Ground Power and Aux Alt sharing OVM?
jonlaury
PostPosted: Mon Jun 28, 2010 9:49 am    Post subject: Ground Power and Aux Alt sharing OVM? Reply with quote
I'm using Z13 in conjunction with Z31-B. Is there anything wrong about the aux alternator and the ground power jack sharing the same OVM? The only condition that I can think of where both systems would be in use simultaneously is a ground powered START on the aux alternator and that may not even be an issue unless the OVM tripped. The issue being what caused it, the GPU or the aux alt.
If this passes group muster, how would I wire it?
PostPosted: Mon Jul 05, 2010 5:49 am    Post subject: Ground Power and Aux Alt sharing OVM? Reply with quote
Can't think of a practical way to do it.
