jhankin(at)planters.net Guest
Posted: Sat Jul 17, 2010 8:28 am Post subject: Portable press for gear legs |
This is a portable hydraulic press that I designed to straighten the legs of my Firefly when I perform a not to good landing, does not happen too often now.
The unit can be used OFF the Firefly or attached to the leg without removing the wheel and associated parts.
Parts used.
5 inch wide channel iron
4 ton hydraulic jack, ( Harbor Freight)
I/8 x 1 inch flat iron
Heavy duty chain
Chain connectors
One jack adapter
One 1 inch conduit bending tool
3/8
Thom Riddle
Posted: Sat Jul 17, 2010 9:28 am Post subject: Re: Portable press for gear legs |
jhankin,
Do you have a photo or two of your gear leg straightener, or just the parts list?
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Posted: Sat Jul 17, 2010 11:31 am Post subject: Portable press for gear legs |
Thom, I will try to take a picture of the unit this evening, right now it is 105 here in Georgia right now.
I really wanted to take a picture of it mounted on the gear leg with it attached to the Kolb.
Jimmy Hankinson
Firefly N6007L
Thom Riddle
Posted: Sat Jul 17, 2010 11:55 am Post subject: Re: Portable press for gear legs |
Jimmy,
I know. I follow the weather down there. I'm going to be visiting my daughter in north Atlanta 1st week of Aug. It should help remind me of why I moved north upon retirement. It is hot enough here at only 82F or so.
I appreciate whatever photos you have, or can take at your convenience, of your tube straightening rig.
Buffalo, NY (9G0)
- Anonymous |
