Posted: Tue Jul 13, 2010 6:36 am Post subject: ANL current limiter location on rear battery installations |
At 05:53 AM 7/13/2010, you wrote:
<Tom(at)CostanzaAndAssociates.com>
With respect to:
> Small aircraft do not get circuit protection in
> the battery feeders to the starter and distribution
> busses.
Why does the battery feeder to the distribution buss not get protected?
Because fat wires in dc electrical systems are
exceedingly hard to burn, hence there is no
value added in attempting to protect them. The
legacy design goals for DC systems in most vehicles
don't call for adding circuit protection to wires
until they become so small compared to the potential
energy sources (1000+ amps from a hard faulted battery)
that wiring protection is called for.
A fat wire in an airplane that's allowed to hat-dance
up to a chunk of airframe will probably burn a hole
in the airframe without opening the upstream
circuit protection. I've seen a 8AWG wire protected with
40A breaker burn an elevator cable in two without so
much as generating bad smells, blinking the lights
or popping a breaker.
Hence design goals and installation that suggest extra
attention to the insulation and support of fat wires combined
with a crew-controlled shut-off right at the battery
i.e. battery contactor.
tomcostanza
Posted: Wed Jul 14, 2010 2:49 am Post subject: Re: ANL current limiter location on rear battery installat |
Thanks for that Bob. As often is the case, at least with me, the answer to one question leads to more questions.
| Quote: | Because fat wires in dc electrical systems are
value added in attempting to protect them. |
When you say "protect them", I'm not sure what you mean. Not knowing any better, I might want to protect things near the high current path, or the battery itself, from melting. Your thoughts?
| Quote: | Hence design goals and installation that suggest extra
i.e. battery contactor. |
Got it. But again, another question, this time about the wire supplying the main battery buss, for example in Z-11. This is neither fused, nor does it go through the contactor. So it isn't shut-off-able. What's the worst case if this shorts to ground. Will the wire just burn through as if it were a fuseable link? What if someone used a heavier wire, anticipating a more robust e-bus?
Please pardon my ignorance, and thanks so much for your patience.
_________________ Clear Skies,
Tom Costanza
-- in year 17 of a 3 year project |
Posted: Wed Jul 14, 2010 1:09 pm Post subject: ANL current limiter location on rear battery installations |
BN: Because fat wires in dc electrical systems are
The idea of adding "protection" to any wire goes
toward risk reduction. Risk of expense for making
easily avoided repairs, risk of experiencing a
hazardous condition. When a wire is strung through
the innards of a type certificated airplane, there's
a standard waltz tune played called "Failure Mode
Effects Analysis" or FMEA for short. This exercise
considers all the potentials for increased risk and
the return on investment for adding "protection" or
risk reduction.
The fat wires in the engine cranking path and major
bus feeders were deduced to first be capable of
very high reliability. Further, when installed with
good materials and practice, they were very low risks
to the airframe even if insulation integrity was lost.
Finally, history has demonstrated that when insulation
integrity of fat wires is lost, it's likely that the
fault condition will be relatively "soft" . . . i.e.
it will arc a lot over time releasing a lot of total
energy . . . but at current levels too low to open
the traditional protective devices. Hence the part
23 rule:
Sec. 23.1357 Circuit protective devices.
(a) Protective devices, such as fuses or circuit breakers, must be
installed in all electrical circuits other than--
(1) Main circuits of starter motors used during starting only; and
(2) Circuits in which no hazard is presented by their omission.
It was just such a fault that is believed to have
brought down Swissair Flt 111 by setting some combustible
insulation on fire after some not-designed-for-prime-time-
insulation cracked and precipitated a "soft" arcing event.
Rather than rewire thousands of airplanes with parsecs
of better wire, the Dispensers of Great Wisdom decided
that a new form of breaker was called for. Hence all
our friends at Klixon, Eaton, et. als. rushed off to
the lab to build little microprocessor based digital
signal detectors into the breakers and train them to
"listen" for soft faults.
Now, if you'd like to protect your ship's battery wire
for such events, I'm sure that somebody makes the breaker
for the job . . . but it will be big, heavy, expensive,
and probably run the lifetime of your airplane never
being called upon to trip.
Check the definition of an E-Bus. Just how "robust"
do you anticipate? See
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z32K.pdf
for recommendations concerning e-bus feeders FUSED
at greater than say 10A. In other words, if your e-bus
alternate feed path gets too big, then a crew-controlled,
mini-contactor is called for. The battery bus is another
critter. Since battery busses are located AT the battery,
their feeders are short. See that (*) on the battery
bus feeder wires? So yes, if that wire sees a fault
hard enough to smoke it, the rule 23.1357(a)(2) suggests
no hazard is presented if the wire is short because
smoke-risk is low and the event will be short lived
due to small gage of wire. At the same time, we want
that path to be very robust (low parts count and well
installed) so that reliability is high.
TA: Bob; this question is similar to what I was asking a few days ago
but I'm not sure we were on the same page, probably my fault. For
example the Z8 I'm using does not show any protection device between
the main bus and the contactor, in my case that is a 7'~8' run from
the rear mounted battery to the Instrument panel where the main bus
is located. The E bus is protected from both ends with fuses in your
drawing and I understand why but do not understand why there is no
protection on the feeder to the main bus/fuse block
BN: Because that should be a "fat" wire well installed.
This same pathway falls under the FAR23 category cited
above. Legacy design goals have supported the notion
for many decades and hundreds of thousands of airplanes.
You won't find this pathway fuse or breaker protected
in any type certificated SE aircraft on a par with your
grandpa's C-170. The e-bus alternate feed wire is
longer, smaller gage and capable of being fault-powered
from either end. Further, we don't want a fault on the
alternate feed path wire to open both the alternate and
normal feed paths. Hence NO protection in the normal path
and SHORT wires there too.
