mtherr(at)yahoo.com Guest
Posted: Sat Jun 26, 2010 6:39 pm Post subject: Rudder hinge wear - solution anyone? |
Hi group,
I mentionned about the rudder upper bearing (hinge) becoming loose with time. I already replaced it once. It appears somewhat loose again. Did anyone invent a fix for this?
Michel Therrien CH601-HD, C-GZGQ
http://mthobby.pcperfect.com/ch601
http://pages.infinit.net/mthobby
carlossa52(at)gmail.com Guest
Posted: Sat Jun 26, 2010 7:38 pm Post subject: Rudder hinge wear - solution anyone? |
How about that bearing that was discussed a few days ago? It was meant for the aileron bell crank, but maybe it could be used on the rudder...?
Salut bien
Carlos
On 26 June 2010 22:37, Michel Therrien <mtherr(at)yahoo.com (mtherr(at)yahoo.com)> wrote:
[quote]--> Zenith601-List message posted by: Michel Therrien <mtherr(at)yahoo.com (mtherr(at)yahoo.com)>
Hi group,
bryanmmartin
Posted: Sun Jun 27, 2010 1:23 am Post subject: Rudder hinge wear - solution anyone? |
Do you keep it greased?
On Jun 26, 2010, at 10:37 PM, Michel Therrien wrote:
Hi group,
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
Posted: Sun Jun 27, 2010 6:47 am Post subject: Rudder hinge wear - solution anyone? |
Hi group,
Michel,
I had to machine new bushings. The paragraphs below, from my
journal, describe, I believe, the same issue and my solution.
The top bolt on the rudder rattled so the bolt was inspected and found to be worn and sloppy.
Began again today with removal of the rudder I removed the press-fit bushing from the upper rudder plate by grinding a 3/16th inch Allen screw head to .250-diameter and used a 3/8-inch socket and nut to pull it
from the plate. Once home, I made 4 more bushings on the lathe that were
better lengths for the rudder bracket gap. The loose bolt had caused wear at the
top angle bracket holes and to the bolt.
>> This morning, the first press fit of the best-length bushing went
>> well. The same screw used to remove the former bushing was used to
>> pull it to a force-fit into place. The rudder was placed on the
>> upper bushing and bolted. The bottom bushing was replaced with a
>> slightly longer one and it too was given a fresh new bolt. Both were
>> snugged to stop bolt rotation and secured with castle nut and cotter
>> pins. Now bolt and bushing were the only working surfaces as intended.
>> Larry McFarland 601HDS at www.macsmachine.com
Posted: Mon Jun 28, 2010 8:03 am Post subject: Rudder hinge wear - solution anyone? |
Larry, I think I did it differently than you.. in my case, the upper plate rotates around the bushing that itself is captured in a fixed position between the two angles attached to the rudder. The bolt does not rotate on any part.
Are you saying that the bushing should stay "with" the upper plate attached to the fuselage and that the friction should be between the bolt and the bushing? If so, that must be hard to lubricate...?
--- On Sun, 6/27/10, Larry McFarland <larry(at)macsmachine.com> wrote:
| Quote: | From: Larry McFarland <larry(at)macsmachine.com>
Subject: Re: Rudder hinge wear - solution anyone?
Received: Sunday, June 27, 2010, 10:27 AM
by: Larry McFarland <larry(at)macsmachine.com>
Therrien <mtherr(at)yahoo.com>
> Hi group,
> Michel,
> I had to machine
solution.
> The top bolt on the
worn and sloppy. Began again
3/8-inch socket and nut to pull it from the plate. Once
home, I made 4 more bushings on the lathe that were better
caused wear at the top angle bracket holes and to the bolt.
best-length bushing went well. The same screw used to remove
the former bushing was used to pull it to a force-fit into
place. The rudder was placed on the upper bushing and
bolted. The bottom bushing was replaced with a slightly
and cotter pins. Now bolt and bushing were the only working
www.macsmachine.com
Email Forum -
FAQ,
- MATRONICS WEB FORUMS -
List Contribution Web Site -
-Matt
Dralle, List Admin.
Posted: Mon Jun 28, 2010 3:35 pm Post subject: Rudder hinge wear - solution anyone? |
Michel,
The bushing was made as a press fit in the large plate. The bolt secures
center within the bushing and was easy to lubricate by greasing the bolt
on assembly.
The upper and lower plates held to center by the bolt are strong enough
to not allow the bolt to rotate in them. The actual rotation forces are
borne by
the largest surfaces of the bolt and inside the bushing. The top and
bottom bushing surfaces are not strained at all in flight. Wear on my
bolt occurred because
it was not tight and locked to allow no pivot within the upper and lower
plates. The bolt now rotates with the rudder and the bushing is fixed by
its fit
in the plate. I had to make 4 bushings to get it right. The bottom plate
holds the rudder at elevation as well so that the top bushing isn't
doing all the lifting.
If the bushing were allowed to rotate in the top and bottom plates, I
believe wear would be a significant issue at the top pivot assembly.
Doubt bronze would be as good in holding a press fit and that's why I
made mine of steel.
