		rleffler
				 Posted: Fri Jul 02, 2010 10:09 am    Post subject: Door Seals |
				For those that went the McMaster door seal route…..
 I just put the seals on for the first time.  As many else have experienced, a perfect fitting door is no longer perfect fitting after putting on the seals.   The door is sitting proud only on the top of the door.    Once I put the hinges on the door, will compression remedy this issue or will I need to figure out another solution?
 I also have the problem at the bottom of the door where there is a gap on the forward section of the door.  That should just be a straight forward solution of building the rain gutter back up until it’s flush along the entire bottom.
 bob
  _________________ Bob Leffler
N410BL - Phase I
		drfred(at)suddenlinkmail. Guest
				 Posted: Fri Jul 02, 2010 10:35 am    Post subject: Door Seals |
				Bob;
 I had to cut mine back some, in fact I had to drop the edge down about
 1/4 "" to make it work. You're just about done.....   .
 Dr Fred
 515 FW
 See you'all at OSH.
 Bob Leffler wrote:
  bob
				 Posted: Fri Jul 02, 2010 11:41 am    Post subject: Door Seals |
				You need to get that bulge up top resolved if you don’t it  will impact the bottom of the door. I ended up sanding (a whole lot since I have  the Vans seals) to get the top more flush once I did that my doors closed and I  worked from there. Having the hinge force it down a little may be fine but I  would fix it so that it really is minimal and without much  resistance
  get the door to fit first than take care of the gaps  everywhere.
  Best of success
  Sent: Friday, July 02, 2010 11:09 AM
  Subject: Door Seals
 bob
		rene(at)felker.com Guest
				 Posted: Sat Jul 03, 2010 5:54 pm    Post subject: Door Seals |
				Here is another option.
 http://www.rvtraining.com/html/atp//html/products_pics.html#DoorSeal
 Did not affect fit, works great.  These are expensive……but…..no sanding…
 Rene'
 801-721-6080
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal
 Sent: Friday, July 02, 2010 1:40 PM
 Subject: Re: Door Seals
 Best of success
 Subject: Door Seals
 bob 	  | Quote: | 	 		  |   href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c    | 	  0123456789 	  | Quote: | 	 		  | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 	  0 	  | Quote: | 	 		  | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 	  1 	  | Quote: | 	 		  | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 	  2
		Walt Fuller
				 Posted: Wed Jul 21, 2010 4:38 pm    Post subject: Re: Door Seals |
				Please forgive me if this information has been posted elsewhere on this forum. I'm wondering if anyone has applied the door seals to the openings or "jams" themselves as opposed to on the door. And if so...can you suggest a specific seal or manufacturer? Thanks in advance.
 Walt Fuller
 RV-10 build # 40584
 getting the panel together
		kearney
				 Posted: Wed Jul 21, 2010 5:12 pm    Post subject: Door Seals |
				Walt
 If you look at the posts over the past couple of weeks you will find
 everything you need to know. McMaster Carr seals seem to be the seal of
 choice - and they do mount on the door frame and not the door.
 Cheers
 Les
 #40643
		Walt Fuller
				 Posted: Thu Jul 22, 2010 7:02 pm    Post subject: Re: Door Seals |
				Thank you Les. I missed the posts somehow on the first go around. Great info on the posted document. Looks like McMaster Carr seals are the way to go. Will have to do some retro fitting but will make it work. Thanks again.
 Walt Fuller
 N420CF
