		Dana
				 Posted: Mon Jul 12, 2010 11:48 pm    Post subject: UltraStar tailwheel strut |
				The mention a few days ago of a fiberglass rod for the tailwheel strut got me wondering.
  I'm having a problem with the tailwheel strut on my UltraStar. It was bent a bit when I got the plane, looks like it had been bent and straightened a few times. It bent, and the 5/8 tube crinkled a bit, right at the end of the 3/4" tube it slips into. I've straightened it out twice myself, but it keeps bending… the crinkled are weakens it, of course, but I don't know how much it tends to bend when straight. One solution is to cut it and splice a new piece of 5/8", but will it bend again? Was this a common problem with the UltraStar? It tends to get bent not on landing, but when moving the plane around with the wings folded (at least that's where I felt it bend the last time). One problem may be that when I got the plane, the 3/4" tube was cut off straight rather than angled per the plans (I've since corrected this), which makes a much worse stress concentration on the inner tube, contributing to its bending (and weakening) the first time.
  I could extend the 3/4" tube farther back which would make it quite a bit stronger, but it would also be less springy, which could lead to damage elsewhere; damage which would be harder to repair. Or go to a fiberglass rod (is that original on later Kolbs or is it an owner mod?). A 5/8" solid fiberglass rod is slightly weaker in simple bending than 5/8OD x .035 steel tube, but it's less prone to local crippling which seems to be my problem. Or perhaps somebody's come up with a better solution?
  -Dana
   Government cannot give you anything it does not first take away from someone.    [quote][b]
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Tue Jul 13, 2010 2:53 am    Post subject: Ultrastar tailwheel strut |
				Dana- Which way is the tube bending?  Sideways, or up (from bouncing)?  Next, do you know if the factory specified tubing of that particular grade, or having it hardened?  Is it original?  My Firestar does have a fiberglass rod tail spring.  No bends or cracks, but I'm careful to lift it when going sideways around the yard.  I worry more about bending the tubing on the "skeg", or doing some kind of damage to the main fuselage tube.  I seem to remember that the Ultrastar tail spring was longer, though.  Could be wrong.
                                                     Bill Sullivan
                                                     Windsor locks, Ct.
                                                     FS 447
				 Posted: Tue Jul 13, 2010 4:39 am    Post subject: UltraStar tailwheel strut |
				Dana:
  Normalized 4130 steel tubing makes a very poor  spring, unless heat treated, of course.
  The tail wheel strut should be a  spring.
  I use .120" wall 4130 heat treated to 48 RC for my  tail wheel strut on the mkIII.  An US could use something with a thinner  wall, like .090".
  I have also shortened tail wheel struts  dramatically on all three model Kolbs I built, US, FS, mkIII.
  [quote]     A 5/8" solid fiberglass rod is slightly    weaker in simple bending than 5/8OD x .035 steel tube, but it's less prone to    local crippling which seems to be my problem. Or perhaps somebody's come up    with a better solution?
 -Dana
  _________________ John Hauck
Titus, Alabama |
		WhiskeyVictor36(at)aol.co Guest
				 Posted: Tue Jul 13, 2010 7:37 pm    Post subject: UltraStar tailwheel strut |
				In a message dated 7/13/2010 3:48:45 A.M. Eastern Daylight Time,  d-m-hague(at)comcast.net writes:
    	  | Quote: | 	 		     Or go to a fiberglass rod (is that original on later Kolbs or is it    an owner mod?)
    Dana,
    FYI
    Fiberglass tail rod was standard on my original FireStar and also on    my buddy's KXP.  It worked great on turf, but was    too springy on pavement.  When I taxied on pavement, the spring    would start oscillating and the nose and tail would start going up and    down.  This would get worse and I would have to stop to get it to settle    down.  Then as soon as I started to taxi it would start doing it    again.
    Bill    Varnes
 Original Kolb FireStar
 Audubon  NJ
				 Posted: Wed Jul 14, 2010 6:02 am    Post subject: UltraStar tailwheel strut |
				Shorten the fiberglass rod considerably.  This should  reduce springiness.
  [quote]      It worked great on turf, but was    too springy on pavement.  When I taxied on pavement, the spring    would start oscillating and the nose and tail would start going up and    down.  This would get worse and I would have to stop to get it to settle    down.  Then as soon as I started to taxi it would start doing it    again.
Titus, Alabama |
