Door gas strut attach bracket replacement
Strasnuts
PostPosted: Fri Jul 09, 2010 10:51 am    Post subject: Door gas strut attach bracket replacement Reply with quote
I made a set of these for my plane and I would like some feedback. These move the strut a little lower so the hinge covers don't interfere with the strut. They also have a cutout for the McMasterCarr seal. The geometry is basically the same as the stock bracket. They are made out of nylon and can withstand a lot of abuse. I have been letting my doors spring open and shutter at the extent to test the strength of the nylon. I have done this probably sixty times and so far so good. They are drilled and threaded so they can be retro-fitted or newly installed. No nutplates needed. Oh ya, they come with a short 1/4 inch bushing for installation instead of the 4 washers. Sorry for the crappy picture.
 Filesize:  271.54 KB
 Viewed:  3245 Time(s)
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
rvdave
PostPosted: Fri Jul 09, 2010 8:00 pm    Post subject: Re: Door gas strut attach bracket replacement Reply with quote
I like them, how much are you asking for a set?
Dave Ford
Cadillac, MI
Strasnuts
PostPosted: Sat Jul 10, 2010 6:23 am    Post subject: Door gas strut attach bracket replacement Reply with quote
Vans sells them at 24.40 each. I was thinking 40 for both in the long run and if there is a demand.
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=304379#304379
780 Hours
SuperSTOL 60 hours
jcumins(at)jcis.net
PostPosted: Sat Jul 10, 2010 11:13 am    Post subject: Door gas strut attach bracket replacement Reply with quote
Put me down for a set shoot me a e-mail how you want paid for them.
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94534
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
