hans-chr.erstad(at)c2i.ne Guest
Posted: Mon Jul 05, 2010 2:23 pm Post subject: SV: SV: Re: KIS IT-1 Aerodynamics |
Thanks for comments Mark
I will do the take off as you explain the next time I fly, and report back
You mentioned "More to do with science and engineering methods". I have
encosed a NACA report I found when googling for some scientific material on
the subject, after I first met Julian, and he told about his modification.
Interresting reading, both from an scientific and historical, point of
view! Many things in our world have changed since that report were made, but
the laws of physics have not changed?
I have not experienced any loss of elevator authority, but feel that an
approach at lowest speed needs a lot of adjustment in pitch. But close to
ground there is almost always some turbulence anyway.
But making control input while flying is not a problem - it is what piloting
is about
Regards, Hans Christian
-----Opprinnelig melding-----
Fra: owner-kis-list-server(at)matronics.com
[mailto:owner-kis-list-server(at)matronics.com] På vegne av Mark Kettering
Sendt: 5. juli 2010 20:18
Til: kis-list(at)matronics.com
Emne: Re: SV: Re: KIS IT-1 Aerodynamics
Hello Hans,
| Quote: | I have flown my KIS 1 for 10 years now, and I agree with 'OC' comments
about the handling with respect to difficulties making consistent
landings and keeping the nose wheel up.
I have flown a TR1 with the main gear in the stock position and with that
aircraft I also had the same problems. So I made some calculations and
found out that the stock main gear location was too far aft. On my TR1 I
then moved it forward and fully eliminated not only this problem on my
aircraft but also the takeoff tendency to over rotate. When flying with
Rich and watching the stick I noted that he had to pull way back to rotate
then quickly release this back force and movement to prevent over rotation
on lift off.
| Quote: | About the wing/fuselage fairing. I have meet Julian several times at
fly-in. He told that the fairing modification made the landings with a
low approach speed a lot easier. Why not believe his experience? I
think he is the only one to make the modification, and having
experiencd what difference it makes. I have fairing modification on my
to-do list. But I may never come to that item on my list, as I feel the
landings are still OK, and I do not operate from runways shorter than
800 meters. I usually keep a little power on in the flare.
Well, I am not a believer! But that has little to do with Julian's
experiences. More to do with science and engineering methods. At some
point with more data I may agree that the elevator loses authority due to
wing fuselage junction separation. At this point I am waiting on seeing the
video for myself. The one still picture I have seen does not seem to
support the conclusion that the wing fuselage junction is causing separation
of flow over the tail. I also never have a sudden loss or any loss of
elevator authority with my aircraft at any time and I have the stock wing
root fairings so this data also does not seem to support that conclusion.
But this is not to say that Julian did not have this problem. Maybe his
plane is slightly different than mine. Maybe my more poor (or maybe better)
fit of my parts in this area prevented a problem that his plane had. Who
knows?
But I do do know the stock main gear location is too far aft relative to the
CG (range) location. I also know that angling the gear forward (moving the
gear contact point forward) reduces the hard nose let down at all CG
locations and cures the tendency to over rotate.
Next time you fly please try this for me but be very careful and let me know
what happens! As you pull back to rotate just hold the stick in the same
location and fly off the runway. This is how a good handling aircraft
should takeoff. It should not need pilot input beyond a steady back
pressure. You should not need to release or push forward. The plane should
literally "fly itself" off the runway. But if you do this in the TR1 with
the main gear in the stock location you will over rotate and need to move
the stick forward. Or you will stall and maybe worse.
Also please keep in mind that the gear location is very easy to change.
Mark
List
7-Day
 Download |
| Filename: |
naca-report-482.pdf |
1.21 MB |
| Downloaded: |
1031 Time(s) |
mantafs(at)earthlink.net Guest
Posted: Mon Jul 05, 2010 7:47 pm Post subject: SV: SV: Re: KIS IT-1 Aerodynamics |
Hi Hans,
That is a very interesting NACA report. I think that specific aircraft design had some major issues. Plus the airfoil used has a major issue of it's own. For example the airfoil has an initial stall angle of just 8.5 degrees, right about where the tail starts to be less effective according to the report. Of course when the wing stalls then there is less down wash on the tail so there is less down force. But most engineers today think of this as a very good thing since it helps act to reduce the likely hood of a stall. If the main wing is starting to stall, then maybe there should be less down force in the tail so the plane starts to pitch down to keep more of the main wing from stalling.
They also talk as if the tail buffeting is a bad thing. Of course tail flutter is but that is not at all the same as buffeting. Production aircraft today are required to have some sort of tail buffeting to warn of a stall. Planes that do not have this "stall indication" are then required to have stick shakers and/or stall horns. If you look at some production aircraft they have main wing leading edge wedges near the root to make buffeting prestall to meet this requirement.
I am a big fan of the old NACA reports. I spent one summer at NASA reading a bunch of them. Many of the old reports are very applicable to our small aircraft. But at times you need to be very careful applying the information in them since at times there is a difference in goal, way of thinking or original conditions to what we have today. For example this report did not address handling qualities on any way. Yes, maybe you could keep the root from stalling first. But do you really want to? I prefer the root to stall before the center and tip since I do not like for the plane to roll into a spin when it stalls. Yes, you can eliminate tail buffeting but do you want to remove the stick shake that warns you of the impending stall? Some airfoils like the NACA M6 have preliminary and secondary stall and this can greatly effect the data but then is this data applicable to our airfoil?
In any case, I think this supports my original theory in that all we are really seeing is the start of the main wing stall and it is starting at the root. Large radius fairings may reduce the local Cl at the root and then this could delay the stall at the root. But the wing will still stall.
Mark
ftyoder(at)yoderbuilt.com Guest
Posted: Mon Jul 05, 2010 9:08 pm Post subject: SV: SV: Re: KIS IT-1 Aerodynamics |
Hello Mark,
I was thinking that this wing would not be beginning to stall at the 80 to
65 mph short final to flair, that I think most of the reporters are
indicating. Our wings are level with a low pitch angle. I understand that it
is better to have the stall begin at the root but I thought it would be at
below 65mph for the TR-1, is this thinking wrong?
Posted: Tue Jul 06, 2010 9:04 am Post subject: SV: SV: Re: KIS IT-1 Aerodynamics |
My Numbers:
Main gear axle: STA 73.6 (my construction manual says 73.5, so meybe I did
not follow it 100% after all
Nose gear axle: STA 21.2
Firewall rear face (ref point): STA 32
(73.6-32=41.6)
See also http://home.c2i.net/h-erstad/ Weight&Balance report
Hans Christian
[mailto:owner-kis-list-server(at)matronics.com] På vegne av F. Tim Yoder
Sendt: 6. juli 2010 00:52
Mark, 'OC' and all,
My gear dimensions are as follows;
Main gear axle center line to firewall is 42 1/8"
" " " " " " nose gear axle center line 53"
I would be interested to see your numbers.
In retrospect, I do have to watch and may have to increase stick pressure in
order to keep the nose gear off the runway. But I do have plenty of elevator
authority to do that.
Julian's plane was a tail dragger (conventional) I think. He was trying to
give it STOL qualities, an oxymoron I think. I forget what he built to
replace the KIS, I think it is a high wing with better STOL qualities.
Mark, I am in annual now, but I will try and report on your take off
procedure. That is if I don't stall, crash, and burn!
Also, maybe it would be helpful to confirm final approach and touch down
speeds from the GPS, if available, to confirm the accuracy of our different
pitot systems at slow speeds. I you are flying alone, it might be safest to
do this at altitude in a practice area.
'OC', maybe Mark and Rich are just better pilots than you and I because I
use your technique for more consistent landings.
Oh, Mark and 'OC' what was the thickness of your main gear shims? Are they
fiberglass or aluminum or???
Posted: Tue Jul 06, 2010 9:14 am Post subject: SV: SV: Re: KIS IT-1 Aerodynamics |
Hello Tim,
At gross weight and with 20 degrees of flaps the theoretical calculated stall with the airfoil on the TR1 would be 60.5 mph. This number is using the standard definition for the wing area, length X cord. Since some of the "area" is inside the fuselage the actual usable area (area generating lift) is slightly less so making a ball park adjustment I would guess actual stall speed would be about 63 mph. This does also not take into account the added "weight" from the tail down force that of course the wing also needs to support. Of course when we build the planes they are not perfect or the same so maybe your stall is slightly different and generally higher. So, 65 mph is not at all far off from stall. And as someone recently implied, the pitot airspeed may not be accurate especially at low speeds.
At gross the TR1 is not at all a STOL type aircraft. The wing is just too small and short. But it is a good all around performer with a fair cruise speed and a fair landing speed.
Mark
jconners(at)dot.state.nv. Guest
Posted: Tue Jul 06, 2010 9:26 am Post subject: SV: SV: Re: KIS IT-1 Aerodynamics |
My experiences flying N94K (KIS TR-1 with Lycoming O-235 L2C) at slow speeds at high altitudes (8000-14500 MSL) and full fuel with pilot only...the aircraft does not stall at 35 knots but the resulting extreme low tail attitude prevents landing at such speeds.
What are the recorded slow flight speeds being experienced by other TR-1 pilots?
Jer
Jerry Conners, PE
Civil Engineer
Nevada Department of Transportation
310 Galletti Way
Sparks, Nevada 89431
775-834-8363 (voice mail)
jconners(at)dot.state.nv.us
richard_trickel(at)yahoo. Guest
Posted: Tue Jul 06, 2010 9:42 am Post subject: SV: SV: Re: KIS IT-1 Aerodynamics |
Hi Jerry
Thanks for logging in. You say the plane stalls 35 Knots so I´m guessing that is indicated. Have you tried to compare with a gps in different directions to compensate for the wind.. Your number is very low.
Rich
--- On Tue, 7/6/10, Conners, Jerry L <jconners(at)dot.state.nv.us> wrote:
From: Conners, Jerry L <jconners(at)dot.state.nv.us>
Subject: RE: SV: SV: Re: KIS IT-1 Aerodynamics
To: kis-list(at)matronics.com
Date: Tuesday, July 6, 2010, 5:21 PM
--> KIS-List message posted by: "Conners, Jerry L" <jconners(at)dot.state.nv.us (jconners(at)dot.state.nv.us)>
Jer
Jerry Conners, PE
Civil Engineer
310 Galletti Way
