bakerocb
Posted: Sun Jul 11, 2010 2:38 pm Post subject: Deceptive Voltage? |
7/11/2010
Hello Bob Nuckolls and other Electrical Gurus,
Suppose you ran your battery down by spinning your first time to be started
O-540 Lycoming engine with the starter in order to preoil the engine in your
nearly finished RV-10. And maybe you did some other things that ran the
battery down.
Then you connected your small amperage output battery charger to the battery
and you attempted to start the Shower of Sparks equipped engine without
success. The engine was cranked OK, but the starting vibrator just was not
putting out.
A check of the system voltage in appropriate points with a separate volt
meter while cranking the engine showed 13 plus volts.
Is it possible that the voltage being seen was in fact the voltage being put
out by the battery charger as it attempted to recharge the run down battery,
but the amperage being put out by the run down battery and battery charger
together just was not enough current flow to run the starting vibrator as
well as crank the engine?
'OC' Baker Says: "The best investment we can make is the time and effort to
gather and understand knowledge."
Posted: Mon Jul 12, 2010 7:01 am Post subject: Deceptive Voltage? |
At 05:36 PM 7/11/2010, you wrote:
7/11/2010
started O-540 Lycoming engine with the starter in order to preoil the
engine in your nearly finished RV-10. And maybe you did some other
things that ran the battery down.
battery and you attempted to start the Shower of Sparks equipped
engine without success. The engine was cranked OK, but the starting
vibrator just was not putting out.
volt meter while cranking the engine showed 13 plus volts.
This number appears bogus. A battery is incapable
of delivering energy at more than about 12.5 volts
lightly loaded . . . a few amps. Given that most
batteries offer an internal resistance on the order
of .007 to .010 ohms, a 200A starter draw would be
expected to drop the battery terminal voltage by
perhaps 2 volts. So a terminal voltage of 10.5 or
lower is expected.
being put out by the battery charger as it attempted to recharge the
run down battery, but the amperage being put out by the run down
battery and battery charger together just was not enough current flow
to run the starting vibrator as well as crank the engine?
No, if the engine cranked at some speed you would
EXPECT to start it, then the battery is fine. The
shower-of-sparks system is designed to do two things:
(1) increased intensity of the sparking energy by
offering a repeating train of battery-supported
sparks and (2) DELAYING the delivery of ANY sparks
until just after TDC such that potential for kickback
is eliminated.
If your engine cranks but doesn't start, the battery
is fine and the SOS system is suspect. This article might
be of value in your quest for making all things right
with the world:
http://www.aeroelectric.com/articles/Shower-of-Sparks/ShowerOfSparks.pdf
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
bakerocb
Posted: Tue Jul 13, 2010 4:38 am Post subject: Deceptive Voltage? |
7/13/2010
Hello Again Bob Nuckolls, Thank you for the prompt response copied below,
but my specific electrical theory question about the battery charger output
voltage possibly masking the battery's output voltage capability was not
answered.
In response to the statement: "...... a separate volt meter while cranking
the engine showed 13 plus volts."
You wrote: "This number appears bogus. A battery is incapable of delivering
energy at more than about 12.5 volts.........."
But what about the battery charger that is connected to the system, turned
on, and providing a higher than normal battery output voltage in its attempt
to recharge the battery while the engine was being cranked and the volt
meter readings were taken?
My electrical theory question is: "Could that battery charger output voltage
be affecting the reading obtained by the separate volt meter and indicate
that the battery is more capable than it really is in putting out amperage?"
Thank you.
PS: Thank you also for writing and passing on the link to the article about
Shower of Sparks.
I will pass that along to the RV-10 builder and his helpers.
Time: 08:01:28 AM PST US
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
Subject: Re: Deceptive Voltage?
7/11/2010
lower is expected.
is eliminated.
with the world:
klehman(at)albedo.net Guest
Posted: Tue Jul 13, 2010 5:05 am Post subject: Deceptive Voltage? |
OC
The thing is the battery voltage during cranking is the highest possible
voltage in the system during cranking. The charger voltage must be
pulled down to the same value unless you are measuring near the charger
and there is is high resistance between where you are measuring the
voltage and the battery. That would mean you have a second wiring issue.
So Bob really did answer the question. The 13 volt reading is
bogus/wrong/not related to you shower of sparks problem and is
meaningless/impossible unless you have the above mentioned second issue
or a large (100 amp ?) charger. Hope that helps a bit.
The answer to your electrical theory question is "No"
BTW I do enjoy your posts.
Ken
bakerocb(at)cox.net wrote:
7/13/2010
below, but my specific electrical theory question about the battery
charger output voltage possibly masking the battery's output voltage
capability was not answered.
cranking the engine showed 13 plus volts."
delivering energy at more than about 12.5 volts.........."
turned on, and providing a higher than normal battery output voltage in
its attempt to recharge the battery while the engine was being cranked
and the volt meter readings were taken?
voltage be affecting the reading obtained by the separate volt meter and
indicate that the battery is more capable than it really is in putting
out amperage?" Thank you.
to gather and understand knowledge."
about Shower of Sparks.
7/11/2010
lower is expected.
is eliminated.
with the world:
nuckollsr
Joined: 24 Mar 2009 Posts: 95 Location: Medicine Lodge, KS
Posted: Tue Jul 13, 2010 6:06 am Post subject: Re: Deceptive Voltage? |
| Quote: | But what about the battery charger that is connected to the system, turned on, and providing a higher than normal battery output voltage in its attempt to recharge the battery while the engine was being cranked and the volt meter readings were taken?
My electrical theory question is: "Could that battery charger output voltage be affecting the reading obtained by the separate volt meter and indicate that the battery is more capable than it really is in putting out amperage?" |
My apologies, I did miss that one. A battery charger is simply another energy source. It has characteristics common to all energy sources in terms of potential power, open circuit voltage, ability to deliver current (internal impedance), noise, etc. A charge may be considered equivalent to a noisy battery (because its got artifacts of internal electronics noise and/or rectified ac mains) with a high internal impedance. The charger can produce no more output current than its designers provided. Unless the charger is specifically designed for cranking engines . . . see:
http://tinyurl.com/385snfg
then the effects of an operating charger on system voltage while cranking is insignificant. It's not unlike paralleling a 60A alternator with an SD-8 alternator. As long as you don't draw more than 8-10A, and SD-8 with a HIGHER regulation setpoint might happily assume all the load and boost the voltage high enough to cause the larger alternator to simply relax.
But as soon as the demand (in this case a cranking motor) exceeds the load carrying capabilities of the source with the higher setpoint (in this case a charger), the voltage sags to the point where the battery is willing and able to shoulder some load . . . in this case, about 12.5 volts or lower. So the short answer is, unless were talking about a boss-hogg charger that is capable of supporting engine cranking loads at 13.0 volts (I don't think such a critter exists), then the cited reading raises some questions as to measurement technique, quality of the instrument, etc. I would not dispute what the individuals observed but I will suggest that the reported readings raise more questions than they answer and beg some explanation that will come from data we do not yet have.
I will suggest that the voltmeter be tested against another instrument believed to be good. They should agree to within a 0.2 volts or so at 13v. Then connect the voltmeter right at the battery terminals to watch the battery's ability to pick up the cranking loads. Do the test with the charger connected, then repeat with the charger disconnected. I suspect that voltage readings while cranking under the two conditions will be under 12.5 volts and not significantly different from each other.
