php
 Excerpt from one is below my sig.
 "The EPA recognizes that that Halon remains the most effective "clean"
 extinguishing agent available, despite its ozone depleting potential,
 and there are no federal or state regulations prohibiting the buying,
 selling or use of Halon extinguishers. All Halon available now is
 recycled so it is an environmentally responsible choice."
 and
 "Halon can no longer be manufactured due to the effects it said to have
 on the Ozone, so all the Halon left in the world has to be recycled to
 fill new canisters. Halotron 1 is the replacement gas for Halon. It has
 about ½ the efficiency to Halon. For example, a 2.5LBS Halon bottle has
 a UL rating of 5; where as, a 2.5LBS Halotron 1 has a UL rating of 2.
 To understand the UL rating view this Halotron video:
 http://www.vetteworksonline.com/videos/Amerex_WS.mov
 Halon is still the granddaddy of the no mess fire extinguishers, and it
 is the choice for most racers, but it is more expensive then Halotron 1.
 I use Halon in my Corvettes. Put it in the front passenger seat using
 the Vetteworks C3 bracket. A 2.5LBS extinguisher is sufficient enough
 size. A 5 LBS is a bit big in a Corvette.
 and
 "Halon is the gold standard in fire suppression. However it's
 manufacture was prohibited under the US Clean Air Act od 1994 as it is
 an ozone depleating Bromated Flurocarbon. It is still manufactured in
 some third world countries. It is NOT illegal to possess and use on
 actual fires.
 In fact the FAA requires up to 5 1211 Halon units on all heavy
 commercial airliners.
 Halon 1211 is a pressurized liquid most commonly found in hand held FE's
 that is a non-conductive, oxygen robbing agent that leaves no residue as
 it turns to a gas at normal atmospheric pressure.
 Halon 1301 is a pressurized gas used in gas flooding fire suppression
 systems.
 Halotron is a synthetic substitute for Halon, a 2C3FC. It is fairly new
 and is supposed to be as effective as Halon however it has not been
 around as long.
 here's it's MSDS:
 http://halotron-inc.com/msds-test.htm
 With any of the above I suggest taking in a deep breath before
 deployment, holding it, and running like hell to up wind.
 These gases will be quickly diluted and dissipate into the atmosphere.
 I recommend using the Halon as it is tried and true and is the best
 agent when fire is lapping at your butt.
 My personal recommendation is to use either a
 AMEREX Halon 1211 2.5# hand held FE
 SAFECRAFT Halon 1301 20# 3 head Fire Suppression system
 OR BOTH "
 On 6/14/2010 2:26 PM, Lew Gallagher wrote:
  Hey Tim,
  want Halon if it does so much collateral damage and is essentially
  obsolete?
  Later, - Lew
		dlm46007(at)cox.net Guest
				 Posted: Tue Jun 15, 2010 8:24 am    Post subject: Halotron fire extinguisher |
				Halon is not obsolete; available from stroud Fire in OKC. I have in my 10.
 ---- Lew Gallagher <lewgall(at)charter.net> wrote:
  Hey Tim,
  Later, - Lew
